z390, 9700k: can high BCLK (150+ Mhz.) cause instability?
1,755 (1.17/day)
If you run a high BCLK (say 150+ Mhz.) would this cause instability all by itself? I've been experimenting w/a high BCLK to facilitate a higher FCLK.
3,438 (4.90/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
Of course. I don't know what exact numbers are on LGA1151 but anything higher than 170 MHz was considered voodoo on LGA1155/2011.
1,755 (1.17/day)
What I don't understand ir_cow is why does it matter? If I'm running the uncore/core/RAM at moderate overclocks why should it matter what BCLK they're running at?
If I run my 9700k at a 100Mhz. BCLK and 5000 core clock/4700 uncore/3900 RAM clocks and nearly the same core/uncore/RAM clocks at 150Mhz. BCLK, it can make a difference in stability?
619 (0.39/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Usually you can increase baseclock up to 3%, in theory 103MHz, if I understand correct what you mean. You can check Intel locked CPU reviews, @W1zzard almost checks BCLK ‘overclocking’. I don’t know if unlocked CPUs have higher BCLK limits, except of course if the MB has an external BCLK generator.
FreedomEclipse
~Technological Technocrat~
24,350 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Because BCLK also ties into different things on your system like memory speeds and PCI-E clock for instance and that could mess with things like storage or GPU. It puts the system out of whack thats why most overclocking is done by multiplier or tweaking the PBO if you're on AMD.
Its not like those days where you could increase both the multi and FSB at the same time for better clocks. Those days are long gone.
::EDIT::
Although I have seen after a quick google that some people have managed 150-180 BCLK on older Intel and AM4 platforms. Im not sure if they were just extremely lucky to pull it off or if it was 200% stable but you could find out more for yourself if interested.
7,392 (4.95/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
BCLK overclocking has long since been "dead", multiplier is heavily preferred because it stretches farther out and doesn't affect memory, bus timings, PCI clocks, etc. like base clock overclocking does.
50*100 is much preferred to 33.5*150 when targeting 5 GHz, for example.
1,755 (1.17/day)
Aren't PCI clocks irrelevant now? You can adjust the memory speed independently of the BCLK though.
The only reason I was interested in an increased BCLK was so I could up the FCLK.
6,881 (1.45/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
I have a 9600k with gigabyte z390
I like doing 101.11 can go higher. I dont like seeing 99.99 so .11 is nice
you should play with other settings perhaps
Toothless
Tech, Games, and TPU!
9,718 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Throw it at 150 and see what happens. You'll answer your own questions.
1,755 (1.17/day)
150+ Mhz. doesn't work, even at RAM/uncore/core clocks + voltages that work at lower BCLK -- unless it's the much higher FCLK that is causing the issue (1500+ Mhz. as opposed to 1000Mhz.), but I read that FCLK can hit 1600Mhz. without any issue.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
150mhz? how tf is it even booting
103mhz max
Toothless
9,718 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
It's like what people have been telling OP..
Mussels
Freshwater Moderator
58,413 (7.88/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Even 101 can cause instability.
it hasn't been since 1156 that i've seen bclk overclocking even work, so few motherboards have the ability to do it properly with a dedicated timing chip so it doesn't screw with everything on the board.
Varies massively by platform, too.
"Why does it matter?"
Because you're overclocking your PCI-E lanes too, and that can cause literally every component to crap out.
7,392 (4.95/day)
São Paulo, Brazil
In most cases yes, but this can still affect older platforms. In general, you want to be doing your overclocks by multiplier, whenever possible.
3,756 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I agree with what the replies say, the scariest outcome of upping BCLK is corrupting your i/o storage data as you increasing the bus speed on the data pipe it runs over.
1,763 (0.32/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
Remember that these are Skylake refreshes, and thus the base clock is NOT tied to pci. So it's ok to raise as long as you keep your various multipliers in check.
However the Intel Management Engine should be keeping it from booting. Remember in 2016 Intel tried to block non-k skylake OC via bclk.
So what's going in here? Did Intel relax the microcode to allow bclk once again? If so, this is going to be very awesome for overclocking all of those non-k Lake CPUs.
3,756 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
Might be they only blocked it on non Z chipsets and/or non K CPU's?
OP is using Z chipset with K CPU.
1,763 (0.32/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
They blocked it on all, asfaik. Like if I update my Z170, I wouldn't be able to base clock my Skylake i3 lol.
The thing that's weird of course, is that it was allowed again with Alder Lake, but then they blocked it again with Raptor Lake. And this is totally an artificial block. The last Intel CPUs that were actually bus-tied were Haswell, Ivy and Sandy.
So you shouldn't be able to do it, but if you can get around the artificial limit, DO IT :)
And when you run into a wall, it's most certainly memory timings in auto that need loosened. Example: if your memory is set to 3200 with auto/xmp timings, it's still going to try and use the 3200 timings even though you raised base clock by 50% and are running the RAM at 4800. I can explain how to do that better if you want later but I'm hardly awake right now.
1,012 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Yes, this allows BCLK oc just fine on 1151 and prior at least, IDK about 1200.
@80251 FCLK doesn't help much of anything, even going from 400MHz to 1GHz does practically nothing. If anything you'd want to lower it as BCLK oc'ing is usually better at 400MHz FCLK.
1,755 (1.17/day)
@DR4G00N
An FCLK <= 800Mhz. causes noticeable stuttering w/my 4090. I believe anandtech did some testing w/FCLK and found that raising it increased 3dMark scores by a few percent, but that was w/a much less powerful GPU.
Toothless
9,718 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
That increase is not worth it if it stutters. Honestly just leave BCLK and FCLK alone before you really start messing things up.
1,755 (1.17/day)
My apparent problems w/the high BCLK were all down to my Rosewill 750 Watt PSU, which couldn't handle an overclocked 9700k and a 4090. My ghetto mod of using two PSU (the 4090 gets its OWN PSU now)
is working.
The stutters occur if the FCLK is too low, not too high, right now my FCLK/system agent clock is at 1571 Mhz. without any apparent problems.
Mussels
58,413 (7.88/day)
Oystralia
Not every motherboard handles it the same, is the key here.
Internally it's all dividers and multipliers - 100x8 for 800MHz (DDR3 1600) could then become 101x7.5 (757/1,515) or 808/1616 depending on how the board feels like doing things. Sometimes they change these in real-time too, with power saving mechanisms.
You then throw in that theres dividiers on just about every component, and 'not tied together' can still result in some decent swings - even GPU's work that way, my 'flat' undervolt curve on my 3090 has a 50MHz swing either way from what it's set to at times, as different dividers are used at different speeds invisible to the end user.
