X370 Fatal1ty Professional vs cheapest X570 for Ryzen 3000 ?
X370 Professional vs entry lvl X570
  • ASRock x370 fatali1ty pro
    Votes: 4 28.6%
  • Entry level x570
    Votes: 10 71.4%
  • Total voters
    14
7,412 (2.90/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
what to choose ?
X370 Fatal1ty is 780pln here vs 750 pln for the cheapest x570s (X570-A Pro/Phantom 4)
It's a high end board with beefy vrm,quality onboard audio,debug led and all the bells and whistles.It's x370 though,so I don't know.
People who just wanna crap on one brand or praise another (gigabyte is shyte,asrock is great) need not respond.Please keep this discussion within the thread topic in relation to these particular boards.
3,056 (1.70/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (378W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
Ryzen 3000 ? (5/7/9) I dont think that either board can handle all Ryzen 3000. The R5/7 3600/3700X (65W) probably yes.
And I dont have a clue about the X370/Ryzen 3000 compatibility of that specific board.
And are you talking about the MSI X570-A Pro?
I would stay away from that board unless is for a R5 3600
the54thvoid
Intoxicated Moderator
12,695 (2.38/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
How does the Fatality stack up against the Asus CH6 X370?. I have the latter and I have a 3700X running quite well. I know my board's BIOS takes the 3900X. I think the best bet is to check with the ASRock support page for CPU compatibility.
HTC
4,638 (0.78/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
OP: check this and see if your board is listed.
EDIT
This is the wrong spreadsheet: there was one where they tested the 3900X for compatibility but i can't seem to find it :(
4,068 (0.58/day)
System Name RiseZEN Gaming PC
Processor AMD Ryzen 7 5800X @ Auto
Motherboard Asus ROG Strix X570-E Gaming ATX Motherboard
Cooling Corsair H115i Elite Capellix AIO, 280mm Radiator, Dual RGB 140mm ML Series PWM Fans
Memory G.Skill TridentZ 64GB (4 x 16GB) DDR4 3200
Video Card(s) ASUS DUAL RX 6700 XT DUAL-RX6700XT-12G
Storage Corsair Force MP500 480GB M.2 & MP510 480GB M.2 - 2 x WD_BLACK 1TB SN850X NVMe 1TB
Display(s) ASUS ROG Strix 34” XG349C 180Hz 1440p + Asus ROG 27" MG278Q 144Hz WQHD 1440p
Case Corsair Obsidian Series 450D Gaming Case
Audio Device(s) SteelSeries 5Hv2 w/ Sound Blaster Z SE
Power Supply Corsair RM750x Power Supply
Mouse Razer Death-Adder + Viper 8K HZ Ambidextrous Gaming Mouse - Ergonomic Left Hand Edition
Keyboard Logitech G910 Orion Spectrum RGB Gaming Keyboard
Software Windows 11 Pro - 64-Bit Edition
Benchmark Scores I'm the Doctor, Doctor Who. The Definition of Gaming is PC Gaming...
I have the ASRock X370 Fatal1ty Gaming motherboard. The only issue I had was with my sound card. I ended up buying an external card and all works well. A new bios update was released which fixed the onboard sound card. But now my Ram is having a difficult time running stock 3200MT/s since this bios update. Hmmmm, hopefully they release another bios to resolve this ram instability issue when trying to run it stock.
ASRock Fatal1ty X370 GAMING X - Bios Issues
what to choose ?
In answering your question, I would go for the cost effective X570 mobo so you can take advantage of the new ZEN2 features.
7,412 (2.90/day)
Poland
Cooling Noctua D15S
What features? If you mean PCI 4.0 I hope you're doing it in jest.
Thanks for the input.that's quite a number of issues.
@the54thvoid CHVI is more expensive,would rather buy faster ram.
10,367 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
if they're both about the same the x570 would probably sell better when you're ready to upgrade. also less of a pain in the butt to setup/flash; you just buy it and pop in the chip. Im not sure if the x370's come flashed ready for the 3000's.
6,118 (2.84/day)
California
System Name His & Hers
Storage lots of SSD.
I would just save up for the Asus Tuf X570 as it seems to be by far the best sub $200 X570 board and handles the 3900X with ease.
7,412 (2.90/day)
Poland
Cooling Noctua D15S
That is true.
But x370 has better vrm,better build quality and features too. It all matters in resale.flashing costs pennies here.
11,878 (2.26/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
what to choose ?
X370 motherboards don't seam to respond as well to bios updates for memory support ,on the few i have messed with.
In that on x470 and 570 getting your memory to and beyond 3200 is very easy on second and third gen ryzen chips where the X370 board's even with a later chip including inbuilt memory controller and a bios update they struggle to clock memory high, likely due to memory layout or something.
I would go x570 if buying a board.
138 (0.02/day)
Türkiye
System Name Revenge of the Strix
Processor Ryzen 5800x3d
Motherboard Asus Strix-e x570
Cooling Corsair H150i pro xt
Memory Crucial Ballistix 32 GB DDR4 3600 MHz CL14
Video Card(s) Red Devil 7900xtx
Storage Adata S50 1tb gen4 - WD Black 1tb gen3 - Seagate2tb SSHD - WD 2tb
Display(s) Dell G3223Q
Case Asus Helios
Audio Device(s) X-fi + Bose Companion 50
Power Supply Seasonic Focus GX 750w
Mouse Asus Pugio II
Keyboard Asus Falchion
buy cheap asus x570.prime pro is very good but if you can't afford it you can buy asus prime p.don't buy msi or asrock x570 series.bios is important and asus good about it and also i like my board's vrm and i don't think prime pro also p is bad.not too bad at least.it's x570 can't be bad because amd asked it to be good.sorry my bad england i'm bipolar you couldn't understand me even you can speak Turkish and this message was Turkish.:p
7,412 (2.90/day)
Poland
Cooling Noctua D15S
Sorry,but you're not talking to somebody that can take this as a serious piece od advice.
Also,your English is not that bad ;)
3,056 (1.70/day)
Asus Prime X570-P is one of the best budget board in VRM perspective, as shown in benchmarks.
3,881 (0.87/day)
All i got out of that video was use common sense. Whos going to run their system with no airflow with PBO+Auto OC on a chip allowing it to use 190w / 290w.
He even says that providing air flow throttling shouldn't be an issue on the worse board at 80c. He states throttling didn't happen until 115c.
11,878 (2.26/day)
Manchester uk
VR HMD Oculus rift
Plus i guarantee ,if you buy the x370 within a few months you will regret not owning the 570, Imho.
3,056 (1.70/day)
Throttling is out of discussion of course!
Personally I wouldn’t like to see my board working in high temps... not when there are way better solutions. This video indicates that there are boards that do the job but with poor solutions, compared to others.
Why anyone would want to get the job done this way and not choose something more safe within the same badget? I don’t understand it.
In the same conditions 1 board’s VRM working at 110+ degrees and on another at 60~70. Same price point, same performance, same level of features...
Higher VRM temps meaning lower power capability or/and lower component quality and efficiency or/and insufficient heatsink/cooling =cheap/cheapest implementation.
What board would you trust to hold your investment in the long term? What board is seem to you more reliable in terms of power delivery?
On the same topic: Why almost everyone has waited for aftermarket RX5700s. Isn’t it because of the thermals mostly?
This all has nothing to do with brands. The last 20 years I have use lots of different brands. MSI, Asus, Gigabyte and more. I’m not a fanboy of anyone.
3,881 (0.87/day)
Higher temps in VRM mean lower power capability or/and lower component quality and efficiency =cheap/cheapest
What board would you trust to hold you investment in the long term? What board is seem to you more reliable in terms of power delivery?
I doubt someone spending $500 on a CPU planning to turn on PBO to its max settings pump an additional 50+ watts is going to want to skim on a board. Not to mention the cooling will probably eclipse the price of these entry level X570s. People who were paying attention already had the list of level1 as a guide to VRMs. The video just puts it in a worst case scenario.
1,327 (0.38/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | QKZ x HBB
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Windows 10 Education 22H2 x64
Just get a X470 board. 1st gen Ryzen boards had/have memory issues. I know some will say is 1st gen Ryzen IMC but if that was the truth board makers wouldn't make a big deal of detailing good updated memory tracing for better memory support with their X570 boards.
My problem with X570 is that fans are already starting to fail for some people.
3,056 (1.70/day)
I doubt someone spending $500 on a CPU planning to turn on PBO to its max settings pump an additional 100 watts is going to want to skim on a board. Not to mention the cooling will probably eclipse the price of these entry level X570s. People who were paying attention already had the list of level1 as a guide to VRMs. The video just puts it in a worst case scenario.
You are not really answering my question... but then it is you right not to.
“What would you choose between those two boards if you those where your only options, and why?”
As I said there are on the same price point.
The worst case scenario shows the weaknesses. To me this is important...
The OP asked for opinions and I said mine, and tried to back it up with facts. And the fact is that some boards is worst than others, at the same cost.
And yes, if some one just wants raw power without any high end features... can do it by sticking a 500$ CPU on a sub-200$ X570 board... if... he chooses the right board.
And I think... I did say it at my first post that those boards are probably ok with the lower 3000 CPUs. But yet again there are some that can drive even the high end ones with out issues. And yes, with the same cost...
3,881 (0.87/day)
Between the X570-A Pro & Phantom 4. The X570-A Pro. The layout PCIe top location, NVMEs and chipset fan isnt blocked. I would stick to a 65w chip 3700X or lower. Most you'll deal with is 125w even if you want to PBO+Auto OC instead of 290w.
3,056 (1.70/day)
I ment between the MSI X570-A Pro and the Asus Prime X570-P (The first and the last in that VRM comparison) but ok, that did answer my question!:)
7,412 (2.90/day)
Poland
Cooling Noctua D15S
I just checked the price of X370 Taichi (same as fatal1ty,different color scheme) and it's even cheaper,can be bought from legit retailers for 720 pln.Isn't it a better buy than entry level x570 that costs 750pln ?
I'm very confused with the poll.People seem to only care about the chipset,not even looking into components.
138 (0.03/day)
Processor 5700X
Motherboard ASRock Gaming X
Memory 2x8 3600 CL14
Video Card(s) 1080 SEAHAWK
Display(s) ViewSonic XG2703-GS
I have a Gaming X and I'm in the same condition, I want good oc capacity (mainly memory because I think CPU oc is almost the same everywhere) and good audio if I upgrade for a 3x00
I think I will not go for a second X370 but more for a X470 since I will be able to have better speeds (currently at 3300 MHz with a R5 1600) and cheaper/same options as new X570
I'm considering the Taichi too but it's still expensive except so I will see if I can get a good deal somewhere
