XFX 580 flash from Mining VBIOS to Retail BIOS , any help
90Ninety
25 (0.02/day)
So I acquired an ex mining RX580 on Evilbook marketplace (XFX AMD Radeon™ RX 580 GTS XXX Edition 8GB ) , seller got it as a job lot untested, it may be damaged ,as not known if working but cheap enough for me to gamble on . I thought I would try to bring it back to gaming use, I have done flashing before with different generations of GPU with a fair amount of success
Anyhow when I tried a bootable dos ATI flash , I got a 'No GPU found' or similar message .
So I decided to boot into windows using my APU, the card is detected here as RX580 . I ran the amdvbflash and tried to load this ROM here (one of three) and a few others using the 'xxx' variant label . Though this allways fails (as shown below) due to the following P/N mismatch
I tried the GUI version and get the same P/N mismatch
For the record , here is the GPU-Z info
Any suggestion appreciated .
Thanks
42,691 (6.68/day)
Thanks
That bios is missing the memory profile hence auto detect. You will need to get a picture of white stickrrs on card snd remove heatsink to verify what ram is on the card
90Ninety
25 (0.02/day)
a few pics
memory
sticker
sticker2
Also there is a secondary BIOS (BIOS switch) as shown
42,691 (6.68/day)
Sorry for late reply
Yeah you for sure have the wrong bios on there.
I will get on it.
I read on XFX your gpu will rise to 1386 from 1366 (auto OC)
These are Samsung FB files:
1366
2019 03 13
1386
2019 03 11
These are Samsung FC files:
1366
2020 03 18
2019 08 20
1386
2019 09 20
