Win11 24H2 Issue
M3TALH3AD
10 (0.01/day)
None of the drivers are installing for the latest version of Win11 24H2.
I get an error during the installation process and it fails.
The normal driver from nvidia works fine but I'd rather use the cleaned up driver from this awesome tool.
Please look into this and run a test, this is happening on a GTX1080, RTX3080ti and RTX4060ti.
18,584 (2.70/day)
System Name AlderLake
W1zzard
Administrator
27,707 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
I assume this is some insider build for 24H2?
8 (0.00/day)
It's happening on all builds of 24H2, from 26100.1 to 26100.712 Release Preview.
The issue is related to driver signing. If I untick 'disable telemetry' and the required driver signing, the driver installs Ok.
21,408 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Sounds like fun changes coming down the pike from MS.
W1zzard
Administrator
27,707 (3.70/day)
Memory 48 GB
Interesting .. does anyone know if Microsoft is making changes to driver signing? Seems unlikely given this is not a major release? Maybe just a bug that they'll fix at some point
8 (0.00/day)
I've also tested with and without the EAC compatible method, both fail.
Is it possible to enable logging? I've tried with "setup.exe -log:"C:\NVlog" -loglevel:6" but no luck.
W1zzard
Administrator
27,707 (3.70/day)
Memory 48 GB
After installation, do you see the certificate in (certlm) Computer Certificates -> Trusted Publishers -> Certificates?
After installation, when you go to the install files -> Display.Driver and check the signature of nv_disp.cat, does the cert check out?
You have to at least start the installer for the certificate magic to happen, so don't just look at the generated files
8 (0.00/day)
'NVCleanstall Driver Modding Authority' gets installed into trusted root certs when running setup.
nv_disp.cat shows 'NVCleanstall Driver Modding Authority' embedded signature and is shown as Ok on the details panel.
W1zzard
Administrator
27,707 (3.70/day)
Memory 48 GB
Then installation should work fine. Microsoft just doing Microsoft things I guess
8 (0.00/day)
If I try to update manually via device manager I get a 'The hash for the file is not present in the specified catalog file' error.
From setupapi.dev.log:
Code:
Driver package INF file hash is not present in catalog file. Filename = nvltig.inf, Error = 0xE000024B
Driver package appears to be tampered, and Code Integrity is enforced.
Driver package failed signature validation. Error = 0xE000024B
30 (0.01/day)
Yes it looks like nvcleaninstall needs an update to get around some new ms security feature blocking nvcleaninstall drivers from installing they get like a third of the way in and crash out.
W1zzard
Administrator
27,707 (3.70/day)
Memory 48 GB
30 (0.01/day)
No but it seems like the security is upped when i drop my tweaks in I get a annoying bluescreen(lightblue not bsod, partial launch brick light bluescreen) on launch my tweaks are so lengthy that its gonna take a long time to halfsplit and narrow it down. Seems like sensitive registry tweaks or messing with system files may cause things to bsod or not work. It definitely feels faster, but I dont think its daily driver ready. Ive read they have cutoff all support for cpus older than nehalem because of instruction POPCOUNT says SSE4.2 and SSE2 are required now? Im about to get into all this had to reinstall 4 times now, the first install I got everything in only for it to bluescreen not of death i think its just a partial launch light blue screen on the final restart. Also it doesnt like when you delete the mcupdate dlls from system32 to get rid of those cancer cpu slowdown "spectre and meltdown mitigation" microcodes that I tweaked around to stop them from nerfing my older 4930K by 40% to force upgrades. Im not an windows internals guy but I suspect some subsystem they use for system file security has been increased if I had to guess, likely you guys could recall that faster than I can.
1 (0.00/day)
Processor AMD Ryzen 3600 (OC 4.4Ghz)
Motherboard MSI B450 TOMAHAWK MAX
Memory Crucial Ballistix 3000 XMP (OC 3733 MHz 16-19-14-36) 2x8GB
Video Card(s) ZOTAC NVIDIA Geforce RTX 3070 (undervolt 2000 mhz 950mv + 1000 mhz mem)
Storage 2x1 TB Seagate HDD, Kingston A1000 NVME SSD 240 Gb
Display(s) 1 - AOC 27" 165 Hz IPS, 2 - AOC 24" 75 Hz VA
Power Supply Chieftec PROTON 550W
Mouse Logitech G305
Keyboard Logitech G-PRO
Software Win 11 without bloat-shit
8 (0.00/day)
Code:
It's weird, I checked the error of the hash of nvltig.inf not being present in the catalog file and it is present and valid:
Code:
signtool.exe verify /v /pa /c C:\NV\Display.Driver\nv_disp.cat C:\NV\Display.Driver\nvltig.inf
Verifying: C:\NV\Display.Driver\nvltig.inf
File is signed in catalog: C:\NV\Display.Driver\nv_disp.cat
Hash of file (sha1): 2DF5A3A3970C9F04C77FC71BBB6839D797903D91
Signing Certificate Chain:
    Issued to: NVCleanstall Driver Modding Authority
    Issued by: NVCleanstall Driver Modding Authority
    Expires:   Wed May 23 00:00:00 2029
    SHA1 hash: 0ACD206E0B4018092E24BBDD185C2059B2DDEC0E
File is not timestamped.
Successfully verified: C:\NV\Display.Driver\nvltig.inf
Number of files successfully Verified: 1
Number of warnings: 0
Number of errors: 0
8 (0.00/day)
Unsure if this is related but I found this: https://x.com/thiojoe/status/1793694960174473464
When I check the official unmodded driver all of the inf files show a catalogue signature of 'Microsoft Windows Hardware Compatibility Publisher' and 'oem93.cat'.
When I check the modded driver none of the inf files show a catalogue signature.
EDIT: In case there was an issue installing the catalogue file I tried manually installing with signtool and the modded infs now show a catalogue signature, however installing the modded driver still fails with the same error:
Code:
112 (0.02/day)
System Name littlet
Processor Ryzen 5900X
Motherboard TUF GAMING B550M-PLUS (WI-FI) ZAKU II EDITION
Cooling EK AIO Basic 240
Memory G.Skill Trident Z RGB 4X16GB 3200MHz
Video Card(s) RTX™ A2000 12GB
Storage C: WD_BLACK SN850 1TB
Display(s) ViewSonic VX3276-2K-mhd
Case ASUS Prime AP201
Audio Device(s) Asus Xonar Essence STX II
Power Supply Corsair SF 600
Software Windows
"The normal driver from nvidia works fine" the clue you missed!
I would try restarting in safe mode then disable driver signing
Zorak
1 (0.01/day)
Yes, you're right you corrected the problem ! please disable driver signing for the installation, good job !
8 (0.00/day)
That's not fixing the issue, that's a workaround and I would assume not a long term solution for NVCleanstall.
The issue seems to be that that Windows is unable to see or accept the signed catalogue file or the file hashes within it.
943 (0.63/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
patience, my friend, wait till the final, it's half a year run:roll:
Nearest0858
1 (0.01/day)
This was confusing me for a long time, thought I was doing something wrong since I switched to Win11 from Win10. Good to know it's not an issue with my machine, hopefully it's fixed soon! Until then I'll go back to NVSlimmer.
W1zzard
Administrator
27,707 (3.70/day)
Memory 48 GB
Just don't use options that require the driver signature to be rebuilt and it should work fine? NVSlimmer doesn't even have such a feature
1,227 (0.51/day)
Processor AMD Ryzen 9 5950X
Case Cooler Master Cosmos
Power Supply Corsair HX850i
Keyboard Cherry MX
Just switched to Win11 24H2 build 26100.1000 and just found out the hard way that this doesn't work anymore. It's a shame, I've been using it for years.
EDIT:
So it's just the driver signing that's breaking this?
