- Oct 9, 2007
- 46,793 (7.63/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Zalman unveiled a pair of ATX mid-tower cases for stylish gaming PC builds. Measuring 207 x 533 x 541 mm (WxDxH), and weighing about 9 kg, the cases are made of steel and ABS plastic. Although packed with room for standard ATX and micro-ATX motherboards with graphics cards as long as 30 cm, the cases come with a support beam, which can be installed in three positions. The beam prevents bending of add-on cards.
Both MS800 and MS800 Plus feature six 5.25" and a common 5.25"/3.5"/2.5" bay, but while the MS800 has three fixed 3.5"/2.5" bays, the MS800 Pro gives them hot-swap capabilities using caddies. Both cases come with two 120 mm fans on top (LED-lit for the MS800 Pro), a 120 mm fan on the rear, a 92 mm fan bracket (MS800 Pro only), and a bottom 120 mm fan vent. Most fan vents are covered with dust filters. The front-panel includes two each of USB 3.0 (standard header), USB 2.0/1.1, HD audio jacks, and a 6-channel fan controller with a rotary knob and channel-selection feather-touch buttons. Slated for December, the MS800 is priced at US $88, and the MS800 Pro at $100.
![](https://www.techpowerup.com/img/12-11-15/140a_thm.jpg)
![](https://www.techpowerup.com/img/12-11-15/140b_thm.jpg)
![](https://www.techpowerup.com/img/12-11-15/140c_thm.jpg)
![](https://www.techpowerup.com/img/12-11-15/140d_thm.jpg)
![](https://www.techpowerup.com/img/12-11-15/140e_thm.jpg)
