YAY... Water cooling kit arived (first build)
1,051 (0.16/day)
Port Fairy, Victoria, Australia
System Name Rampage 3.0
Processor i7 3770K 4.2Ghz
Motherboard ASRock Z77 Extreme 4
Cooling Corsair 110 (280mm rad)
Memory 16GB G.Skill Sniper F3-1866 10-11-10 CR1
Video Card(s) 2 X gigabyte 7970 ghz edition @1100mhz / 6000mhz
Storage samsung 500 GB + 128GM crucial M4 ssd
Display(s) LG IPS235P 23in IPS 1080p
Case corsair vengance c70 - white
Audio Device(s) On Board
Power Supply Corsair HX-750w
Software Windows 7 Ultimate 64 bit
ok, i would like to say some famious last words and say that i have recieved my new watercooling kit and i am going to insall it over the weekend, and i am just crossing my fingers that i dont kill everything because every time i open the case i seem to be cursed and things go bad fast even if i just look at it (ask my brother mussels he will aggree with me on that one)
the kit consists of
Laing D5 Vario 12V Pump
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_296&products_id=6154
D-TEK FuZion v2 CPU Block + accelorator nosel kit (q6600)
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_295&products_id=7154
Swiftech MCR320-QP Radiator
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297&products_id=6144
Swiftech MCR220 Radiator (the rad/ res version) (from a Swiftech 220 compact kit)
cosmos 1000 case
i will post pics good or bad when it is all done
wish me luck
DOM
7,628 (1.10/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
so your going to be using two rads to cool just the CPU ?
775 (0.12/day)
Barcelona, Catalonia, Spain
System Name Woody
Processor AMD Ryzen 7 9700X
Motherboard Gigabyte B650M Aorus Elite AX ICE
Cooling MSI MAG A13 CoreLiquid 360
Memory 32GB (2x16) Corsair Vengeance 6000MHz (CL30)
Video Card(s) Sapphire Pulse RX 9070
Storage WD_BLACK SN850x (2x1TB) + Sandisk Ultra 2TB
Display(s) Asus ProArt PA348CGV (3440x1440 @ 120 Hz)
Case Lian Li A3 (Black-Wood)
Audio Device(s) Logitech Pro X & Scarlett 2i4 w/M-AUDIO BX5-D2
Power Supply Corsair RM750 (ver. 2019)
Mouse Logitech MX Master 3
Keyboard Keychron Q1 Pro (Akko Cream Blue Pro V3 switches)
Benchmark Scores It's over 9000!
Search for the CyberDruid mods to the cosmos or the thread by DanishDevil "Whacking the Cosmos" ... maybe you can get some nice ideas too before starting!
Very good luck! :toast:
Chickenfeed
5 (0.00/day)
System Name Feedanator 3 (build in progress)
Processor Intel Core 2 E8400
Motherboard Asus Rampage Formula X48
Cooling Dtek Fusion V2, Feser X360, MCP655, MCRES Micro Res, Tygon R3603
Memory 2x2GB Corsair Dominator PC8500 (RMA)
Video Card(s) Nvidia GTX 280
Storage WD VelociRaptor 300GB / SS SpinPoint F1 1TB
Display(s) LG L246WP @ 1920x1200
Case Silverstone TJ07BW
Audio Device(s) Auzentech X-fi Prelude
Power Supply Enermax MODU82+ 625
Software Windows Vista Ultimate x64
What are you planning to use for fans out of curiosity, those Silent X or are those just as case fans?
1,051 (0.16/day)
yes 2 rads for the 1 cpu .lol. GPU/NB may follow...ty SirKeldon i will look into the "Whacking the Cosmos" thread
Skitzo
720 (0.12/day)
are you using two rads for silence? I'm considering two triples for that reason.
1,051 (0.16/day)
im am using 2 rads mostly becasue i wanted a tripple for the top of the case and i have a spare 240mm left over and also the 240mm has a res fill cap in it so it also solves the "how to fill" issue with ease, for fans i will be using mostly slient X fans and a few noctua fans on 7v
Odin Eidolon
920 (0.15/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
noctua and silenx fans aren't the best for radiator usage (low air-pressure)
1,051 (0.16/day)
i have had the fans for a while now, that is why i am using them + i love a "silent" pc if i cant hear it im happy, what fans would you reconmend???
775 (0.12/day)
System Name Woody
Odin Eidolon
920 (0.15/day)
Cooling HDT-1283
if you are looking for something cheap, yateloon 12sm from petra are fantastic. zalman zm-f3 are good tho and papst too. try to google VAPOR's fan review, u'll find a lot of infos
1,051 (0.16/day)
thanks for the links, i think i will go simple i am not as hard core as those guys, i think i will mount the 360mm in the top and the 240mm off the back of the case with the "RAD Box" that come with my old 220 compact kit.
ZenEffect
622 (0.10/day)
go w/ the yate loons. they are nice and quiet + provide very good air flow. the thickness of those swiftech rads do not provide much surface area for the air to dissipate the heat thus need a bit higher cfm fan to work really efficiently. yate loon mediums are your best bet.
http://www.petrastechshop.com/12yalod1cafa1.html
personally i use scythe 110cfms on all 3 rads push pull, yes they are loud but i put them on a fan controller so they go from whisper quiet to loud as a jet. 1 swiftech 120.2, 1 bix 120.2 and 1 bix 120.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060
cooling cpu, + 2 gpus. all fans on a sunbeam rheobus 4 fan controller, used a bunch of y adaptors to control them all. hooked up per radiator, so each knob controls overall fan speed per radiator.
2 rads to cool the cpu is overkill, you should be able to pull 1.6 or so volts loaded at about 55-60c.
how are you going to run your loop?
Odin Eidolon
920 (0.15/day)
Cooling HDT-1283
those scythe slipstream are said not to do wery well on a radiator, but i've never tried them. How are yours Zen?
1,051 (0.16/day)
all i can say is god dam i was right again, in my first post i said i normally kill things when i open the case, well 2 of my 500gig HDDs died, my windows drive and 1 of my 3 torrent drives.
the windows drive ha a piece physically fall off the back and the torrent drive wont boot in 2 systems, so in total i lost about 700 gig of data :(
i am unsure how the drives died i removed them from the case still in there removable HDD and sat them on the table and 2 hrs later the dont work and to top things off i have been told i am picking ppl up from the pub later so i am waiting for them to hurry up and finish and give me a call to come get them....
165 (0.02/day)
Philadelphia, PA
System Name Heaven-Cf
Processor AMD Athlon 64 X2 5000+ BE Brisbane (215Mhz x15) 3.225Ghz 1.35v Rev BH-G2 8.5hrs prime stable
Motherboard Asus M2R32-MVP (2 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Cooling Xigmatek HDT-S 1283 + AS5 Cpu, Stock GPU Fan, 2 80mm fans, 1 120mm 110CFM Silverstone 2 PSU fans
Memory OCZ ATI CrossFire 2GB (2 x 1GB) DDR2 800 400.3 MHz CPU/7 4-4-4-12-23 2T 1.9v
Video Card(s) POWERCOLOR AX4870 512MD5 Radeon HD 4870
Storage Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS (250 GB, 7200 RPM, SATA-II)
Display(s) Hanns-G HD191-D 2ms 700:1 16.2 million colors
Case APEVIA X-CRUISER-BK Black Steel ATX Mid Tower
Audio Device(s) Creative Sound Blaster X-Fi Titanium Fatal1ty Professional
Power Supply PC Power & Cooling Silencer 750 EPS12V EPS12V 750W
Software XP Pro Tweaked
Benchmark Scores x1950xtx: 3d Mark 03/05/06 - 18467/11383/6478 | Super Pi 32MB 27m 8.110s
i would check and make sure your case is grounded or at the very least neutral. Another thing if you go to do anything in a case shut off the psu and remove the power cable. This normally stops anything from possibly grounding to the PSU because its off or to the ground cable because its not there and electricity very rarely will jump to something unless it is grounded. But if you dont shut off the psu it will still ground back to the psu so just unplugging it isnt enough. With your luck i would ground myself every time i went near the comp case. Also carpet, nylon fabricate, fleece, and platic can all cause static electricity from friction so always wear cotton do it on a dinning room chair in a tiled room.
Or you can do as this suggests: :D
1,051 (0.16/day)
yeah i always ground my self and this rig was build up on the table, if anything was to die i thought it would be the mobo/ram/ect not 2 hdds that were far away from the action, anyways nothing i can do about it now
ZenEffect
622 (0.10/day)
works great for me. kept my q6600 idling @ 32c and load @ 61c 4ghz 1.55v. this is on full blast though and like i said, they are quite loud.
165 (0.02/day)
Philadelphia, PA
Im more partial the the silverstone 120mm 9 blade 110cfm fans myself but both get the job done.
1,013 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
I have one Silverstone FM-122 on my SI-128 cooler and another pulling air out the back of the case. Great fans that move lots of air with lots of pressure.
285 (0.04/day)
System Name Dark Aurora
Processor Intel e6600 @ 4.09ghz
Motherboard ASUS Maximus Formula x38
Cooling Custom Water Cooling on Cpu and Gpu
Memory 4gb Corsair DDR-2 800mhz/ 2gb Patriot DDR-2 1066mhz
Video Card(s) XFX 8800gt 512mb
Storage 160gb Maxtor, 250gb Western Digital, 320gb Maxtor
Display(s) Dell 22" LCD
Case Gigabyte Aurora 570 (Black)
Audio Device(s) Audigy SE
Power Supply PC Power and Cooling 750W
Software Dual boot Windows XP/Fedora 8
Benchmark Scores AM3 201,045 Super Pi 12.453s @ 4.09ghz
http://www.tech-forums.net/pc/1401912-post31.html
Heres a post by a guy I was helping out.
It explains how to hang a radiator off the back of the case using a gutted 120mm fan.
I find the end look is much cleaner and it acts as a sort of wind tunnel so you don't just lose the airflow from the fans mounted inside the case.
