X86-P6: Ultra-compact NAS Unveiled With Four M.2 Slots and Dual 2.5G Ethernet
GGforever
147 (1.28/day)
The X86-P6 is a freshly unveiled mini PC that primarily aims to function as a NAS or a local backup. The system is powered by up to an Intel Core N355 processor, sitting at the top of Intel's Alder Lake-N product lineup. Packing 8 cores and 8 threads, the N355 is no small fry and packs enough computing grunt to push through moderately intensive workloads without an issue. However, the primary selling point for the system, unsurprisingly, is its storage at networking capabilities.
With dual 2.5G LAN, the X86-P6 packs enough networking prowess for a small home office or backup setup. The system also packs four M.2 2280 slots - albeit limited to only a single PCIe 3.0 lane (1 GB/s) per SSD when utilizing all the SSDs, which should theoretically be enough to saturate the system's networking capabilities. Apart from the LAN, the system also sports dual HDMI 2.0 ports, dual USB 3.2 Gen 2 ports, as well as an M.2 B-key slot for wireless network modules.
The system packs a single SO-DIMM slot, good for up to 16 GB of DDR5-4800 memory. At just 6.7 x 6.5 x 5.8 inches, the X86-P6 is undoubtedly impressively compact, which isn't all that surprising considering the modest internals. As for pricing, the X86-P6 is available on Amazon at a starting price of $198 for the barebones version with an Intel N100 CPU, and $480 for the high-end variant with the Core 3 N355 CPU.
483 (0.25/day)
CPU support up to 16GB! Must correct your misinformation.
Intels spec sheets are often wrong or outdated. Case in point: X58 being able to run 6x8GB.
As long as the higher density dimm are electrically compatible you should be good to go. This means things like voltage, rank, and so forth
You are correct. Fixed!
Technically the spec sheet says that but they are already doing pre-orders with higher ram amounts.
It was the same thing with the N305, you can currently buy 32gb and 48gb variants
GGforever
147 (1.28/day)
I know. But I know certain N100/150/305 systems with 16+ GB RAM that have occasional stability issues.
So, there. Not ideal in a NAS, best to stick to official specs.
3,828 (2.55/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Aliexpress sells configurations with up to 32 GB of RAM. Maybe the manufacturer has tested the larger SO-DIMM too and it works.
The manufacturer appears to be "CWWK", and here's the product page:
3,828 (2.55/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
4,179 (0.94/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
So close, if only it had 10Gbps ports...
4,179 (0.94/day)
Processor 5800x3d
Mouse *squeak*
Software Manjaro
single pcie 3 lane lol, so wouldve bottlenecked hard
First- you're giving up 2/3rds of your bandwidth to use 2.5 Gbps ports. So I'd much rather hit a 1GB/s bottleneck then a 312MB/s bottleneck.
Second- it's x1 lane PER DRIVE, a total of 3.0x4 lanes. that is 4096MB/s, 4GB/s. It could saturate not one but TWO 10Gbps ethernet ports at the same time.
"You can get PCIe 3.0 x4 speeds if you remove the breakout board that gives you four M.2 2280 slots and just use a single SSD. But if you want to use four SSDs you’ll be limited to PCIe 3.0 x1 speeds."
The writing is very poor. The backplane is fed with a 3.0x4 connection which then gets split up among installed drives. They're not feeding all 4 ports with a single lane.
It's BS that all these flash based NAS units sacrifice all their bandwidth. Even a basic SATA III SSD can saturate a 2.5Gbps port. Why is it only aSUStor with their overpriced gimmicks can reliably make 10Gbps NAS units?
14,392 (6.47/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Not too expensive, either. Nice! :)
2,488 (1.17/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
AFAIK, X550 and X710 are pretty spendy to integrate. (Both of which have optional 10G+5G/2.5G/1G 'multi-gig' support)
Given the lacking consumer-facing options for 10GBASE-T, I think dual (Realtek) 5gbps ports would've been appreciated (and more-widely compatible)
Hold up. I've been looking for a device like that for awhile.
Closest I've found is a Viking Enterprise Solutions U20040-02 U.2 Gen3x4 -> 4x M.2 Gen3x2 expander. 1739320882697.png1739320908066.png
'Never seen x1/x1/x1/x1 bifurcation before, so I assume they're using a cheap ASMedia gen3 switch.
(They are, I can see it in the pic).
100% :rockout:
NVME-based NAS doesn't even begin to make sense without at least Dual Port 5GBASE-T.
4,787 (0.94/day)
Even Terramaster F8 comes with 10Gbps NIC out of the box.
1,081 (0.17/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
>M.2 SSD NAS
>only dual 2.5Gbps LAN
Why people creating things like this???
GGforever
147 (1.28/day)
Yeah, true.. but not if you are utilizing a single ssd though.
I mean, yeah dual 10G wouldve def be nice.
But at this price, do we really expect people to have 10G networking at their home?
1,081 (0.17/day)
Hungary / Budapest
System Name Kincsem
I see, and then it is kind of pointless that way :toast:
246 (0.14/day)
I don't see it as pointless, one just needs to keep in mind it's limitations. Sure it can't compete with a full server NAS, but this is MUCH smaller and with no spinning drives, more durable. This would make a great on-location NAS for a photographer or video dumping machine.
3,828 (2.55/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
And it would be able to run on battery. Unfortunately the manufacturer hasn't thought of that but it still wouldn't be difficult to connect it to a ~100 Wh power bank for a few hours' runtime.
