Zotac 5090 Solid disabled ROPs
Wuxi-gamer
8 (2.67/day)
Hey guys. I'm desperate, I have spent such a big amount of money on this piece of hardware and got this. I don't know wtf is going on with my card. Because I couldn't find a problem similar to mine on the Internet, looks like nobody's ever dealt with this before.
The story:
Have been using this card for a while, no problem whatsoever, except one small thing: the ROP count in GPU-Z (and other programs like AIDA64 and HWinfo64) is incorrect, it's different from the official specs given by Nvidia. My card has only 168 ROPs, while a 'normal' 5090 has 176 ROPs. Initially I thought I was just a software glitch, that has nothing to do with the card's real perfomance... but recently I ran 3DMark and got some slightly underperforming results: about 13000-13300(while the average is about 14200 for users with the same HW config) which can be explained by the disabled ROPs.
What I have tried:
Reinstalling drivers with DDU
Reinstalling Windows
Switching VBIOS(my card has dual bios: a normal one and a silent one)
Nothing helped
Want to try to take off the gpu riser but not sure
My config:
CPU: AMD Ryzen 9800X3D no OC
RAM: G.Skill Trident Z5 ddr5-6400 48GBx2 XMP turned on
Mobo: Gigabyte X870E Pro Ice rev 1.1 with the latest BIOS
GPU: Zotec RTX5090 Solid (Non-OC version), installed on a gpu riser
Drivers: 572.42, the latest
PSU: Phanteks amp GH1200W ATX3.1/PCIE 5.1
GPU-Z 2.62.0(the latest one)
I'm at my wits end.
My guesses: 1)Corrupted VBIOS 2)A problem with the riser(but I think it's quite unlikely 3)Defective card(but how?)
14,345 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Is it a PCI-e 4 riser or 5?
6,144 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
This is extremely strange, paging @W1zzard ...
43,721 (6.78/day)
Reminds me of the 1060 line between 6gb and 3gb models where the 3gb got the screws to it in shaders, tmus, rops
7,629 (5.02/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
There are no alternate variants of the RTX 5090, the 5090 D is a separate SKU sold exclusively in China. I believe this is a glitch with GPU-Z, in any case, W1zzard should know better.
653 (0.13/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
This isn’t a 5090 D is it???
518 (0.97/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
Pcie 5, in gpuz it also shows as pcie 5.0 x8(because I’m using pcie ssd sharing lines with the card)
In your screenshot it's showing 2.0 x8. Is that just unloaded and it shows up correctly when there's a load on the GPU?
Ruru
S.T.A.R.S.
13,407 (3.01/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Most likely a bug in GPU-Z. COULD be a card with some weird bios from the manufacturer, but I highly doubt.
137 (0.28/day)
Processor 7600x -- 8600k
Motherboard MSI B650 -- ASRock z370
Cooling TR PA120 -- CM212
Memory 2x16GB -- 2x8GB
Video Card(s) PNY 4080 -- Zotac 2080ti
Display(s) LG C3 (42) + Acer XB271HU -- Sony X950H (49)
Case Torrent Compact Steel Panel -- Define R2
Power Supply BeQuiet Darkpower13 750 -- Seasonic X750
Keyboard Epomaker TH80SE/EK21 -- Logi G710+
Software Win10 (both)
I would test with the riser out of the equation.
65 (0.04/day)
Does not looks like D variant by device id
Code:
NVIDIA_DEV.2B85 = "NVIDIA GeForce RTX 5090"
NVIDIA_DEV.2B87 = "NVIDIA GeForce RTX 5090 D"
thats excerpt from drivers inf file
Btw, the difference of the D version is non-obvious "would any parameter displayed in GPU-Z be different for D version"
6,144 (0.84/day)
Ikenai borderline!
Mouse Logitech G604
The 5090D is identical in every hardware spec to the ordinary 5090, it's just BIOS or driver limited to have lower inferencing, same way as the LHR cards worked. So even if this was a 5090D it wouldn't matter, because it should still have 176 ROPS not 168.
Wuxi-gamer
8 (2.67/day)
Update.
Took out the riser, put the card in the pcie x16 mobo slot, even took out the ssd that was ‘stealing’ pcie lines from the gpu and now it’s pcie 5.0 x16
NOTHING changed, ahaha. So the riser is fine.
The result in 3DMark is almost the same. And the GPU-Z info is the same.
So I think it’s not a software bug, it looks like a firmware or hardware problem, that affecting performance.
But if I delete the drivers via DDU, I see this. The ROPs count is correct, it changes back to 168 only after I install drivers. Very interesting
zcyandrew
5 (5.00/day)
I tried to submit my vbios to online database, but it says BIOS reading not supported on this device.
UPDATE: I upgrade GPUZ to 2.63.0 and successfully upload my vbios to the online database.
7 (0.01/day)
System Name 2022-PC
Processor Intel Core i5 12400
Motherboard ASUS TUF Gaming B660M-PLUS D4
Cooling Corsair iCUE H150i ELITE CAPELLIX XT, 2x SP140 RGB ELITE, 1x SP120 RGB ELITE
Memory Corsair Vengeance RGB RS CMG32GX4M2E3200C16
Video Card(s) ASUS TUF GAMING RTX 3060 Ti OC 8GB GDDR6X
Storage Corsair MP600 GS 1TB, Samsung 980 500GB
Display(s) 2× AOC 24G2SPAE/BK
Case Corsair 4000D Airflow
Audio Device(s) Corsair Virtuoso PRO, Corsair HS65 7.1 Surround
Power Supply Corsair RM750x SHIFT
Mouse Corsair Sabre RGB Pro
Keyboard Corsair K70 RGB TKL
Seems like a driver or BIOS issue, but as the image above has, the BIOS and Driver are the same but has the correct amount of ROPs.
The computerbase image had a different BIOS "B5" and a press release driver.
W1zzard
Administrator
28,250 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
What's happening is that without an installed driver, GPU-Z will fallback to a hardcoded table, which has the expected ROP count
This is a reasonable approximation on virtually every card in the market, because such a discrepancy is very strange and has never happened in a long long time
858 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply Seasonic Prime TX-1600 ATX3.1 | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
Wuxi-gamer
8 (2.67/day)
Thank you very much for uploading your BIOS, dude, I downloaded it and compared it with mine(which I managed to extract too using the newest version of GPU-Z). And you know what? No difference at all, the files have the same size(I mean identical down to the byte). So VBIOS is probably not to blame here. But wtf is causing this problem... What a ridiculous situation.
zcyandrew
5 (5.00/day)
Thank you very much for uploading your BIOS, dude, I downloaded it and compared it with mine(which I managed to extract too using the newest version of GPU-Z). And you know what? No difference at all, the files have the same size(I mean identical down to the byte). So VBIOS is probably not to blame here. But wtf is causing this problem... What a ridiculous situation.I
I download an Asus bios, it also has same num of bytes(1,961,983). An easy way to check whether there is a difference is to choose "Submit to online database" when extracting bios. It will automatically check whether there are duplicates. If the bios is exact same, it will say there exists one in database.
By the way, is your card also made in Indonesia?
452 (2.14/day)
your card is internet-famous now dude.
you'll need RMA
what a crapshow of a launch. bricked cards, melted connectors, defective GPUs........ how is there no Q/C phase at tsmc/nvidia/zotac to filter out impaired dies ?
7,629 (5.02/day)
São Paulo, Brazil
I can't believe it's actually a hardware defect, I've never seen this before in all my life, what the hell is going on with this GPU's launch
Wuxi-gamer
8 (2.67/day)
you'll need RMA
I think I'm gonna wait for a Zotac/Nvidia response to the situation. My card was bought in Korea, while I'm in China, so RMA'ing the card can be difficult and time-consuming, especially now when there is a big shortage of 5090's so I'm not sure if I can get a replacement quickly. Maybe wait several months, I mean, I still can use the card and play games without any problems, so I'm not in a hurry.
zcyandrew
5 (5.00/day)
Have you checked if my bios is different from yours ? If they are same, then the issue is probably on the die.
