[WIP] Lego Techinc PC Case With 3D Printed Parts
20 (0.01/day)
Slovenia
Hi! My name is Damjan and I want to show the World what I'm working on!
My current self-isolation situation is an excellent excuse to start a new project: A LEGO Technic built PC case! Because am not a person who could concisely modify a LEGO brick (there is a special place in hell for people who would), I decided to 3D print my own bricks which would serve as an interface between computer components and real LEGO bricks.
I expect two challenges:
  • Structural integrity: To properly mount and support heavy PC components I decided to build mostly with Technic bricks. I have quite some experience with that (I participate in LEGO Truck Trial races, Google it) so with some careful planning that should not be a problem.
  • Heat: My "production" (not prototypes) 3D printed bricks will be made out of the same material as LEGO bricks - the ABS plastic which starts deforming at around ~80°C. No computer component should reach this temperature, but I will make sure everything is ventilated properly anyway.
The heat is the reason I'm starting with PC fan mounts:
I also made some hard drive and SSD mounts:
And a PSU mount:
I welcome you to join me on this adventure! Updates will follow soon. Cheers!
20 (0.01/day)
Slovenia
Due to the World Pandemic I am still missing few things from AliExpress to continue my work. Because I am very impatient, I can't wait to show my progress, so here's a photo of the motherboard tray prototype.
The tray is designed to accomodate any (standard) sized motherboard. Mini-ITX? Just take the white 3D-printed brick. Micro-ATX? Add yellow. Full-sized ATX? Add orange.
Brass insert nuts are very secure. I was not able to pull them out after they set in. The surrounding PLA plastic broke first.
Cheers!
Inserting the nut video (external link to Instagram)
20 (0.01/day)
Slovenia
The work is slowly progressing. A prototype for the rear I/O panel is done:
20 (0.01/day)
Slovenia
That would require a lot of small bricks which could easily drop off when plugging/unplugging cables. I also think that there would still be some gaps which would not look very pleasing. I will continue with this design.
Cheers!
277 (0.13/day)
System Name Cheapskate Maximus
Processor Xeon W3680 @ 3.99Ghz [133x30] [1.375v]
Motherboard HP Z400 Rev 2
Cooling Alpenfohn Brocken v1
Memory 3 x 4GB DDR3-1600
Video Card(s) Sapphire RX570 Nitro+
Storage 240GB WD SSD, 6 x 2TB HDD
Display(s) 27" iiyama XB2783HSU AMVA+
Case AeroCool
Power Supply HP 600w Bronze (Delta)
Keyboard Gots keys
Software W10 x64
Nice work, can't wait to see it finished as a lot of Lego PC's tend to be a bit janky, but with some 3D printed stuff it looks like it's going to be a much cleaner build. :cool:
20 (0.01/day)
Slovenia
I found some time for my hobbies, so I have begun building the case in the virtual environment where I have an unlimited supply of bricks. I started with the bottom which needs to be perforated for better airflow to the power supply. Enjoy.
9,899 (1.69/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Love the concept
2,017 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
Amazing!
2,706 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Really clean job, videos/thumbnails/ regular updates. You went full swing with this one. Haven't been excited about a scratch build in a while, but I want to see this one finished. Do you think a build with lego in vertical orientation is possible? (like FT02B)? On a side note, Slovenia is a lovely place, been in Koper for three months or so...really beautiful aaand so much food ahaha.
20 (0.01/day)
Slovenia
Vertical orientation is possible, it's LEGO so why not! Will I ever build it like that? Who knows
20 (0.01/day)
Slovenia
After almost a year of planning, today I finally started the build! I found out that building in LDD and in real life is not the same. There are few things I already want to change (for structurual rigidity). I will continue with what I have for now and modify later. This is the front mesh.
Cheers!
834 (0.45/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
This is awesome, can't wait to see the final product!
