XIGMATEK Intros the Aquarius S Wide Mid-Tower Case
47,297 (7.53/day)
XIGMATEK over the weekend introduced the Aquarius S, a compacted version of the Aquarius Plus. Both cases are still targeted at gaming desktops with room for DIY liquid cooling setups. What sets the new Aquarius S apart is its lesser depth, which means only two 140 mm / 120 mm fan mounts along the top- and bottom panels, instead of three on the Aquarius Plus.
Despite this, you get room for graphics cards up to 32 cm in length, CPU coolers up to 17 cm in height, and PSUs up to 20 cm in length. The PSU bay is oriented sideways in this vertically-partitioned case. Two clear tempered-glass panels cover the front- and left-sides. Storage options include two 3.5-inch trays that can each hold 2.5-inch drives, and three additional 2.5-inch mounts behind the motherboard tray. The Aquarius S measures 349 mm x 285 mm x 430 mm (DxWxH). The company didn't reveal pricing.
14,170 (3.81/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Now make an iTX version, this is still too big.
1,986 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
*looks at picture of case with GPU inside* Dat bitch isn't even plugged in, yo! :roll:
freeagent
8,856 (3.87/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I don't even think that's a picture of a real computer :laugh:
Edit:
Probably couldn't find a GPU so they just said eff it
394 (0.09/day)
Where ever the wind blows
System Name PATATAS-3XTR3M3
Processor Ryzen 5800X
Motherboard Asus ROG Crosshair VIII Dark Hero
Cooling Phanteks Glacier One 240MP
Memory 32gb (16x2) G.Skill Trident Z Neo 3600mhz
Video Card(s) Asus ROG STRIX RTX 3080 Ti UV:850@1850
Storage Boot Drive: ADATA XPG SX6000 256gb, Storage Drive: 1TB Samsung 980 x2
Display(s) Lenovo G27Q-20
Case Lian Li O11D Mini
Audio Device(s) Samson SR850 connected to a Focusrite Scarlett Solo
Power Supply Corsair SF750
Mouse Logitech G Pro X Superlight
Keyboard Akko MOD006, Durock POMS
Huh This is my case atm but in SEA its known as the Tecware VXC. Really good airflow for the price. The only downside is that it doesn't come with any fans (the Tecware rebadge) and removing the front glass panel is kind of a pain. Hopefully xigmatek includes fans when they're the ones selling it
834 (0.46/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
I feel like they're placing a lot of faith in those two bottom intake fans for solid airflow given that there isn't any side intake. Looks like they've taken it into consideration and made sure the feet are tall enough, but there's still likely less intake compared to a front or side intake. Would be interested to see how this compares thermally to the Aquarius Plus.
6,263 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Actually, if you set it up as shown, with the 2 fans in the top sucking hot air out, it should be pretty efficient, as that would make the air flow path a mostly straight one, since hot air rises.
I've never seen the Plus version, but it should compare favorably.....
Too bad it doesn't have USB-C on the top I/O, if it did, I might consider buying it for my next build :(
834 (0.46/day)
Maryland, USA
Yeah, in theory the vertical airflow pattern should do well. You're just limited by how much air those bottom fans can pull in from the inch or so gap beneath the case and the surface it's sitting on. Compared to side/front intake with a whole open room to pull air from versus having to pull air from an inch gap between the desk and the case, I can speculate which one's going to suck in more air. Idk though, all just speculation. Anybody dense enough to put this on a shag carpet though is in for a PC turned EasyBake Oven.
I'd never heard of it either, but they linked the press release in the first sentence. Just an O11 Dynamic clone. Biggest noticeable difference between the two is the addition of side intake on the Plus.
A shame indeed.
703 (0.14/day)
Pensacola, FL, USA, Earth
Getting lots of similar feels to my Corsair Carbide Air 540 case. :D
2,025 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
Looks like a 3D printer,....
Deleted member 205776
Only reason I like this sort of cases is the giant amount of space in the back for PSU cables. Sometimes routing crappy PSU cables (cough Corsair RMx) in some compact midtower cases is a pain.
6,263 (1.53/day)
Motherboard AZW SEI
mee2, and my 740 :)
Well, if it is a major concern, you could just make a pair of risers to go under each set of feet, using some good old school 2x4's, or bricks, or go for da bling bling and use some marble/ceramic/stainless steel rectangles for that matter, hehehehe :)
14,170 (3.81/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Not as much as this does.
179 (0.10/day)
Actually quite a lot more "LianLi O11Dynamic" feel ^^. Just missing the "side fan placement" (right side of Mainboard) option but in general a very similar layout. But most of the "new" 2-chamber designs look like this. The Corsair actually went a nice and slightly different way and I like it a lot (but more the small version for ATX/ITX builds than the 540 :) - I think the design of the smaller ones is actually even nicer)
