Zotac 4070 super trinity hotspot temperature
5 (0.00/day)
Hello guys. I recently bought this card and im a bit concerned about hotspot temp only.
Playing demanding games results in up to 68-69 degrees on GPU, up to 64-66 on memory junction and up to 86-87 on Hotspot
The pic below is taken after 10 minutes timespy stresstest.
GPU and memory seem like what one must expect for this card, looking around on YT videos and forums, but Hospot seem higher (usually hotspot hits like 79 max with a 11-13 delta).
Delta gpu/hotspot is 16 degrees in this case but I saw up to 17.5.
Is that delta ok? and is the hotspot temp itself normal?
Thx for replies
2,383 (6.42/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
It’s fine. If you are really bothered you can try to repaste the card or swap the paste for a PTM pad, but I wouldn’t worry too much. Hotspot readings can vary quite wildly between samples.
freeagent
8,597 (3.79/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I saw about 12-14c with mine. I put a Thermalright Heilos pad on and typically I see 10c spread between GPU and Hotspot.
MSFS 2020 still kicks the HS temp up to 80 with ~305w core and ~375w board power.
5 (0.00/day)
Hi, thx for replies.
I cant repaste now, the card has 1 moth, warranty would be lost.
But I think that u consider the situation pretty normal right? its not RMA matter righ?
Ruru
S.T.A.R.S.
12,829 (2.94/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Audio Device(s) Creative Omni BT speaker
VR HMD Oculus Rift CV1
Oh hell no that isn't high. I know that they can't be compared, but my 6700 XT still goes over 90C with hotspot temps even with a beefy aftermarket cooler, yet still not worried.
I'd be worried if your hotspot temps would be 20C higher, your current temps are totally fine.
42,324 (6.65/day)
Youre fine
Some parts are designed to run hotter yes, we can't compare apples and oranges though
1,382 (3.62/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Yep, looks normal. Nearly exactly what my MSI 4070 Super runs actually. No worries.
42,324 (6.65/day)
