XMG APEX 15 is a Laptop with AMD Ryzen 3950X CPU Inside
AleksandarK
2,524 (0.96/day)
Have you ever wondered how a laptop with a desktop CPU that has 16 cores and 32 threads would look like on a laptop? Well, today is your lucky day as XMG, a German laptop maker, has decided to launch a laptop that has AMD's latest and greatest desktop CPU - the Ryzen 3950X 16C/32T monster. The 3950X CPU, while featuring a regular TDP of 105 W, has been configured to 65 W in Eco Mode, and it runs anywhere from 2.6 to 4.2 GHz. The CPU also isn't soldered to the motherboard and there is a full AM4 socket, that is capable of housing any 3000 series desktop CPU.
Besides a powerful CPU, there are options for NVIDIA GeForce RTX 2060 or RTX 2070 graphics cards, which drive a 15.6-inch Full HD 144 Hz IPS panel equipped with anti-glare technology. The GPUs are a "Max-P incarnation" as XMG calls it, which presumably means that they are designed for maximum performance i.e. possibly higher boost speeds. Additionally, you can configure the laptop with up to 64 GB of DDR4 2666 MHz RAM. This configuration, containing Ryzen 9 3950X, RTX 2070, 32 GB of RAM and 1 TB NVM, costs around 2631 EUR. For more configuration options, you can check out this website. Availability is supposed to be in 6-8 weeks.
1,833 (0.76/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
Probably a Clevo rebrand. I hope they make more AM4 laptops in the future.
225 (0.09/day)
System Name Dreamstation2
Processor Ryzen 7 3700X
Motherboard MSI X470 Gaming Plus
Cooling Hyper 212 Black Edition
Memory Kingston HyperX 32GB DDR4 3200 CL16
Video Card(s) Aorus 2080 Ti Turbo (sounds like a vaccum cleaner at full load)
Storage 2 x 1TB M.2 NVME + 1TB 2.5" SSD
Display(s) Samsung Odyssey G7 32" 4k
Case NZXT H500i
Audio Device(s) Asus Xonar U3 / Audio-Technica ATH-M50x / Edifier R1855DB
Power Supply Corsair TX650M
Mouse Corsair Scimitar Pro RGB
Mating the fastest desktop processor to DDR4-2666 doesn't sound like clever choice, but for low memory bandwidth applications should work well. We all know how memory-sensitive the Zen2 CPUs are. Guess that's a limitation of the mobile platform.
Cheeseball
Not a Potato
1,976 (0.34/day)
Pittsburgh, PA
System Name Titan
Video Card(s) ASRock Radeon RX 7900 XTX 24 GB GDDR6 (MBA) / NVIDIA RTX 4090 Founder's Edition
Storage Crucial T500 2TB x 3
Case HYTE Hakos Baelz Y60
Power Supply Corsair SF1000L
Keyboard Wooting 60HE+ / 8BitDo Retro Mechanical Keyboard (N Edition) / NuPhy Air75 v2
VR HMD Occulus Quest 2 128GB
Software Windows 11 Pro 64-bit 23H2 Build 22631.4317
Max-P is the "non-official" way of saying the Mobile versions of the NVIDIA GPUs that don't have Max-Q's reduced GPU and memory speeds. Technically it's supposed to be something like GTX 1060 Mobile.
430 (0.23/day)
System Name R2V2 *In Progress
Processor Ryzen 7 2700
Motherboard Asrock X570 Taichi
Cooling W2A... water to air
Memory G.Skill Trident Z3466 B-die
Video Card(s) Radeon VII repaired and resurrected
Storage Adata and Samsung NVME
Display(s) Samsung LCD
Case Some ThermalTake
Audio Device(s) Asus Strix RAID DLX upgraded op amps
Power Supply Seasonic Prime something or other
Err...
Massive CPU... But not even a 2080 option?
2,715 (0.59/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
Err...
It's a 15inch laptop, 2080 might be too much heat. If they made a 17in model, it'll handle a 2080.
Cheeseball
Not a Potato
1,976 (0.34/day)
Pittsburgh, PA
System Name Titan
Looking at this further, if they had a desktop 3700X (configured to 65W) option along with a RTX 2080 Max-P (1.6 GHz boost) with the same 230W power brick for $1,999.00. I'd actually buy one.
22,276 (6.02/day)
ARF
4,670 (2.69/day)
Ex-usa | slava the trolls
It's interesting how they've become suddenly so brave to put so hot parts in narrow chassis :eek:
So much noise from the fans and heat on the keyboard... who needs it?!
This is for 128 Minesweeper & Solitaire VMs. Quarantine measure
Yeah, I was thinking the same, the graphics acceleration is going to run on the CPU :D
2,852 (1.14/day)
Buenos Aires, Argentina
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Case NZXT Source 210
Power Supply Corsair CX650M
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
Up to 8 TB of solid-state storage... Three drives inside a laptop is news to me. But if I had the money and was actually interested in a laptop, I'd happily pay for all that storage :laugh:
Err...
Thermals would probably make it very hard to add such option.
Although I'd be more bothered by the fact that RAM speed is limited to 2666 MHz. That's just sad on AMD's current platforms.
344 (0.07/day)
Clevo laptops usually have XMP and custom RAM options.
2,061 (0.74/day)
Tanagra
System Name Budget Box
Processor Xeon E5-2667v2
Motherboard ASUS P9X79 Pro
Cooling Some cheap tower cooler, I dunno
Memory 32GB 1866-DDR3 ECC
Video Card(s) XFX RX 5600XT
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Antec P7 Neo
I don’t have a use for it, but I like the “because we could” methodology on display here.
2,852 (1.14/day)
XMG Support
Schenker Rep
23 (0.01/day)
Yes. XMG APEX 15 supports 3200MHz RAM and will put these options online over the week.
This chassis does not support XMP but rather requires memory with 3200MHz JEDEC profiles. Those are pretty new and are just coming out. At launch we were not ready yet to commit to either GoldKey, Crucial, Micron or Samsung, but I think we have that figured out now.
Q: What RAM modules do I need to hit the 3200MHz speed?
A:
Over the last few years, DDR4 RAM speeds beyond 2666MHz were achieved by using XMP: Extreme Memory Profiles. In 2020, this will change. XMG APEX 15 is our first high-end model that does not support XMP. This will also apply to every subsequent model released with next-gen Intel H series CPUs.
In other words: most RAM modules that are advertised with 3200MHz (or more) won’t be able to run at 3200MHz in this machine. They will clock down to their highest JEDEC profile, which is usually 2666MHz.
In order to hit the 3200MHz speed, you need RAM modules that can already achieve this clock speed on JEDEC profiles. This requires new RAM modules that are coming out now in 2020. We will keep this list up to date over the upcoming months:
VendorTypeSKU
GoldKey8GB DDR4-3200 JEDECGKE800SO102408-3200A
GoldKey16GB DDR4-3200 JEDECGKE160SO102408-3200A
Crucial8GB DDR4-3200 JEDECCT8G4SFS832A
Crucial16GB DDR4-3200 JEDECCT16G4SFD832A
Micron8GB DDR4-3200 JEDECMTA8ATF1G64HZ-3G2XX
Micron16GB DDR4-3200 JEDECMTA16ATF2G64HZ-3G2XX
Samsung16GB DDR4-3200 JEDECM471A2K43DB1-CWE
Any modules not on this list cannot be guaranteed to run at the desired 3200MHz.
Yes.
Q: Will you offer XMG APEX 15 with other NVIDIA GPUs?
A:
At launch, XMG APEX 15 is offered with RTX 2060 and RTX 2070 and supports up to 115W TGP on the GPU. Since the RTX 2080 requires 150W or more, it won’t be possible in this current chassis. Our ODM offers a downgrade to GTX 1660 Ti, but we decided not to carry that option because the price gap between GTX 1660 Ti and RTX 2060 has become relatively small and NVIDIA is going to push RTX features like DLSS 2.0 even more in 2020.
Correct. They announced these back in January, they are using Clevo's NH57ADS platform.
Correct.
NH57ADS = RTX 2060
NH57AF1 = RTX 2070
You will get different factory options, depending on which brand you buy:
Chassis-Design: Our ODM is offering this chassis in 4 different variations.
  • NH50: Picture 1 - 2 - 3
  • NH55: Picture 1 - 2 - 3
  • NH57: Picture 1 - 2 - 3
  • NH58: Picture 1 - 2 - 3
The features, mechanical engineering and mainboard layout are identical on each one of these – the chassis is purely about cosmetics and haptics. We picked the NH57 variation because it’s the only one where the LCD lid is made from metal. You can really feel the difference – it’s a much more quality / high-end feeling. NH55 was a close contender but it was covered in a semi-glossy IMR coating which is a bit too prone to collect fingerprints – it looks more matte on the pictures than in real-life.
Overall, the NH57 is the best choice, even though it costs a couple of dollars more in production.
Fingerprint-Reader: the F/P Reader is situated in the top left corner of the touchpad when you order XMG APEX 15. Other brands might not offer this convenient feature.
TPM: the ODM usually offers the mainboard with either dedicated TPM (dTPM) or with a Firmware TPM implementation (fTPM). In Intel, the fTPM is called Intel PTT. AMD does not seem to have a specific marketing name for their own fTPM solution. Regardless, we are building XMG APEX 15 with dedicated TPM 2.0 from Infineon.
Keyboard Layouts: our ODM has their own unique keyboard design – love it or hate it. We at XMG make our own keyboard layouts and our layout for this model will differ from the ODM standard. The keyboard in this model is the same as in previous XMG PRO so the layouts have already been drawn for over 20 keyboard languages for the pan-European market.
LCD: the NH series is available with 3 different panel specs: 60Hz with either 45% or 72% NTSC Gamut and the 144Hz top spec, likewise with 72% NTSC. We are committed to build all XMG APEX 15 with the best available LCD panel.
BIOS: our ODM’s standard BIOS usually only comes with a minimal amount of options and features. We have worked with our ODM to extend those options to deliver as many expert tuning options as reasonably possible. This includes various Undervolting options. At the same time, XMG APEX 15 can also be tweaked with RyzenAdj and Ryzen Master.
Brand: we offer a fully debranded option where your laptop will remain completely blank with no printing and no laser-etching on any of the surfaces. Our brand will only remain on the rating label and in the BIOS boot logo. On top of that, all XMG and SCHENKER models are delivered without any stickers (Intel, AMD, NVIDIA, HDMI etc.) on the palm rest area. Where possible, the stickers will be put into the shipping package for your personal usage.
(FAQ taken from our Reddit thread)
We'd be happy to answer more questions from the community!
Cheers,
Tom
27,332 (6.61/day)
Can we get a 17" or 18" version of the laptop in the article? 15" just doesn't cut it.
The chassis from the following but with the X3950;
Or just a 17" version of the Apex 15.
XMG Support
Schenker Rep
23 (0.01/day)
@lexluthermiester I hear you but this is not yet on the immediate roadmap. There are a lot of high-end models launching right now and R&D resources are tight.
Computex is delayed to September 28~30, 2020. I'm sure we will see some major roadmap updates then. We hope, XMG APEX 15 will have already sold well until then so that our ODM might consider to kick-off additional such projects. Wheels are sometimes turning slow here in Taiwan, but they do turn.
Cheers,
Tom
551 (0.17/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
Here is the thing not a lot of people think with these kinds of laptops; they have a battery. Rarely do desktops have a battery. Meaning this could literally replace your desktop, have a built in keyboard and mouse (pros will still have ur own choice of peripherals), and will also have a UPS system inside it. And the price is actually rather decent for its capabilities. Killer steal.
I mean if ur gonna use this plugged in all the time, might as well use a monitor lol
14,048 (3.84/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
If that's the situation, then there is a case for a removable screen model to be made available, just use your own monitor when at home, or attach the screen when mobile.
I think it would work.
859 (0.19/day)
NL
System Name SIGSEGV
Processor INTEL i7-7700K | AMD Ryzen 2700X
Motherboard QUANTA | ASUS Crosshair VII Hero
Cooling Air cooling 4 heatpipes | Corsair H115i | Noctua NF-A14 IndustrialPPC Fan 3000RPM
Memory Micron 16 Gb DDR4 2400 | GSkill Ripjaws 32Gb DDR4 3200 3400(OC) 14-14-14-34 @1.38v
Video Card(s) Nvidia 1060 6GB | Gigabyte 1080Ti Aorus
Storage 1TB 7200/256 SSD PCIE | ~ TB | 970 Evo
Display(s) 15,5" / 27"
Case Black & Grey | Phanteks P400S
Audio Device(s) Realtek
Power Supply Li Battery | Seasonic Focus Gold 750W
Mouse g402
Keyboard Leopold|Ducky
Software LinuxMint KDE |UBUNTU | Windows 10 PRO
Benchmark Scores i dont care about scores
Can I easily detach/attach the laptop battery?
Because I want to ditch that battery off when gaming. It is really unpleasantly to use the battery when gaming.
Seriously, my laptop always connects to electricity when gaming and unfortunately it's very difficult to detach the battery.
It runs very hot easily and quickly degrades the battery itself.
ARF
4,670 (2.69/day)
As far as I know, you can safely forget about the battery and leave it to live as is.
