XP 32-bit vs 64-bit for gaming
2,361 (0.47/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 NVME SSD (OS), Toshiba 3TB (Storage), Toshiba 3TB (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell P2312H @ 1080p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7 (Speakers), Creative Zen Hybrid headset | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse Roccat Kone Air| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
I'm in the process of building an XP-era machine for a bit of semi-retro gaming. I'm considering 64-bit because it will make better use of the dual-core CPU, but I just wanted some opinions from you guys. I've done a bit of research, and the general consensus seemed to be that XP64 was okay for gaming, provided you could get drivers for your hardware. That doesn't appear to be an issue for me, as all the hardware I intend to put in it has appropriate drivers.
I was an XP64 user myself back in 2009 for a while, and the only problem I encountered was some software incompatibility, but from what I recall that was primarily due to "flags" being set by the developer into the installer when it would actually run fine if you extracted the program files yourself. Anyone here have any thoughts on the matter?
9,781 (2.28/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
couldnt you just install windows 7? wouldnt it be just as compatible with all the games that would run on XP? or even if compatability mode was used if not by default? or do you need it to be XP?
i used XP for years , from its release to well past win 7's launch, it was IMO the best OS, followed closely by Win 7 , but I feel like your limiting yourself by running an XP build. unless stricktly for the novelty of the old OS.in which case, disregard my comment.
2,361 (0.47/day)
Marlow, ENGLAND
It's really not. I can name two games off the top of my head that straight up don't work on Windows 7, and I won't get full use of my Sound Blaster card with it because Microsoft deprecated DirectSound when Vista came out. I might dual-boot it with 7, but I really do need XP as the primary OS.
9,781 (2.28/day)
Massachusetts
Processor i7-11700K
oh im Sure some games dont work on Win 7, but XP has Such a tiny footprint , You could run a VM with XP installed, and have all the novelty, and functionality of XP, on a Win 7 PC, is that an option? Dual boot Could be good too, but I would go VM first, unless there is a reason VM wouldnt work for You.
i just want to make it clear that im not trying to dissuade you from your goal, Im just offering up my opinion as you requested...So please, dont take what i offer as discouragement, i am just possibly ignorant to your end goal.
2,361 (0.47/day)
Marlow, ENGLAND
I already use a VM with XP installed for some games, I just like having something physical to play around with.
qubit
Overclocked quantum bit
17,865 (2.94/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
If you intend building a retro machine, then definitely install XP 32-bit as the frame rates are higher, something like 30% or so which is really important with a slower GPU and CPU. This is especially true when compared to Vista and 7, but not quite as much with XP 64-bit. I've not compared with 8.1 or 10 but from various reviews I've seen they perform about the same as Vista and 7.
People didn't believe me when I reported my personal benchmark results on TPU a few years ago, but it's absolutely true. I think this significant overhead is what the fuss over Mantle and DX12 is all about, as they redress the balance by reducing it significantly and thus improving framerate.
Note that a VM will kill gaming graphics performance, so you're right to want to run it on dedicated hardware.
Finally, of course you won't be able to run the latest AAA games on it, but they're not compatible with XP anyway so that doesn't matter.
2,361 (0.47/day)
Marlow, ENGLAND
Is this vs XP64, or 7/8/10?
newtekie1
Semi-Retired Folder
28,472 (4.18/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
XP 32-bit for sure. A lot of retro games, especially DOS based ones, still use 16-bit code which XP 64-bit can't run.
9,781 (2.28/day)
Massachusetts
Processor i7-11700K
cool, alrighty man, best of luck with your endeavor.
Frick
Fishfaced Nincompoop
19,039 (2.83/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Which games don't run on 7? I think I've got most of my old games working on 7, and I have a lot of them. For DOS, DosBOX.
qubit
17,865 (2.94/day)
Quantum Well UK
Keyboard Yes
It's faster than all of them, but the difference is less compared to XP 64-bit. I did say that in the previous post, but maybe the wording wasn't clear.
Good point, I'd forgotten about that.
2,361 (0.47/day)
Marlow, ENGLAND
Off the top of my head:
Galactic Civilizations
Master of Orion 2
Strange Adventures in Infinite Space
Frick
19,039 (2.83/day)
Piteå
Master of Orion 2
You tried killing explorer.exe? And if the colors are screwed, open the Display properties thing and leave it open.
2,361 (0.47/day)
Marlow, ENGLAND
I tried those around the time, but they never worked. GalCiv just crashes on launch, it refuses to run on anything newer than Vista.
Frick
19,039 (2.83/day)
Piteå
I have a distinct memory of running GalCiv and MoO2 on Windows 7 though... Doesn't matter though, dedicated retroboxes are fine things.
