XFX RX 580 8GB - UEFI csm bug
greg182
8 (0.01/day)
Greetings after reading the topic
Referring to the graphics, bios, etc. I tell you that I have the same problem with CSM in an 8GB xfx RX580 and doing all the steps indicated by my friend eidairaman1, I found that my bios is here in the database.
Card part number RX-580P8DFD6
This is the bios https://www.techpowerup.com/vgabios/192497/xfx-rx580-8192-170410
Could you help me to know which bios I could use to change it and solve the problem, I am inexperienced in the subject and I am afraid.
bios list https://www.techpowerup.com/vgabios...sion=&interface=&memType=&memSize=8192&since=
Thank you
263 (0.28/day)
You need to provide white sticker picture from back of card, GPU-Z screenshot and maybe vRAM chip picture
greg182
8 (0.01/day)
I can't take a picture of the vram, I would have to disassemble the entire card. and the information of my bios and all the specifications are in this link https://www.techpowerup.com/vgabios/192497/xfx-rx580-8192-170410 when I opened the GPUZ and loaded the BIOS it told me that it was already loaded and that was my bios and it sent me to that page.
263 (0.28/day)
You have created a new thread, show GPU-Z screenshot to keep everything in this new one pls
Any other white sticker on the GPU also?
As you can see many unverified BIOS are available so we need more info
greg182
8 (0.01/day)
of course no problem here are 2 images I hope it helps. I also attached a picture of the box and the problem that it presents when deactivating the CSM is this one in the photo
izy
995 (1.23/day)
You can update GOP on your current vBIOS. I did it on my old XFX RX 580 8gb (and on a 280x long time ago i think) and went just fine.
greg182
8 (0.01/day)
that is very complicated I prefer to continue using the computer with the CSM active..
Thanks you
izy
995 (1.23/day)
Its pretty easy there are a lot of information that you dont really need , if you can give me your vbios i can do it for you but flash it at your own risk , i didnt had any problems as i said but i cant give any guarantees. (you can get it with GPU-Z)
Edit: Seems that you have the same card i had (same model , same memory, same bios version), you can use the vBIOS ive used with updated GOP that worked just fine for me (i still had it saved, ive attached it below). (but at your own RISK!)
GOP Driver Name: AMD GOP X64 Release Driver Rev.1.67.0.15.50.Oct 18 2018.14:11:59
  • Ellesmere_updGOP.rom
greg182
8 (0.01/day)
thanks for your help I will have it as an option l kwye I really want is to change the BIOS if there is a compatible one
izy
995 (1.23/day)
Thats for sure compatible as its for the same card and it was tested on my own card, you have dual bios and you shouldnt be too worried about it, you can boot with the other bios if for any reason it fails , i only told you to flash it at your own risk as i dont want to be responsible for your processing of flashing and so on.
greg182
8 (0.01/day)
Seguro que es compatible ya que es para la misma tarjeta y se probó en mi propia tarjeta, tiene doble BIOS y no debería preocuparse demasiado por eso, puede arrancar con las otras BIOS si por alguna razón falla, solo se lo dije. flashearlo bajo su propio riesgo, ya que no quiero ser responsable de su procesamiento de flasheo, etc.
I understand I have never used cards with double BIOS nor do I know where it is activated in this model or how it is used. Could you tell me if it is an automatic function or if there is a button I haven't seen?
freeagent
8,164 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
