XFX AMD Radeon RX 6750 XT temperatures
nucleo
4 (4.00/day)
First AMD card that I bought, installed yesterday, did some testing. Temperatures seem a bit high for a 3 fan card, I expected better. Are these normal?
Room temperature: 22c, zero rpm off, advanced control disabled, max fan speed 100%, BAR enabled.
With a case panel:
Idle: 47-48c.
Stalker 2 - 94-98% load, 1797 max fan rpm: 78c max gpu temp, 98c hotspot.
Witcher 3 - 97-99% load, 1962 max fan rpm: 80c max gpu temp, 101c hotspot.
Without a case panel:
Idle: 46-47c.
Stalker 2 - 94-98% load, 1609 max fan rpm: 77c max gpu temp, 98c hotspot.
Witcher 3 - 94-98% load, 1684 max fan rpm: 78c max gpu temp, 99c hotspot.
1,960 (0.32/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
We are lacking information. Is it the MERC, QICK or SWFT or even the reference model.
Please share exact part number.
1,960 (0.32/day)
Version 020.002.000.019.018099, I think it's the reference model.
That is not the part number on the graphics card. You shared a bios version number and that is not the same.
17 (0.00/day)
Spring Grove, PA
Safe max for Hotspot is 110.
Your delta is reasonable, so cooler contact doesn't indicate an issue. Did you buy it new?
nucleo
4 (4.00/day)
Yes, fresh out of the shop. 3 year warranty. I'm still able to return it to the shop at the moment.
Another thing that was noticeable, one of the fans is making noise at around 1000 or more rpm's.
