- Oct 9, 2007
- 47,189 (7.56/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
ZOTAC unveiled a new bells and whistles-laden GeForce GTX 650 graphics card in the Greater China region, the GTX 650 Destroyer TSI (twin, silent, intelligent). The card combines a custom-design PCB with a sporty high-performance cooling solution. The PCB packs a strong (relative to this GPU) 3+1 phase VRM to power the factory-overclocked GPU.
The GPU is clocked at 1071 MHz, and the memory at 5.00 GHz. The card packs 2 GB of GDDR5 memory across a 128-bit wide memory interface. It relies on a 6-pin PCIe connector for power. Display outputs include two DVI, and one each of HDMI and DisplayPort. Moving on, the TSI cooling solution appears use a large monolithic aluminum heatsink ventilated by a pair of 70 mm fans, and a sporty cooler shroud that keeps up with the color scheme of its Extreme Edition cousins, which lends it a high-end feel. Pricing and availability is under the wraps, although this one is most likely meant only for Greater China.
