XFX Radeon RX 580 shows incorrect x8 bus lanes
blackhein
6 (0.01/day)
Hi folks,
This is my first post here.
And I´m having some trouble with my XFX Radeon RX 580 GTS XXX Edition OC+ 8GB.
GPU-Z shows correct information about the GPU card. But at bus interface shows working x8 1.1 or 3.0 instead x16 3.0 supported.
Card was bought back in SEP/2019 but only recent I noticed this.
I´ve tried different configs at UEFI Bios but no success at all.
Could you help me?
PS: I tested an old EVGA GTX 550 Ti at the same pci-e x16 slot, and it works @x16 on first boot and installation of nvidia drivers.
825 (0.45/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
Is it still x8 under heavy load? If so, have you tried cleaning the fingers of the GPU and reseating it?
42,078 (6.62/day)
I would clean the pcie contacts and blow out the slot, get a picture of the pcie blade on the card front yo back, a close up. Hopefully no smd components have been knocked off or damaged.
I would remove all AMD GPU and Nvidia GPU drivers using their uninstallers, then download and run display driver uninstaller.
blackhein
6 (0.01/day)
Under heavy load it works @x8 3.0. I've made a Furmark test, gaming, render and it works fine.
Yes, I disassembled and cleaned the whole PC last weekend.
I've already run DDU to cleanup drivers but o lucky, maybe it's needed again. :(
I use the PC for working but I'll try again a more deep clean on pci slot and take the photos ASAP.
Tks guys, soon I come back with new info.
1,891 (1.45/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hi. Is there any chance to take out your card and put it in another system where you should remove all older drivers and reinstall them ?
I suspect you have problems with the main board not with the video card itself.
If the problem persist then you were unlucky and could be a hardware problem with your video card.
blackhein
6 (0.01/day)
I have already tested an old GTX 550 Ti and it works @x16.
Taking a closer look to the Amazon shopping page (where I bought it) it saids: "hardware interface - pci express x8"
Maybe a custom XFX VBios limiting the bus lanes?
Here are pictures of the board. I just clean all up (card and pci slots again) and aplied new thermal paste to GPU. (that is the first time I disassemble this GPU)
  • Photos_RX580.zip
20 (0.01/day)
Somewhere in Melbourne Australia
System Name Main PC, Project Many Drives.
Processor i5-4690 @ stock, Core 2 Quad QX6800 @ 3.2GHZ
Motherboard Gigabyte GA-Z97X-UD3H, Intel D975XBX1
Cooling Cooler Master Hyper 212 evo, Cooler Master TX3
Memory 4 x 4GB DDR3 Kingston blue stuff with heatsinks, 4x 2gb Random DDR2 800
Video Card(s) EVGA Geforce GTX 770 2GB ACX OC, Modded Sapphire Radeon 7850 with a heatsink from a GV-NX96T512HP
Storage Samsung 120GB, WD 2TB, Sansumg 1.5TB, TOSHIBA 1TB. 3x WD 7.2k, 5x Seagate 7.2k, 2x Maxtor 10K, 1 SSD
Display(s) HP W2371d, HP20wd. 23" 1680x1050 Proview thing, 19" 1280x1024 dell ultrasharp thing
Case Antec P180 (or P182 idk), some boring coolermaster case with 3 120mm fans
Audio Device(s) Soundblaster XFI XtremeGamer Fatal1ty Pro, built in audio
Power Supply SilverStone 1KW 80+ silver thing, Antec HCG-750 non modular. (runs hot and loud AF)
Mouse Logitech G400S, Microsoft optical Mouse
Keyboard Microsoft Multimedia Keyboard 1.0A, IBM SK-8820
Software Too much software to be listed here.
Benchmark Scores Fast enough for me XD
Are the surface mount caps on the rear edge of the connector in good condition and aren't damaged or missing?
I have a Radeon HD 5770 that's permanently stuck in PCI-E X4 due to one of the caps being ripped off due to damage during insertion.
42,078 (6.62/day)
1 is damaged or missing, i just reviewed the photos
blackhein
6 (0.01/day)
Wow, I would never see that. :eek: You have eagle eyes. I'll try to find a good tech to fix it.
Tks again for helping and I'll keep you updated as soon as I get it back fully working.
42,078 (6.62/day)
Where do you live Geo graphically?
1,891 (1.45/day)
Romania
Wow, indeed @eidairaman1 have eagle eye.
I was sure it is something hardware but i did not saw the cap missing , even i was carefully watching at your photo.
Gratz @eidairaman1 !!!!
blackhein
6 (0.01/day)
42,078 (6.62/day)
São Paulo city, Brazil
I was thinking if it's a VBIOS issue/lock at start, but now I'll let the technician do his job.
Tks again to all of you, specially @eidairaman1
If you don't have a tech in Brazil, here is 1 in the U.S.
Thanks @Andy Shiekh
Otherwise it's having to go on youtube to find Eli Tech and Zettabit.lab and then go on the web to find their email addresses.
1,891 (1.45/day)
Romania
@eidairaman1 - if you have those 2 mail addresses would be nice to share with us .
You will help those guys and they won't loose time to find them :)
On the other hand is the any tech lab or guy located in Europe who can repair video cards ?
42,078 (6.62/day)
Unfortunately I don't have e-mail addresses let alone even tried to search for them
