- Jul 2, 2007
- 40,951 (6.56/day)
- Republic of Texas (True Patriot)
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Ok here is a discovery on the Windows Audio Service, which applies to Vista~11, maybe XP/2000. If you ever have a red x on the audio icon in the task bar and you know the audio drivers are installed, trying to fix it through windows troubeshooter typically fails.
1 way to fix is: Run services.msc
Try and start the Windows Audio Service, if it fails with a 1068 error, do not change any properties with it other than to autostart if not already.
Find RPC make sure it is Auto Start.
Find Multimedia Scheduler, Auto Start, Reboot System, that issue should be fixed.
Windows Audio Service depends on RPC and Multimedia Scheduler, do not disable them.
This was probably the 1 time I killed the multimedia service to get an APU rig to function smoother (low and behold AVAST became bloatware) which broke the audio output, ofc using blackviper.com windows services cleanup list. Just tread lightly
