- Oct 9, 2007
- 47,057 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
An 80 Plus Platinum-compliant 1450W PSU? No, we're sober. Xigmatek is flexing its engineering muscle in the PSU department with a semi-modular PSU that has both high-power and high-efficiency. The Goliath GP-1451 from Xigmatek gives you all the connectors you'll ever need, and with 1450W, enough power for 4-way SLI, 4-way CrossFireX, dual-socket systems. What's to not to like? The Goliath uses an asymmetric double 12V rail design, the first rail can deliver 55A, and the second 75A. Apart from 24-pin ATX and EPS connectors, most connectors are detachable to improve cable management. The beast is cooled by a 130 mm fan.
