Xeon E5-4620 Vs Xeon X5675 Vs 2670? for Crunch.
E5-4620 or X5675?
  • E5-4620
    Votes: 6 75.0%
  • X5675
    Votes: 2 25.0%
  • Total voters
    8
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi every one.
As the title says E5-4620 Vs X5675.
I would like to know which one would be the better option.
Cheers.
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
I'd say E5-4620, more threads/cores newer tech higher IPC? Though this is my humble opinion only I have no experience with either chip from which to base it!
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
I would say the same.
I know the Xeon X5675 because I have a few, but the E5-4620 it's something new for me.
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
I wouldn't go with a E5-4xxx CPU unless you plan on running four of them. These CPUs have enough QPI links to do 4 socket systems. I would suggest a E5-2xxx series CPU, for less cost you'll get better performance but will still retain dual CPU capability, or maybe even a E5-1xxx CPU if you're not planning on going DP or QP.
The E5-2670 would be a far better choice and shouldn't cost more.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
It uses 115 W, no in my plans.
E5-2660 then if you want to hold on to the 95-watt TDP. Still higher boost clocks than the E5-4620. As I said before, unless you're planning on going QP, it's better to go with a E5-2xxx CPU but I would still go with a SB-EP or IVB-EP CPU in the E5-2xxx series over the X5675.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.98/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
i am not voting in this poll because i am Xually biased.
ES- 2660 is a good option and ok for blades too.
337 (0.09/day)
Same here. I agree completely with @Aquinus , E5-4xxx CPUs for QP systems only, if you can afford them. ;) Better performance per buck with two DP systems.
Same here. Let 'em crunch! :D
Worried about those additional 20 watts? Turn off your monitor. :laugh:
Agreed and noted for future upgrades. For now though, I'm happy with what I've got to crunch on and can afford - hence my vote. :rolleyes:
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Monitors are always turned off :slap:
As i have said before it's something new for me and because i can get those Xeons very cheap i would like to buy at least one in order test power consumption performance and so on, let's say to have some fun with it and to learn something new.
1,700 (0.27/day)
I got a 2620v3 and a 2670v3 if your interested. I can only use one..... (both under $400)
Aquinus
Resident Wat-man
13,173 (2.78/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
I would browse a bit more. I'm seeing the E5-2660 on fleabay for as low as 150 USD which is a great price for a 8c/16t part. If I didn't have to repair the car, I would have considered investing in two of those.
t_ski
Former Staff
11,960 (1.75/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
My E5-2680v1 dually and my E5-2650v2 dually both produce more than double what my X5675 does. Each of the duallies get 18.1PPD (average), where the X5675 gets around 5.5K PPD (average). I haven't looked at the exact specs, but assuming it's just a matter of 4P CPUs vs. 2P CPUs, then the new generation should still be an improvement over the last.
As long as you can get the parts cheap, they're worth it. If you have to shell out for retail, then no.
4,666 (0.70/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
Since (iirc) BOINC scales pretty linearly with cores and clock speeds, just as a really rough estimation of multi-threaded horsepower, I usually just take the number of cores multiplied by the clock speed to get sort of a "total GHz" rating. the E5-4620 and X5675 both clock close to each other at 20.8 and 20.82 respectively. Here's a detailed "on paper" comparison between both processors. I highly recommend poking through Anandtech's review of the Sandy Bridge-EP architecture too.
If you can get either for the same price, I'd definitely lean towards the E5-4620 for the improved architecture (and as others have said, the E5-2660 over the 4620 unless you're going quad socket).
CAPSLOCKSTUCK
8,578 (1.98/day)
llaregguB...WALES
Mouse cheap
that is exactly the sum i used, i used a pencil and paper.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Update.
E5-4620 - 8 cores - 16 threads 2.4GHz
Power consumption: 133W
PPD: 7500/8500 - Depends how many FAH2 is running.
X5675 - 6 cores - 12 threads 3.6GHz
Power consumption: 175W
PPD: 5500/6000 - depends how many FAH2 is running.
Price
X5675 - 150€
E5-4620 - 90€
[Ion]
WCG Team Assistant
13,391 (2.39/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
How are you seeing the E5-4620 @ 90 euros? The cheapest available here is $500 each for non-ES ones
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Ebay:D
Note: I bought it but not in Germany.
I found a Quad socket motherboard for that Xeon but i don't have a clue what kind psu i should use for it.
[Ion]
WCG Team Assistant
13,391 (2.39/day)
Still that's really cheap. $500 was the Ebay price here too....
4,518 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
ES and 150 Euros. More than 10 avail.
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
I would like to buy 3 more, I just need to find out what kind of psu I need for the board.
Motherboard:
Intel S4600LH2 SG49987
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
4,518 (0.81/day)
Denmark
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
