- Oct 9, 2007
- 47,291 (7.53/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
First spotted at the recent CES 2009 event, the Zalman VF2000 LED is incing towards launch. The Korean cooling specialist added a smart bit of innovation to this GPU cooler: it can also be used to cool a CPU. The VF2000 LED is a simplistic looking GPU cooler that is compatible with most GPUs such as the NVIDIA G9x and ATI RV700 series. Designed primarily for graphics cards, the VF2000 LED maintains a short profile. It measures 126x110x45 mm and weighs 290 g. Its construction is fairly simple, consisting of a contact block from which four heatpipes emerge, conveying heat to a dense aluminum fin array. The 90mm PWM-controlled, blue LED-lit fan is embedded into a circular cavity atop the array.
The provision of additional retention modules makes this cooler compatible with the Intel LGA-775 and AMD AM2/AM2+/AM3 sockets. However, the catch is that this cooler is recommended only for CPUs with rated TDPs below 110W, and hence can't be used for overclocking adventures on air-cooling, however, its slim construction sets it up as an ideal cooler for low-profile PCs. For the same reasons, this cooler is not provided with support for the LGA-1366. Matbe sourced some pictures from the cooler's official photo shoot. For more pictures, visit this page.
