wiring home security cameras
Status
Not open for further replies.
Decaf
7 (0.00/day)
new york
Hi all, this is my first post, still new to this forum, anyways straight to the point i recently bought 4 security cameras off Craigslist in hopes of setting them up around my house, now before i go any further my goals are not to hook them up to a DVR system right away, at the time being i just want them so i can monitor my front/back door, and driveway from my room. i originally thought wiring these would be simple but it has proved to be a bit more then i can handle
the big guy has 4 wires, red, green, clear, and uncoated
the gold guy has 4 wires, red, black, yellow, white
the smaller one, under the big guy has 4 wire, red, black, yellow, and uncoated
and the last guy on the right has 3 wires, yellow, red, and uncoated.
any help getting these guys wired up would be very grateful .
OneMoar
There is Always Moar
8,796 (1.64/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
uhhh
need model numbers at the very least else nobody here is gonna beable to help you
396 (0.08/day)
System Name potato
Processor Ryzen 9 5950X
Cooling Custom WC Loop
Memory 2x16GB G.Skill Trident Z Neo 3600
Video Card(s) RTX3090
Storage 512GB, 2TB NVMe + 2TB SATA || 32TB spinning rust
Display(s) XIAOMI Curved 34" 144Hz UWQHD
Case be quiet dark base pro 900
Audio Device(s) Edifier R1800T, Logitech G733
Power Supply Corsair HX1000
Mouse Logitech G Pro
Keyboard Logitech G913
Software win 11 amd64
red red -> (+) power
not sure for the rest
red -> (+) power
black -> ground, usually for power
yellow -> video
white -> ground, probably for video
red -> (+) power
yellow -> video
uncoated -> ground, probably for video
red -> (+) power
yellow -> video
uncoated -> ground (for power+video)
you need to do some testing, those are based on my very limited experience - not guaranteed to be correct ;)
377 (0.05/day)
Easy way would be to use 9-12 volt ac/dc adapter for each camera. Red=positive, Black=negative. Then use the red, white, and yellow AV input to your TV set. You may have to cut the jacks from the AC adapters and RCA cables to splice into your camera wires. Test the yellow white and red AV inputs on your TV for video and audio. You should be able to monitor AV1 and AV2 , depending on your TV set.
OneMoar
8,796 (1.64/day)
Rochester area
Easy way would be to use 9-12 volt ac adapter for each camera. Red=positive, Black=negative. Then use the red, white, and yellow AV input to your TV set. You may have to cut the jacks from the AC adapters and RCA cables to splice into your camera wires. Test the yellow white and red AV inputs on your TV for video and audio. You should be able to monitor AV1 and AV2 , depending on your TV set.
uh no lets not make assumptions
377 (0.05/day)
So Right, more details necessary. Just a general idea of how 12v DC CCTV cams can be set up without a DVR.
Decaf
7 (0.00/day)
new york
thank you everyone for your replies, so im not planning on setting them up to a dvr just yet, at the time being id like to just use them to a monitor, i.e CCTV.
below are the model numbers and other info listed on each camera
USAG- model: US-BC-103 (varifocal DC lens)
power- dc12v NTSC
Ser No- M0603450
DSP- CM25WNVB-SH20/3.6
Power- DC12v 350mA
Unknown- Model- 627b
tv Type- NTSC
serial number- 758280600621
Digimerge- Model number- DCBHR1032b
Power- dc12v/ac 24v 200mA
Decaf
7 (0.00/day)
new york
so ive pretty much figured out how to wire everything, now anyone have any suggestions on what to use as a power supply? ive looked at RG59 Coaxial CCTV-Cam Cable, but thats a bit pricey. i think for my budget setup im going to setup power close to the camera and just run the video camera to my room. so i know i cant just wire them to a plug and stick it into a wall, so what should i be looking for? they are all dc 12v, does the mA difference matter? any particular adapters i should be looking for or can i just hack an old 12v dc plug and use that?
1,205 (0.19/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
Milliamps must be same or greater
1,205 (0.19/day)
Hampton Roads
Cooling Fans
Storage small ssd
Case Lian Li
Power Supply X750
Would stress it a bit methinks. An old external hard drive brick is usually good for a couple amps.
Decaf
7 (0.00/day)
new york
okay so the closer i can get to the mA's the better, over is okay but under wont work. makes sense.
Decaf
7 (0.00/day)
new york
update
UPDATE- got one camera up and running, thanks for everyones help, think i got the hang of it, going to start installing the other three in the next couple days
Morkel
7 (0.00/day)
If you have a model than try to see some review on that camera security system.Hope you get some help there.That how exactly you install that cameras.And also you can find many pictures there that how you can connect and create a network with that cameras.
Status
