chillfactr
- Apr 18, 2021
- 1 (0.00/day)
I bought this used gpu taht was using it for mining, i plugged it in and it would work in windows 10 pro, but was a little glitchy. so i downloaded this rom to flash it (XFX.RX590.8192.181031_1.rom)
i did not, i repeat, DID NOT! save the rom that was on it. so now it wont boot to windows anymore. i can still use atiflash in dos to write the bios but it wont boot with windows anymore. how can i get the oem bios on it or set it to factory mode?
Ok so i switched the bios switch and it seems to be working like a charm on that setting. so i guess no guru input needed here. Thankx
