Xfx 6800xt vram clock
DangerousB
2 (0.03/day)
Hi guys! Since last night i noticed that my xfx 6800xt jumps to 1900mhz clock while watching youtube videos or randomly videos on pc! I have 2 monitors acer @1080p 75hz... tried to lower the hz but doesnt help... tried to turn off one monitor and that doesnt help..the card is undervolted to 985mv! Stock settings same problem happens! Thanks
3,805 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
Do you have VRR on?
Monitors support lowering Hz when you dont need high refresh rate?
This is with DisplayPort if that makes any difference.
206 (0.05/day)
Processor Ryzen 7 5800x3D
Motherboard Gigabyte B550 Gaming X v2
Memory Corsair Vengeance LPX 2x32GB 3600Mhz C18
Video Card(s) XFX RX 6800 XT Merc 319
Storage Kingston KC2500 2TB NVMe + Crucial MX100 256GB + Samsung 860QVO 1TB + Samsung Spinpoint F3 500GB HDD
Display(s) Samsung CJG5 27" 144 Hz QHD
Case Phanteks Eclipse P360A DRGB Black + 3x Thermalright TL-C12C-S ARGB
Audio Device(s) Logitech X530 5.1 + Logitech G35 7.1 Headset
Power Supply Cougar GEX850 80+ Gold
Mouse Razer Viper 8K
Keyboard Logitech G105
This shouldnt really be a problem. Card boost its vram clock to 1900mhz when it needs to. 1900Mhz is default max clock of that card so no problem there. Youtube videos use your GPU power (if hardware acceleration is on which is default) so it can boost your card. Undervolt doesnt effect it and vram isnt really a big power problem so you shouldnt really worry about it.
Is there another problem like heat or power? Otherwise, that's completely normal.
DangerousB
2 (0.03/day)
the main problem that the card goes to 55c and the fans starts then... both monitors are connected via DP and vrr are enabled for both monitors! the thing is that in last few days i didnt noticed that the fans starts after watching videos! the power consumption while watching videos is 25-26w
