[XO] Motherboard's Post Codes & Meaning
226 (0.05/day)
Athens,Greece
Hey to all wannabe extreme clockers.
This thread is here to help you understand post codes and how to 'avoid' them.
00 Bclock Usually it is appeared when you use high bclock. So, try a lower value
01 Motherboard Usually it means nothing when it comes to oc. It is just
00.|Bclock|Usually it is appeared when you use high bclock. So, try a lower value
23.|IMC|Usually it means that IMC can't run on the specific memory frequency. So, try to use a lower divider
55.|IMC or RAM|Usually it is appeared when you use high memory frequency, tight timings or both. So, try a to loosen timings or lower memory frequency
FF.|CBB|Usually it is appeared when you xtreme cooling. Most of the time it means Cold Boot Bug. Try to warm up your pot (or cooling method :p )
A9.|Incorrect Settings| A9. based on my tests seems to be a result of high overclock. So, try more realistic settings :D
Important TIP:
If you see new, unusual and strange Post Code errors, check for insulation problems on our system.
Humidity can cause liquefaction at low temperatures
Useful links
Link back to the discussion:
http://www.techpowerup.com/forums/showthread.php?t=182495
Link to the [XO] Tweaked and Tiny Operating Systems thread:
http://www.techpowerup.com/forums/showthread.php?p=2884450#post2884450
Link to the [XO] Overclocking (and not only) Glossary:
http://www.techpowerup.com/forums/showthread.php?p=2884476#post2884476
751 (0.16/day)
System Name My PC
Processor i7 4790k @4.4ghz
Motherboard Gigabyte z97m-d3h
Cooling Corsair H105
Memory 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T
Video Card(s) GTX970 Stric oc
Storage Samsung 840Pro 512GB
Display(s) Asus ROG SWIFT
Case Lian Li 359
Audio Device(s) Denon DA-300USB / Denon AH-D5000
Power Supply Corsair AX860
Mouse Roccat Kone Pure Optical
Keyboard Corsair K70
Software Win10 64-bit home
Hmm... for all my 3 gigabyte boards in my past 5 university years "FF" actually indicates that everything works. In fact the booklet that comes with the mobo says FF represents "Fine Function".
PAOK RE
226 (0.05/day)
Athens,Greece
LOL yeah even with Evga mobos FF used to mean Fine Function but on Z77 mobos (asrock, asus and evga) FF seems to be CBB ;)
Btw are you from Greece or smth?
849 (0.16/day)
Nairobi, Kenya
Processor Intel Core i7-14700K
Motherboard ASUS ROG STRIX Z790-H
Cooling DeepCool AK500 WH
Memory Crucial Pro 32GB Kit (16GB x 2) DDR5-5600 (CP2K16G56C46U5)
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro (2TB x 2) / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
On my Intel Motherboard DZ68BC
[00] Means it has booted operating system (Normal Operation) according to booklet provided with the motherboard.
Simply this post codes mean different things on different motherboards, though I might be wrong.
226 (0.05/day)
Athens,Greece
Yeap thats obvious :p
Just for the record the above post errors are the most common errors you may get under xtreme cooling on Evga, Asus and Asrock Z77 boards.
Don't know if they have the same emaning when it comes to other vendors with same chipset or same vendors with different chipset (asus z68 for example). :)
751 (0.16/day)
System Name My PC
Case Lian Li 359
brandonwh64
19,542 (3.54/day)
Maybe you should post which motherboard these codes belong too since most some boards have different codes for different errors.
