XMP not working on Ryzen 7 2700x
Deathbourne
16 (0.01/day)
Hello everyone! Need help...
Two weeks ago I built a PC and found out I can't run XMP Profile.
I've read a lot of information on forums, and everyone tell I need to change timings (CL). But no matter how much I tried it I can't do this. Maybe someone know how to do this?
CPU - Ryzen 7 2700x
Motherboard - MSI B450 Gaming Pro Carbon AC
RAM - Corsair 2x16, 3200Mhz, CL16-18-18-36, 1.35V, XMP 2.0 (CMW32GX4M2C3200C16)
Power Supply - Corsair RM550x (550W)
I already reset BIOS to default, few times. Base RAM timing 15-15-15-36 on frequency 2133Mhz (SPD).
By XMP "Profile 1" boost RAM only to 2933Mhz (Support frequency), by "Memory try it!" boost to 3033Mhz.
Any other frequency don't let to start system, so I have to reset CMOS.
As I change a frequency, CPU cooler change RPM and start to make noise. I can't change RPM because after restarting system RPM return back to default.
On frequency 2133Mhz work stably without problem. On frequency 2933Mhz CPU cooler make noise and today was BSOD.
What do you advise: to keep frequency on 2133Mhz or there is some solution for boosting RAM to base frequency 3200Mhz?
Deleted member 185158
When you set XMP, you want to disable, Power Down and Gear Down modes in bios.
Be sure to set manually the Memory voltage.
Be sure to set the XMP timings manually, the main timing set matters most. IE: 16-18-18-36.
The motherboard is designed to try setttings 3 times before posting in "safe mode" (4 total restarts, it takes a few minutes) where it posts all stock settings, but reserves your overclock settings so that you can make adjustments. In short, you shouldn't have to clear cmos.
I would like to see a screen shot of the Bios SPD tab and or CPU-Z tab.
2,047 (0.37/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
its called DOCP (xmp) in some boards are you enabling the right one? just asking.
Durvelle27
6,813 (1.48/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Looking through the specifications of that board and the RAM
It looks like with Ryzen 2000 on that board only does 2933MHz with Dual Rank RAM
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
I also don't even see your RAM listed on the motherboard QVL list
4,849 (1.50/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600 32GB kit OCed to 6600
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply EVGA 850 BQ
Software Windows 11 Professional v24H2
On MSI motherboards it's referred to as A-XMP.
Deathbourne
16 (0.01/day)
I already set the timing manually with an XMP profile. "Profile 1" sets 2933Mhz (the system starts at this frequency but sets high values for the cooler speed and the BSOD was yesterday) and "Profile 2" sets 3200Mhz but the system does not start with it.
Then I set the "Expert" mode and the system rebooted itself and I did not have to do a CMOS reset.
One RAM accelerates to 3200Mhz without problems, but two in dual-channel mode up to a maximum of 3066Mhz through "Memory try it!".
I know. I have this mode called A-XMP.
I also read about it, but others somehow manage to overclock RAM more than 3200Mhz.
The issue is more likely that it is Corsair than anything. Not a hater, just the fact that Corsair doesn't do well with Ryzen.
Perhaps, but I hope that I can manage to overclock the RAM.
My RAM is not in the list of the motherboard, but I do not think that this is a big problem. After all, RAM works, just not at its frequency.
Yes, I have exactly the same BIOS as in the screenshot you attached.
841 (0.42/day)
Processor Intel i9 13900KS
Motherboard z790 Apex
Cooling LT720 + Phanteks T30
Memory 32GB
Video Card(s) RTX 5090 Astral
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Hx1200i
Mouse G502 X Plus
Keyboard K95 Platinum
Since it apparently isn't a QVL memory its possible xmp voltage settings dont apply proper so at least some will have to be set manually.
If that isnt the case then you simply, probably, need to push more voltage SoC/imc and dram to make it work.
I recently installed a 16gb b-die kit on a 3600x+b450 tomahawk system that would only pass the boot check for mem ~50% of the time at the rated 3600c16 xmp speed.
You either compromise with a lower clock (2933) or you push some more power to get things to post.
Deathbourne
16 (0.01/day)
I tried to overclock the RAM using a "DRAM calculator for Ryzen", and this also did not help.
I read about the need to change the voltage, but I don't know how to do it correctly so that my RAM does not burn out.
bug
14,025 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
The same happened to me when I tried to run my 3600 kit at 3600. Turns out the motherbord/CPU won't run that high, so i was resetting and going back to the default values. I set it manually to 3200 (the max supported) and it's been fine ever since.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Probably need to update (or less likely but still possible, downgrade) your BIOS to get it working
I've got that exact same RAM on a 2700x and had no issues on MSI, ASUS or Aourus boards, but i *have* ran into BIOS versions that had broken XMP
Oh and try different RAM slots, some pairs clock higher than others, my MSI B350? (it was a while ago) was bad for that
Deathbourne
16 (0.01/day)
My supported frequency of 2933Mhz is BSOD. Therefore, there are two options: leave 2133Mhz or overclock the RAM to a stable frequency.
Mussels
58,413 (7.86/day)
Oystralia
the XMP1 2933 doesnt work for me either, 3200/XMP2 was needed. Focus on that, maybe manually setting RAM voltage to 1.35v
Deathbourne
16 (0.01/day)
I tried to overclock the RAM immediately after build the PC, but it did not work. After I updated the BIOS to the latest version, that didn't help either.
I used other RAM slots, this does not help.
In single-channel mode, RAM accelerates without problems, in dual-channel system does not start.
I set the voltage manually at 1.35v, this does not help.
I read that you need to change the voltage, and then the RAM will work at a frequency of 3200Mhz, but I do not know how to do it correctly.
Mussels
58,413 (7.86/day)
Oystralia
raise the voltage, reboot, enable XMP, reboot again
maybe use the memory try it in the BIOS, and ignore the XMP - MSI's 'try it' settings were really good for me, for various RAM
I mean, dont forget you could actually have faulty RAM here too, its not likely but it can happen
Deathbourne
16 (0.01/day)
I raised the voltage, rebooted, turned on A-XMP, rebooted again, but nothing works.
Do you think my RAM might be malfunctioning? How to find out? Maybe I'm just wasting my time and I just need to change it under warranty.
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
That's the whole point bud
Being that the RAM isn't listed on the QVL means that the RAM was never tested in the board by the manufacture. So at the point they can't guarantee that the RAM will run at the rated speeds. Yes it will work at lower speeds like any other RAM but it will not work at the actual rated speeds.
Deathbourne
16 (0.01/day)
I understood. And if I change the RAM that is in the list of supported, then it will work 100% as indicated? That is, if the supported frequency is indicated at 3200Mhz, then it will give out 3200Mhz or will it still have to be overclocked?
Manally set everything.
Start at 2933, then manually increase the frequency.
Stop using the profiles.
Deathbourne
16 (0.01/day)
I tried to overclock the RAM using the "DRAM Calculator for Ryzen" manually set all the parameters, and this also did not help.
I've already tried all the options.
Im sorry.
After review of memory jdec tabs.... That memory is crap.
Cas 22 at jedec #6 is stupid.
Can you take a picture of spd tab in bios please?
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
We must also remember how hard dual rank memory is on the IMC on the older Gen Ryzen. Ryzen 3000 is more tolerate but older Ryzen still runs into issues with certain ram
6,192 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Corsair kit and Ryzen plus ram not on QVL list. No surprise here.
Deathbourne
16 (0.01/day)
Im sorry.
