- Oct 9, 2007
- 46,923 (7.61/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Do most pre-built CPU liquid cooler kits look the same to you? It's probably because they carry Asetek or Akasa design. Enter a refreshment in the pre-built arena: Zalman. The Korean PC cooling veteran unveiled Reserator, a liquid cooler which swaps the conventional-looking radiator for a high-performance heatsink with radially-projecting copper fins, in which the heat pipes are swapped with coolant channels. The contraption is ventilated by a 120 mm Zalman custom-design blue or red LED-lit fan, with PWM control. The CPU block features copper base with mirror finish, while its other parts are given aesthetic touches with chrome plating and LEDs. The cooler will be designed to handle thermal loads as high as 400W. It is slated for early-2013.
![](https://www.techpowerup.com/img/12-11-20/175a_thm.jpg)
