X670E motherboard, should I get TUF or Strix?
3,352 (0.62/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Hello,
I am wondering if any of you have experience with any of these motherboards.
Which one is better to get? Strix costs 70 euros more.
dgianstefani
TPU Proofreader
4,989 (2.00/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
It doesn't matter.
Zen 4 doesn't OC enough for motherboard tiers at this range to be a difference worth paying for.
Buy the one that has the IO you want.
3,352 (0.62/day)
Case Zalman S2
It doesn't matter.
Does the WiFi version also include Bluetooth?
dgianstefani
TPU Proofreader
4,989 (2.00/day)
Swansea, Wales
System Name Silent
142 (0.11/day)
System Name Upgraded CyberpowerPC Ultra 5 Elite Gaming PC
Processor AMD Ryzen 7 5800X3D
Motherboard MSI B450M Pro-VDH Plus
Memory CM4X8GD3000C16K4D (OC to CL14)
Video Card(s) XFX Speedster MERC RX 7800 XT
Storage TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB
Display(s) AOC Agon AG241QX 1440p 144Hz
Case Cooler Master MasterBox MB520 (CyberpowerPC variant)
Power Supply 600W Cooler Master
I wouldn't buy either of them until the SoC voltage problem which is blowing up Ryzen 7000-series CPUs on some ASUS motherboards is confirmed to be fully resolved.
You would probably be fine as long as you make sure you update your BIOS to the latest version, as these problems are supposed to have been fixed in new versions released a few days ago, but I would recommend waiting another week or so in case it turns out the problem isn't properly fixed. If you buy one of these motherboards new today (2nd May), it is very likely it will come with a defective BIOS which could damage your CPU if you enable XMP or EXPO.
Similar problems have been seen on Gigabyte motherboards, but ASRock and MSI motherboards do not seem to be affected.
Aside from the voltage issue, in my opinion the Strix is only worth buying if you're really into overclocking with exotic cooling. The TUF's 14+2 70A power stages are more than enough for a heavily overclocked Ryzen 9 7950X with a high-end tower or AIO cooler. The Strix has 16+2 90A power stages, which could help with overclocking if you're using dry ice or a high-end TEC or water chiller, but won't really matter for normal PCs.
The Strix has 2 extra rear USB ports, and some of its USB ports provide more bandwidth, but the 10 ports of the TUF is already enough for most people. The TUF also has an extra header for front USB ports.
The Strix has a slightly better audio codec/soundcard, but the difference is unlikely to matter except to audiophiles and professionals, and most of them would use external soundcards anyway.
Other than that, the features of these 2 motherboards are basically identical.
Both motherboards include WiFi 6E and Bluetooth v5.2.
Strix has never been a brand for people who want good value, it's for people who want overkill cooling and RGB.
X670E itself is also a waste of money if you won't use the extra PCIe lanes that it provides over B650. Even if you really want support for PCIe 5.0 in both your main M.2 slot and GPU slot, you can get that from much cheaper B650E motherboards like the ASRock B650E PG Riptide WiFi, which has a similar VRM and the same number of rear USB ports (albeit most of them are low-bandwidth USB 2.0 ports) as the X670E TUF. Fewer PCIe lanes means it only has 3 M.2 slots rather than 4, and one of its M.2 slots is only PCIe 3.0 x2, but 3 M.2 slots and 4 SATA ports is still plenty of storage. The ASRock B650E Riptide also has the upside that using the wrong BIOS won't make your CPU explode.
142 (0.11/day)
Update: ASUS did not deal with the problem well.
3,195 (1.66/day)
Memory Micron DDR4-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1
Power Supply Corsair RM750x
Mouse Logitech M575
With the current issues (with ASUS in particular) I'd wait until some independently confirmed fixes are working on ASUS boards or consider alternative if you need a board sooner rather than later.
3,352 (0.62/day)
Case Zalman S2
Because of these issues and because I have a 3080, I ended up skipping the entire generation. Will wait until next year.
41,826 (6.61/day)
I would say neither and Look at AsRock
6,509 (4.63/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Assuming your system specs are up to date, your motherboard isn't too terrible... why not just purchase a 5800X3D? You even have 32 GB of RAM already. Won't owe anything to a socket AM5 PC for games.
3,352 (0.62/day)
Case Zalman S2
Yeah that's what I am thinking.
6,509 (4.63/day)
São Paulo, Brazil
IMO you should do it. You won't regret it. Maybe seek out a more feature rich AM4 board in the medium term, as more folks buy into AM5 or Intel platforms, you may find a good deal on a high end X570. But for now, just grab a 5800X3D and enjoy. Keep the rest in your wallet :)
Toothless
Tech, Games, and TPU!
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Maybe nab a better CPU cooler at some point too.
6,509 (4.63/day)
São Paulo, Brazil
Yeah, I agree. 5800X3D plus a decent heatsink and you just spent less than a good socket AM5 motherboard would cost, and you'll be playing all the latest games just as well. Little point in a X670E + 32 GB of good DDR5 + a 7800X3D when you can save hundreds of bucks by just doing that.
Ruru
S.T.A.R.S.
12,545 (2.89/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
18,585 (2.70/day)
System Name AlderLake
Better go intel than AM5 with an Asus board at this time....
579 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Yeah, I wouldn't touch an AM5 board ASUS/Gigabyte at this time.
11,878 (2.22/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
945 (0.54/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Between the two, I would go for Strix.
Btw, why not MSI?
52 (0.02/day)
Asus will fix their BIOS problems soon enough. People are just on the bash train because of the recent video from Gamers Nexus. There is already a beta BIOS available which lowers SoC voltage and an Asus representative has told to Finnish tech media outlet io-tech that they will provide warranty if anything happens using a beta BIOS, at least in Scandinavian countries, so the disclaimer on Asus support page is nothing to worry about, in fact, it has been there whenever Asus has released a beta BIOS, no matter the socket.
My advice on mobo purchase: Buy any decent looking AM5 board other than the very entry models and Asus Prime B650, based on what IO you need. Almost every board has adequate or even robust VRM, no matter which of the four major brand it is. Especially those X670 boards are all very high quality, or perhaps overkill rather, as far as I know.
EDIT. clarification
8,969 (3.31/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
41,826 (6.61/day)
My advice on mobo purchase: Buy any decent looking AM5 board other than the very entry models and Asus Prime B650, based on what IO you need. Almost every board has adequate or even robust VRM, no matter the manufacturer. Especially those X670 boards are all very high quality, or perhaps overkill rather, as far as I know.
Nice assumption there because I overlooked Asus during the AM4 days due to them butchering the TUF line and overpricing the ROG line.
