Xeon 2683 V4 Wattage problem
Kasy21
9 (0.03/day)
So I recently bough a xeon proccessor and an aliexpress motherboard, I know it is aliexpres but using hardware info it shows that under load( Cinebench R23 Multi thred) is only using 20W and I don't know why I tryed to change some things in the bios about the power managment and it still did not use more than 20W and is a good 1GHz under what it should be.
My system consist of:
Xeon 2683 V4
Machinist MR9S
Kingston Fury DDR4 32GB 3200 Cl16
Thermalright pearless assasin 120
860 (0.60/day)
System Name ASUS TUF F15
Processor Intel Core i5-10300H
Motherboard ASUS FX506LHB
Cooling Laptop built-in cooling lol
Memory 24GB @ 2933 Dual Channel
Video Card(s) Intel UHD & Nvidia GTX 1650 Mobile
Storage Adata XPG SX8200 Pro 512 GB & WD Blue SN550 500 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU (from more powerful ASUS TUF DASH F15 lol)
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
Kasy21
9 (0.03/day)
Machinist X99-MR9S: характеристики, обзор, bios и прошивка, покупка и цены (xeon-e5450.ru)
russian site. tells that board has trouble with AIDA64 and also shows lower cpu power values than actual (!)
So is like a motherboard sensor thing? I didn't know that that could happen if I used hardware info, I will try with something to measure the wattage directly from the wall if that is the case, but the performance also is like 30% or more lower in some bench so I don't know for sure, I will keep tryng things, thanks for the info with the russian site.
860 (0.60/day)
Mouse Logitech G604
maybe try to find modded BIOS for this board so it could push all cores to turbo clocks, then performance will be way better. that's how xeons should be used with ALX boards, otherwise low single core clocks make their usage stupid nowadays, cheaper to get just used desktop pc with 4 gen i5-i7 cpu for example, because these boards on ALX cost almost like budget NEW sockets boards lmfao
6,743 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
These boards are frankenstein builds you can/should be lucky they even boot and work.
They use any chipset they can shove in a board so you have 20 variants of the same model. Just have fans and giant cpu coolers and go on with day.
41,290 (6.57/day)
Call them basket cases
898 (0.67/day)
System Name Yes
Processor E5-2690 v4
Motherboard VEINEDA X99
Video Card(s) 2080 Ti
Storage NE-512 KingSpec
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Just bring up CPUz and run 7Zip, prime or Cinebench23. Notice the all core clocks when you click the right mouse btn. Or AMp clamps on 8 Pin. The wall outlet is very inaccurate.
no modified BIOS, it is not possible for V4 to push all cores like V3. 2690 V4 runs at a fairly high 3.2 GHz on all cores. 12th gen 12400F would make more sense 700 single thread CPUz bench might be better but 4990 multi thread is inferior to V4. 2683V4 / 2690 V4 can probably do 6600 in CPUz. although there may be a tie in cinebench23 at 1/5-1/3 the price, not bad at all. Still, elden ring can't be expected to run flawlessly at 60 FPS. for the same price I'll probably get the 12400F and H610 board instead of the 2683 V4 and B85, I don't need that many PCIe and memory slots.
860 (0.60/day)
Mouse Logitech G604
this time AM4 also dropped in price, might consider it too assuming later you could EZ find better CPU much cheaper than 1700 socket. Also beware that if you need single thread more then i3-13100F is a bit higher in clocks than 12400F and it's currently at same price, but maybe you are lucky and could find used 12400F even cheaper.
