Zen 4 iGPU - Memory Bandwidth Incorrect
1,682 (0.33/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
I just bought a new 7950X system and took a look at GPU-z. There's a few bugs I noticed (or maybe I'm just misunderstanding things)
  • The memory bandwidth is reported as double what it should be for DDR5-4800. 128 bit DDR5-4800 should be 76.8 GB/s.
  • My 3090 shows resizable BAR as enabled, but the iGPU shows it as disabled in the exact same system at the same time.
  • It shows 512MB as the memory size - that's the dedicated amount set in the BIOS but is that the correct way it should be reported since it's sharing system memory? I'm not sure that's wrong but I've never checked an iGPU before.
Great work on this software, as always. Just trying to report bugs to improve it for others.
AsRock
TPU addict
19,175 (2.98/day)
UK\USA
Cooling D15
I see the amount i selected in bios which is 4GB all so see system reserved ( task Manager ) is now 4.4GB so maybe look there and see how much reserved ram you have.
I don't have the driver installed for it as it was making problem with a game so. I just jumped in the bios picked 4GB and enabled it.
1,682 (0.33/day)
VR HMD HP Reverb G2
I just looked into the details of resizable BAR, it's apparently an unsupported GPU, so that's not a bug.
tabascosauz
8,219 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
GPU-Z only ever shows what is set in BIOS for iGPU, not a on the fly number
W1zzard
Administrator
28,181 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
This is totally expected. The BAR support is per-device, it's not universal. AMD confirmed to me that the IGP does not support resizable BAR. It really doesn't need it, because its memory is in the CPU's memory pool anyway
I felt like showing the number was better than showing "N/A" or "System Shared". I vaguely remember that on some platforms where I can't read the memory size I'm showing something like the former.
1,682 (0.33/day)
VR HMD HP Reverb G2
The logic behind AMD not supporting resizable BAR with IGPs makes sense. However, I've always found the use of the word "disabled" to be confusing because it implies that you can enable it. I think "unsupported" would be a better way to describe resizable BAR on these IGPs and older GPUs, but it's only a minor quibble.
Makes sense. I have no complaints.
Ruru
S.T.A.R.S.
13,330 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Agree on that, same goes with Crossfire/SLI these days.
9,671 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I am not sure if resizable BAR support even makes sense for iGPUs considering the memory is shared with the system.
