[Case Gallery] WIPB-2010/1
3,603 (0.65/day)
Oregon, USA
System Name GLaDOS
Processor AMD FX-9590 X8 4.7GHz
Motherboard ASUS Sabertooth 990FX
Cooling Corsair H80i v2
Memory Corsair Vengeance 24GB (2x8GB, 2x4GB) DDR3 1600 MHz
Video Card(s) ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Storage WD Blue 3D NAND 1TB Internal PC SSD
Display(s) 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand
Case Corsair iCUE 220T RGB Airflow
Audio Device(s) Onboard - Corsair Void Pro Wireless
Power Supply Corsair 850HXi 850W
Mouse Corsair Sabre RGB
Keyboard Corsair K70 LUX RGB
Software Microsoft Windows 10 Pro 64 Bit
Specs:
Processor: AMD Athlon64 X2 2.6ghz w/stock cooler
Motherboard: ASRock A780 LM
Cooling: 2 LOGISYS 80mm Purple LED Fans, 2 APEVIA 80mm Green LED Fans
Memory: G.SKILL 4GB 240-Pin SDRAM DDR2 800
Video Card: Sparkle NVIDIA GeForce 9500 GT
HDD: 1 Seagate IDE 160GB and 1 Toshiba SATA 160GB
CD/DVD Drive: ASUS SATA DVD-RW/CD-RW Lightscribe drive, IDE 16x Philips CD-RW/DVD reader
CRT/LCD Model: Dell E173FP (17" LCD)
Case: RAIDMAX OEM
Sound Card: Using onboard for now.
PSU: CORSAIR CMPSU-400CX 400W ATX12V V2.2 80
Software: Microsoft Windows 7 Ultimate 64-bit
Mods:
Removed the junk holes from the front of the case to allow more airflow for the intake fans. Added a fan to the heatsink on the 9500 GT. Replaced the normal mesh fan guard on the case side for a grill.
Still a work in progress, still needs two more HDDs, a new CPU cooler and a better graphics card. I also plan on taking a dremel to the rear fan's area, so I can use a less restricting fan grill instead of the junk drilled holes. This is going to be my LAN PC, as I'm going to build a new computer very soon for my new desktop/ongoing project.
