WTF is this FAN header?
3,394 (0.60/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
I bought a "microPC" device as a pfSense appliance. It gets hot though, and needs a FAN on top of the case. There are headers on the board, but I cannot figure out what the hell they are. I originally thought they were the small ones graphic cards use, but they are actually about half that size, maybe 5mm or a little less.
What I bought is this: https://cwwk.net/products/cwwk-x86-...irewall-pc-2x-i226-v-2-5g-lan-fanless-mini-pc
Can anyone tell what connector I need for this? To be more specific, I need a reduction from this to regular 4pin PWM connector.
de.das.dude
Pro Indian Modder
9,174 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
did they not provide any wiring harness that fits there?
looks like it has enough for PWM, so maybe get a voltmeter and try to figure out which pin is which. Or remove the heatsink and look at the PCB, it should be marked.
3,394 (0.60/day)
Czech republic
No, it's China. There aren't even any BIOS updates.
I need to identify what the fan header is so I can buy a connector/reduction.
2,993 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Looks like a GPU fan header to me.
3,394 (0.60/day)
Czech republic
No it's not. The perspective makes it look that way though.
This is GPU FAN header:
The header on the motherboard of the device is about half the size. I've never seen anything like that. I guess it's not used in PCs.
2,993 (2.04/day)
Germany
well then contact the vendor/manufacturer.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
That is whack it's laptop pwm header hehe
3,394 (0.60/day)
Czech republic
Oh so that's what it is!
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
Yeah good luck finding a fan that will work on it
Might just try for a molex/ sata connector fan setup ?
Small device so maybe it's small enough to use a laptop fan in it ?
3,394 (0.60/day)
Czech republic
Well no, I need a reduction for it (and I said that in the first post!). I already have a suitable fan, but it's a classic case fan obviously.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
Okay I see
Yeah that 4 pin is so weak they offer the usb fan addon
3,394 (0.60/day)
Czech republic
What do you by mean weak?
I do currently use the USB fan, but it's noisy AF and can't be regulated, which is why I'm trying to find a way to connect a regular one directly into the motherboard.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
The 4 pin port you're asking about is weak this is why the manufacture used a usb for the larger fan for more power
You could how ever ghetto rig a fan controller to it so you can use the new fan or the existing one.
820 (1.30/day)
System Name Naboo (2019)
Processor AMD 3800x
Motherboard Gigabyte Aorus Master V1 (X470)
Cooling individual EKWB/Heatkiller loop
Memory 4*8 GB 3600 Corsair Vengeance
Video Card(s) Sapphire Pulse 5700XT
Storage SSD 1TB PCIe 4.0x4, 2 TB PCIe 3.0
Display(s) 2*WQHD
Case Lian Li O11 Rog
Audio Device(s) Hifiman, Topping DAC/KHV
Power Supply Seasonic 850W Gold
Mouse Logitech MX2, Logitech MX Ergo Trackball
Keyboard Cherry Stream Wireless, Logitech MX Keys
Software Linux Mint "Vera" Cinnamon
It seems to be a JST-XH connector
3,394 (0.60/day)
Czech republic
I don't think you have the slightest idea what are you talking about.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
de.das.dude
Pro Indian Modder
9,174 (1.71/day)
VR HMD ;_;
get a pwm fan 5v, and hotwire the pwm signal from that mobo header onto that. are you even sure that the header is PWM enabled and not just for show?
820 (1.30/day)
Processor AMD 3800x
Display(s) 2*WQHD
You're right. This header is i.e. used at 3D Printers. One can get SunOn fans with that header. Ranged from 5 to 25volts. Afaik also Noctua uses this header. 4Pin means that the fans are PWM. 3Pin is a voltage controlled speed. AFAIK the fans connected to a mainboard are 12v.
2,798 (6.34/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
There ARE 2.54 to 4-pin FAN adapters from what I can see on Ali and such that are compatible with XH, so you might try your luck there. Whether or not the port on your particular device will carry the PWM signal is a mystery, to my knowledge there isn’t actually any official spec for how PWM is implemented on XH connectors, so despite being 4-pin it might NOT have it, contrary to what one might think.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
820 (1.30/day)
Processor AMD 3800x
Display(s) 2*WQHD
3,394 (0.60/day)
Czech republic
Thinking the same about you mate hehe
Just add a controller to the usb fan dude.
Claiming a fan header is "weak" by just looking at a picture while not even being able to type coherently in your own native language is certainly reasurring sign that it's me who is clueless here :kookoo:
Aha! Adapter was the word I was looking for, lol.
I'll check Ali.
2,259 (1.00/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
i dont know if this will help but i thought id mention it.
i use one of these with my x99 board from china cus ive only one pwm fan header.
it has a switch high/low/ and off. i run it on low which is about 700 rpm so quiet.
mines 3 pin but thay do 4 pin as well i got it off ebay for £4 shipped.
9,340 (5.14/day)
Louisiana
Keyboard G710+x3
Dude the manufacture didn't even use it but instead the manufacture uses a usb port for a fan
This is what you're not able to understand
Contact the manufacture and ask.
820 (1.30/day)
Processor AMD 3800x
Display(s) 2*WQHD
