Hi everyone! Can anyone help me with XFX RX Vega 56 Double Edition bios? Couldn't find one on the net. Mine seem to have reference bios (aftermarket). GPU-Z shows 1590 Mhz default clock, which is too high for a nano (1138/1474 MHz Boost Clock).
Processor | Core i7-12700k |
Motherboard | Z690 Aero G D4 |
Cooling | Custom loop water, 3x 420 Rad |
Video Card(s) | RX 7900 XTX Phantom Gaming |
Storage | Plextor M10P 2TB |
Display(s) | InnoCN 27M2V |
Case | Thermaltake Level 20 XT |
Audio Device(s) | Soundblaster AE-5 Plus |
Power Supply | FSP Aurum PT 1200W |
Software | Windows 11 Pro 64-bit |
The rated clock speed of the card and the maximum boost clock set in the bios are not the same.Hi everyone! Can anyone help me with XFX RX Vega 56 Double Edition bios? Couldn't find one on the net. Mine seem to have reference bios (aftermarket). GPU-Z shows 1590 Mhz default clock, which is too high for a nano (1138/1474 MHz Boost Clock).
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
ATIWinflash has no way of knowing that the BIOS is original. It will refuse to flash a new BIOS if it's the same as the BIOS that's already on the card. Is that where you got the idea that it was the original BIOS?...according to AtiWinFlash it has original bios.
The pic is not mine, but ATIWinflash shows the same for me. Thanks, I shall try to switch the bios (silly me x2).where you got the idea that it was the original BIOS?
System Name | RyzenGtEvo/ Asus strix scar II |
Processor | Amd R5 5900X/ Intel 8750H |
Motherboard | Crosshair hero8 impact/Asus |
Cooling | 360EK extreme rad+ 360$EK slim all push, cpu ek suprim Gpu full cover all EK |
Memory | Gskill Trident Z 3900cas18 32Gb in four sticks./16Gb/16GB |
Video Card(s) | Asus tuf RX7900XT /Rtx 2060 |
Storage | Silicon power 2TB nvme/8Tb external/1Tb samsung Evo nvme 2Tb sata ssd/1Tb nvme |
Display(s) | Samsung UAE28"850R 4k freesync.dell shiter |
Case | Lianli 011 dynamic/strix scar2 |
Audio Device(s) | Xfi creative 7.1 on board ,Yamaha dts av setup, corsair void pro headset |
Power Supply | corsair 1200Hxi/Asus stock |
Mouse | Roccat Kova/ Logitech G wireless |
Keyboard | Roccat Aimo 120 |
VR HMD | Oculus rift |
Software | Win 10 Pro |
Benchmark Scores | laptop Timespy 6506 |
It's a driver issue, i had the same , clean install ,i had it on vega And polaris.Thanks for the answer. Yes, it seems the card wasn't flashed or anything, but its not functioning properly. Barely managed to install the drivers, now getting the same error again (thread stuck in device driver, win7/win10 (fresh install,2 different rigs). Today my screen just gone black when system was idle. R9 290 working just fine, even without reinstalling the drivers. I think its hardware related afterall, gonna have to return it.
That's the BIOS I posted the link to above.The pic is not mine, but ATIWinflash shows the same for me.
Processor | e6850 |
Motherboard | foxconn blackops |
Cooling | mcr220, mcp355 w/EK v1 g3/8, dtek v2, mcw30 |
Memory | gskill HZ w/micron gts |
Video Card(s) | 3870 |
Storage | 2x samsung 501j |
Display(s) | trinitron 24" |
Case | p180b |
Audio Device(s) | SBA2 plat pro |
Power Supply | 750TX |
Software | server08 |
Ok, thanks again, appreciate your help. I'll try and change the switch position first, then load the BIOS you've posted above into ATIWinflash and see what it'll show (the pic I posted is from some reddit guy with the same card). I'll report back tomorrow, it is past midnight here.
