xspc x20 750 pump be enough please?
100 (0.05/day)
Milton Keynes,England
System Name AMD™ Red Tiger
Processor AMD™ Ryzen™ 7 3800XT @ 4700mhz
Motherboard MSI™ X370 Gaming Carbon Pro
Cooling XSPC™ Raystorm™ dual XSPC D5 pumps 2x 360 EX radiators 6x Noctua™ NF-F12 Industrial™ 3000rpm
Memory Avexir™ Blitz™ 3200mhz 16.18 @ 3200mhz
Video Card(s) Sapphire™ Radeon™ RX 7900XTX under Alphacool™ water block
Storage 1x Intel™ 660p 1TB 1x Seagate™ 2TB 7200RPM
Display(s) Electriq™ VM280UHD 4K 60hz
Case Cooler Master™ Cosmos™ Pure Black with 5x Coolermaster™ bladeMaster™
Audio Device(s) Creative SB X-FI with Logitech™ X540 5.1
Power Supply EVGA™ 1000w G2
Mouse EasySMX™ 4000dpi Red led on MSI™ Lava Dragon giant mouse mat
Keyboard Rii™ K66 Red switch mechanical keyboard with red led
Software Windows™ 10 Home
Benchmark Scores 13000 3dMark™ Time spy.
Hello Forum,
I got a cosmos case and have a xspc raystorm kit with the x20 750 pump that I got as a bargain deal. it came with a ex360 radiator and I also got a second ex360 radiator with the money I saved from buying it as a bargain.
I am at the moment using it with both radiators on the outside of the case and only running the cpu block.
im looking at adding in a pair of Bykski water blocks that I also got as a bargain to a pair of vega 56's,i have read that parallel would easy the strain on the pump a bit.
would the pump be enough to run this kind of set up please?
another question is, considering the size of the loop, would it be better to put the water though the cpu block being the part of most resistance first or would I want to go though the least resistance and them return though the cpu block please?
I have read up and they say it don't matter, but want to set it up right first time and have asked on other forums , but interested in more opinions please.
Best regards,
MrPeforations.
299 (0.05/day)
Saigon city
System Name Kurise PC
Processor i7 5820k 4,7ghz / Ryzen 1700x 4ghz / 8700k
Motherboard Asus X99 deluxe / MSI x370 gaming pro carbon / z370i strix
Cooling EK evo, xspc slim 360 rad, D5 pump, dual alpha cool GPU mono block, dual xspc 240 radiator, DDC 18w
Memory Crucial sport white 16gb x 8 128gb 2666mhz/ Crucial sport white 16gb x 4 64gb 2933 / ddr4 chinese 32
Video Card(s) GTX 1080Ti SLI / HP gtx 1080 SLI 1850/1520 / 2080ti ref
Storage Lite on 512GB x 3 / Plextor m2 256gb / samsung 970 evo
Display(s) AOC I2769Vm, AOC U3477PQU, AOC I2769Vm / Koios 40''/ eizo EV2730QFX 1:1
Case Xigmatek Elysium / Corsair 750D / Bitfenix prodigy M
Audio Device(s) creative blaster ZX / Blaster ZXR / Blaster x7 lmt + burson v5i upgraded
Power Supply Be Quiet 1200 / Thermaltake toughpower 1200w / chinese 750w sfx PSU
Mouse Asus Echelon/ steelseries black ops II/ james donkey
Keyboard Cm storm quickfire pro / Fire rose steampunk kb/ corsair k70
would be fine but a 1000l/h pump or 1200 should give you beter performance just a little bit , i used to have a CPU + GPU waterblock + 2 rad with a 800l/h pump without any problem . But i just prefer any 1200l/h pump then lower their speed or i tend to use dual pump or separated loops for cpu + mobo + memory and GPU loops .
I would put the water to the blocks first then the rad => res/pump.
100 (0.05/day)
Thank you gasoline for your input.
the Bykski™ RX Vega gpu blocks I have ordered can flow both ways but the optimum flow way is the wrong way in my set up as the XSPC™ EX360 radiators i have are external and i would have to flow the wrong way to have them like that, but it apparently does not make much difference.
i'm planning though to run pump-cpu-radiator's-gpu's-reservior.
Best Regards,
MrPerforations
