Worth Upgrading Monitor? Dell 2407WFP
85 (0.02/day)
Sydney, Australia
System Name Monster Gaming PC
Processor [Intel] Core i5 3570K
Motherboard [ASRock] Z77 Extreme4
Cooling [Cooler Master] Hyper 212 EVO
Memory [Corsair] 8 GB (2 X 4 GB) Vengeance Low Profile
Video Card(s) [ASUS] GTX 670 OC 2GB (GTX670-DC2OG-2GD5)
Storage [WD] Caviar Blue 1TB SATA III 7200RPM
Display(s) [Dell] UltraSharp 2407WFP (24" 1200x1920)
Case [CM Storm] Scout 2 Black
Power Supply [OCZ] ZT Series 750W
Software Windows 7 Ultimate,
I was wondering whether or not I should upgrade in the future. I currently own a Dell 2407WFP (anandtech.com review/spec). It uses a S-PVA TFT LCD panel, with a 1920x1200 resolution in a 24" size. In 2006, it would've been a beast of a monitor. Today, it would be considered decent/alright for professional use. Unfortunately, I am no professional. I am a gamer! Yeah, I multitask and occasionally touch Photoshop, but I mostly play games to kill time. That means I should like small response times, (where affordable) high refresh rates and 16:9 ratios. But is it actually worth swapping a working 1200p monitor for a smaller gaming monitor. Will I notice the response time difference? Will I notice colour inaccuracy from a TN panel?
1,374 (0.36/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
Go with an overclockable 27 incher and steer clear of downgrades to shotty monitors.
85 (0.02/day)
Sydney, Australia
Are you referring to a Qnix QX2710. I don't think my GTX 670 can handle 1440p and an IPS panel means poor response time and limitations to the Max OC, which can only be 80-90Hz in some situations. Also to mention they still aren't too cheap. Did you have any other monitors in mind when you said 27" overclockable?
What exactly is a shotty monitor?
Norton
Moderator - Returning from the Darkness
14,108 (3.00/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Dell Ultrasharp's are great monitors, I have/had a few of them- If you're happy with it than stick with it.
Otherwise, consider the newer monitors with LED backlights since they use 50% of the power that our older Ultrasharp's use! ;)
1,374 (0.36/day)
Display(s) PG348Q
Case Core X71
Korean panels in general. IPS doesn't mean poor response time at this time and date at all as pretty much any IPS comes way below 16ms which is more than fine even with input lag and other factors added in, and when 60 HZ is fine why are you concerned about 80-90 HZ? You do realize 80-90 HZ is pretty impressive for an LCD, right?
That said they obviously aren't too cheap yes. There are other Korean monitors around like Kogan which you can find in Australia.
Crap.
Kursah
Super Moderator
14,717 (2.23/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I have an IPS from at least 2 years ago, with a higher measured G2G response time (most of the advertised responses are grey to grey)...good luck noticing any real difference. I believe mine is rated at 8ms, and comparing A|B to my 2ms Asus TN panel, I notice no issues in lag/ghosting/anything "feared" about IPS being slower. Even comparing my Asus to my Samsung 1080P IPS 32" TV I noticed no issues with lag. I think people find it convenient to forget that 100ms is 1/10th of a second. So being less than 1/100th of a second is going to be pretty damn tough to perceive...even for those that proclaim to be more sensitive to such things. This is my experienced opinion from years in this field, take it with a grain of salt, but understand too many people get too picky about the little aspects, the extra BS that you'll use or play with or "try" to notice for the first short time you own that piece and then it's just a visual utility to access your PC again. The extras you want now won't matter in two weeks beyond bragging rights.
Modern monitors are very impressive, 60Hz is good for me...I don't need 3D nor are worried about modern sync technologies yet...too new. Dell monitors are pretty damn good in this market. There are plenty of options, you need to go with the one that works best for you...it's tough should you not be able to test them at a storefront. In that case I would recommend Dell monitors in the IPS class hands down just because of my years of experience with them. Many LED TN panels are good too if you feel you must have the fastest of fast response times. It's really tough to go wrong right now imho.
:toast:
Deleted member 24505
I'm still using my Dell 2405WFP and it is still a fine monitor, i use the component inputs to connect my pioneer dvd player too.
85 (0.02/day)
Sydney, Australia
Kursah. Thanks for that massive explanation on noticing response time difference. My main incentive for a change in monitor is the use of 1080p over 1200p, as it is a much more universal resolution, gives me better FPS and recordings fit on the display of almost everyone else. Not entirely that I hope to go from 6ms to 1ms.
My main point is that a single GTX 670 can't handle 1440p to the point where it looks worse than 1080p due to the turned down settings + AA. AA is still necessary at 1440p, unfortunately. 1440p would've been a good idea if I had a 7970/280X/290(X). I will probably need a 2nd card for it to run well, which means an extra $200-300 spent.
At $350 I could buy one of those 120hz BenQ 24" 1080p instead.
Yeah. I use those component ports for a JTAG Xbox 360. Hopefully any future replacement monitor may have HDMI
1,374 (0.36/day)
Display(s) PG348Q
Case Core X71
I ran a single 680 with an U2713H, and it ran many games well, so your assumption of 670 not being able to handle 1440p is not completely true. Besides, it's not all about games.
And after all it's your money. You can rather buy a frankly, shitty BenQ with a TN panel or an overclockable IPS 27 incher. And they don't sell for much more than $350, in fact, they pretty much sell for that much but I'm not entirely grasped on their Australian prices.
85 (0.02/day)
Sydney, Australia
Look! I absolutely love 1440p! It is my favourite resolution as it is the balance between quality and performance when powered by the higher end rigs. Unfortunately, I am already struggling to run games on ultra with AA at 1200p. I cant run a variety of games maxed these days. The future will only mean lower FPS. I dream of owning a 4K or QHD setup, but my wallet doesn't allow me. This thread was more to ask if I need upgrading than actually give me serious monitor suggestions. I feel that I need a 2nd card or go team red to be able to power games at BETTER quality with a similar FPS.
I feel that 1920 based resolutions already provide the pixels for my multitasking anyway.
414 (0.09/day)
brčko dc/bosnia and herzegovina
System Name windows 10 pro 64bit
Processor i5 6600k 4.4ghz 1.25v
Motherboard asus maximus viii gene
Cooling BeQuiet Dark Rock pro
Memory 2x8(16)GB 2860mhz
Video Card(s) gtx 1070 EVGA
Storage ssd x2 128gb raid0/ ssd480gb
Display(s) AOC 1440p 75hz
Case Aerocool DS Cube
Audio Device(s) asus motherboard intergrated
Power Supply be Quiet pure power L8 600w
Mouse Corsair Ironclaw wireles
Keyboard Logitec G213
Software my favorite World of Tanks :) is that a software?? :)
i think you already made your mind!!if you want it buy it,its that simple,if you cant afford it dont think about it!!
i have the same monitor,and realy old gpu(hd 4890) and i have hard time playing games at 1200p,but gtx 670.. i mean come on ...stop bulshiting
my bro have gtx 660 ti and have no problem playing most games play at FHD and max setings and playable FPS
what else you want...
