ZADAK 511 Intros MOAB M.2 RGB SSD Heatsink
47,126 (7.58/day)
ZADAK 511 today introduced the MOAB M.2 RGB, an M.2-2280 SSD heatsink that's studded with addressable RGB LED lighting. The heatsink is 80 mm long, and roughly 1 cm tall. It's made of aluminium, with a 2 mm-thick base plate, and heatsink fins projecting upward. The heatsink is capped off by a steel top-plate with RGB LED embellishments that wire out to standard 5V aRGB connectors. The company didn't reveal the heatsink's total weight, but is including special steel long bolts to hold the heatsink and your SSD down to the board's M.2 nuts. The company also didn't reveal pricing.
Ruru
S.T.A.R.S.
12,469 (2.88/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
Wow, a new RGB product! :D
In fact I didn't even realize that you could put RGBs in M.2 heatsinks. :laugh:
1,042 (0.34/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
Can we have heatsink for heatsink? in RGB ofc..
1,491 (0.21/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
this rgb madness started when pc cases manufacturers decided to offer inside viewable side panels...
819 (0.22/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
Nah... Window panels were before that. It all started with first "gaming related" Abit Fatal1ty mobos that included red leds across the board. Afterwards it all went downhill...
8,190 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
197 (0.05/day)
I am not sure I want ZADAK written anywhere in my system. Why such a branding push, couldn't you just put small Z in one corner ?
6,098 (1.52/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
From the looks of it, it probably too tall for those m.2 slots (virtually all of them) that are next to the 1st pcie slot, where the GPU sits right on top of it, which is a very tight fit even without heatsinks....thanks to the mobo makers stupid insistence on putting them there. But of course if you put your drives on slot cards, no problemo :)
4,520 (0.71/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
haha RGB let alone LEDs lighting wasn't even around back then it was UV and neon tubes my friend.
1,491 (0.21/day)
Deleted member 178884
Don't worry everyone, just make a rgb build and you'll be putting your presents by the PC this year, all you need to do is mod the startup to play jingle bells.
848 (0.37/day)
System Name Batman's CaseLabs Mercury S8 Work Computer
Processor 8086K 5.3Ghz binned delidded by Siliconlottery.com 5.5Ghz 6c12t 5.6Ghz 6c6t on ambient air
Motherboard EVGA Z390 DARK
Cooling Noctua C14S for all overclocking so far Noctua Industrial PWM fan 2000rpm rated (700rpm inaudible)
Memory Gskill Trident Z Royal Silver F4-4600C18D-16GTRS running at 4500Mhz 17-17-17-37 (new mem OC) : )
Video Card(s) AMD WX 4100 Workstation Card (AMD W5400 7nm workstation card coming soon)
Storage Intel Optane 900P 280GB PCIe card as Primary OS drive / (4) Samsung 860Pro 256GB SATA internal
Display(s) Planar 27in 2560x1440 Glossy LG panel with glass bonded to panel for increased clarity
Case CaseLabs Mercury S8 open bench chassis two-tone black front cover with gunmetal frame
Audio Device(s) Creative $25 2.1 speakers lol
Power Supply Seasonic Prime Titanium 700watt fanless
Mouse Logitech MX Master 3 graphite / Glorious Model D matte black / Razer Invicta mousing mat gunmetal
Keyboard HHKB Hybrid Type-S black printed keycaps
Software Work Apps text and statistical
Benchmark Scores Single Thread scores at 5.6Ghz: Cinebench R15 ST - 249 CPU-Z ST - 676 PassMark CPU ST - 3389
Already done that - way ahead of you. lol :D
We even have an rgb nativity scene this year playing Chuck Berry's "Run Rudolph Run". jk :p
Ruru
S.T.A.R.S.
12,469 (2.88/day)
Jyväskylä, Finland
Damn those cathodes were fragile.. I remember that few ones broke when I used those. And the cable mess with the inverters etc.
I preferred all-red with lights back then :)
