XFX Radeon RX 580 GTS XXX bios help
57 (0.06/day)
Friends, if you have the XFX Radeon RX 580 GTS XXX model, can you send me the bios code on the bios chip, it's very urgent, I can't find the chip
plz help
41,963 (6.61/day)
plz help
Take pics of white stickers on card back and remove gpu heatsink and take pics of the ram chip's stenciling, post here, you will get help
57 (0.06/day)
Which of the chips marked in the first picture is the spare bios, which is the original bios, I lost 1 of the bios chip, can I run the card with a single bios?
The bios says 25q40h on the chip, but how can I solve such a chip on the net and in companies?
41,963 (6.61/day)
Not worried about the bios chip
Get a close up of each ram chip please, i want to id then
I will help you source the correct firmware for the card
41,963 (6.61/day)
eidairaman1 the situation is urgent please​
PAY ATTENTION TO WHAT IS ASKED, GIVE THE INFO I REQUESTED OR I CAN'T HELP YOU!
Who the hell are you to demand this is urgent???
Get the pics of each ram chip, i cant see them properly without a clear shot.
This is the only way to get you a working bios.
222 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
You already have "the code" on the other chip. The are almost certainly the same chip.
If you get a replacement chip soldered on, you will need to program it using the file eidairaman1 is trying to help you locate.
I don't know which physical location was for the gaming BIOS, and which is the mining BIOS.
You could probably run with 1 BIOS chip, but I noticed you BIOS switch is missing.
It seems unlikely that the BIOS chip was removed by accident, since it is well protected under the back plate.
It looks like a big ball of solder in the place of the BIOS switch.
I'd guess that there is a bit more to this story...
You can use the instructions here to ID the chip and start to try to find a replacement.
it's very urgent
"Urgent" may be strong word for this situation, and may make you sound impatient.
Good luck!
57 (0.06/day)
the pictures you want ?
Good luck!
I Wanted To Ask If The Place Of The Currently Installed Bios Chip Is Correct In The Picture.
Can I Get Image With Single Bios I Lost Other Chip
eidairaman1?​
41,963 (6.61/day)
eidairaman1?​
Thank you. Now we can proceed
D9VVR is Micron
mt51j256m32hf-80
You card.
1366 Stock, 1386 OC 2000 Ram
These bios will work.
1386
2019 03 11
2018 12 25
1366
2018 11 20
2018 03 04
57 (0.06/day)
D9VVR is Micron
mt51j256m32hf-80
You card.
1386
2019 03 11
2018 12 25
1366
2018 11 20
2018 03 04
I couldn't see the bios chip model, the model on it is nowhere ?
222 (0.10/day)
1,891 (1.45/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello
I am sure you could find that specific chip on a broken card with same details.
So instead searching web for a new chip you better start search a broken card for a replacement chip.
57 (0.06/day)
Hello
I have a single chip, can I program it, can I open the card with a single chip?
41,963 (6.61/day)
With the BIOS files I just provided you, yes you can that card
1,891 (1.45/day)
Romania
With the file @eidairaman1 provided, you will program or flash the card.
Your card will function with one chip as long as you do not move the switch to the 2nd position where it supposed to be the missing chip.
So yes you will have a 100% functional card
57 (0.06/day)
In the picture, is the place where the Bios Integration is installed is the Backup Bios or my own Bios Point will be used for Card Scraping
1,891 (1.45/day)
Romania
As i can see from the photo, the chip was removed - desoldered, so maybe it was removed for a reason.
57 (0.06/day)
Is the place where the chip is installed is correct, does it work in the same place by removing and programming?
1,891 (1.45/day)
Romania
Usually external programming is not made by removing the chip, rather using a tool to fit on that chip without taking it off the video card.
I would not move it. Just use an external programming tool to do it.
57 (0.06/day)
Genellikle harici programlama çipi çıkararak yapılmaz, bunun yerine çipi video kartından çıkarmadan çipe sığdırmak için bir araç kullanılır.
hareket ettirmezdim. Bunu yapmak için sadece harici bir programlama aracı kullanın.
Chip Doğru Yerleştirildi mi Yoksa Chipi Diğer Boş Yere Takmalı mıyız?
1,891 (1.45/day)
Romania
"Is The Chip Placed Correctly Or Should We Insert The Chip In The Other Empty Place?"
Yes the chip is placed in the right slot ( for the second BIOS).
You are missing the 1st BIOS so you will use the switch ONLY in the second position, because when you will move it to first position the card won't work.
So using the card as it is now without moving the switch rely only in programming it with a correct BIOS.
57 (0.06/day)
The bios location in the picture is correct, just programming is enough, this card will be used for excavation, will it be solved when you program it?
1,891 (1.45/day)
Romania
Yes, after you flash the card with the correct BIOS, yes you would have a functional card.
And yes you could use it at mining if you like.
57 (0.06/day)
I'll try a little later, I'll write the results to you, can I get an image?
Friends Opened Card But What Is The Problem? Can You Give Information?
