ZOTAC GeForce GTX 680 Extreme Edition Pictured
47,166 (7.56/day)
ZOTAC is flexing its engineering muscle. First, it was talk of a 2 GHz GeForce GTX 680 by one of its senior executives, and now this, ZOTAC GeForce GTX 680 Extreme Edition. Pictured below, the card's design is reminiscent of the crazy engineering endeavors ZOTAC China undertakes, to come up with some extremely powerful designs, which seldom get out of the APAC region (to EMEAI and NA regions).
ZOTAC took a top-tier binned GK104 GPU, 2 GB of high-grade Hynix GDDR5 memory chips, and paired them with a 12-phase VRM power supply. Apart from bleeding-edge International Rectifier GaNpowIR driver-MOSFETs, the VRM uses server-grade tantalum capacitors, and FPCAP multi-phase capacitors. To drive it all, ZOTAC used CHiL CHL8318 VRM controller.
Apart from consolidated voltage measurement points, the card also features a special native logic that takes input from a USB control module. Called OC+, ZOTAC will bundle the card with a front-panel OC module that probably fits into a 5.25" or 3.5" exposed drive bay, gives you hardware control, and real-time diagnostic information about clock speeds, fan speeds, and voltages. The card ships with a swanky-looking air-cooler, which uses two fans to ventilate a dense aluminum fin array, which draws heat using copper heat pipes.
ZOTAC claims world-records will be set, and broken, using this card, although it did not give out details of its out-of-the-box clock speeds.
INSTG8R
Vanguard Beta Tester
8,039 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Well it may not hit 2Ghz but it's certainly got some beefy parts that should make for some pretty good overclocks.
126 (0.03/day)
System Name Mein pride und joy
Processor Ryzen 5 3600
Motherboard GigaByte Aorus X570 Elite
Cooling Cryorig H7 Ultra
Memory Kingston HyperX DDR4 16GB CL15
Video Card(s) Sapphire RX5700 Pulse
Storage Samsung 850 Pro 256 / Samsung 860 Evo 500 / Seagate 1TB
Display(s) BenQ XL2430T
Case Fractal Design Define R5 Blackout Edition
Audio Device(s) Onboard / Asus Xonar AE
Power Supply Seasonic SSR-650RM
Well damn, this thing sure looks like a beast to me. 6+8 power, how much tdp this thing has now?
1,742 (0.30/day)
on top of that big mountain on mars(Romania)
System Name ( . Y . )
Tdp is not measured by how many power conectors a card has, they are there for increased oc limits and safety.
MxPhenom 216
ASIC Engineer
13,006 (2.51/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Well id think its still 195. The 6+8 power just allows for more power overhead for overclocks.
babash*t
74 (0.02/day)
Nairobi, Kenya
System Name Baba
Processor AMD FX 8120 @4.2Ghz
Motherboard MSi 990FX GD65
Cooling Thermaltake Frio
Memory 2x4gb Corsair Vengeance LP
Video Card(s) Sapphire HD 7870 2gb
Storage 500GB WD blue + 2x2TB WD green
Display(s) 2x AOC i2353Fh IPS LED Monitors
Case Generic
Power Supply CoolerMaster GX650 Bronze
Software Win 7 Ultimate 64bit / Win 8 64bit Release Preview
The smaller companies are where to look for beautiful cards(zotac n palit) if I were to switch sides completely to nvidia, I take this(or the palit jetstream) over anything gigabyte/asus...just by aesthetics alone
2,318 (0.40/day)
Texas
System Name Mr. Reliable
Processor Ryzen R7 7800X3D
Motherboard MSI X670E Carbon Wifi
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Bitspower Blocks
Memory 32Gb (2x16Gb) GSkill Trident Z5 DDR5 6000 Cl30
Video Card(s) Asus Tuf 4080 Super
Storage 4 x Crucial P5 1TB; 2 x Samsung 870 2TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
This has some amazing components on it...and on top of that I think that has to be the sweetest looking cooler I have seen in a VERY long time.
746 (0.12/day)
LOVE the "industrial" looks of this card! Seems to be pretty hardcore too, with the server-grade components and all, which is awesome for those of us running BOINC/Folding@Home 24/7 on their GPU's. :cool:
137 (0.03/day)
Cheonan, South Korea
System Name Youtube Machine | Jellyfin Server | Not so retro PC
Processor Ryzen 5 5600X | Athlon 200GE | Athlon X2 270
Motherboard B550M DS3H | A320 Pro-VD/S | N68S-UCC
Cooling Hyper 212 Turbo | Stock Ryzen 5 cooler | Stock
Memory 32GB Klevv 3600mhz | 16GB Team 2666mhz | 2GB DDR2 800
Video Card(s) RX 6600 Eagle | Vega whatever igp | HD 7770
Storage 2x SX8200Pro 512gb | 8TB of scavenged HDDs | 1tb laptop hdd
Display(s) rmmnt30hfcw + S24F350
Case CM Q300L | Old Pentium 4 PC Case | old case
Power Supply PA-5B1B | S12III | 1stplayer "80+" time bomb
Mouse Loigtech G502
Keyboard Corsair Strafe | $8 wireless MK combo
Software Win11 | OMV | WinXP
Benchmark Scores I don't like Gigabyte
this card looks amazing
571 (0.12/day)
Islamabad
System Name Hhumas-PC
Memory OCZ Platinium 2x2GB
Display(s) Dell U2410F
Case Casecom
Power Supply Corsair HX1000
amazing this front panel is kind of sexy
961 (0.17/day)
Currently somewhere around NSW, Australia
System Name hmmm... / lappy (ASUS Scar III)
Processor Intel Core i7-8086K / Intel Core i7-9750H
Motherboard ASUS Maximus XI Formula / ASUS G531GW
Cooling Noctua NH-D15s w/ 2 x Noctua NF-F12 PWM Chromax and 1 x Noctua NF-A15 HS-PWM Chromax Fans / Stock
Memory 4x16gb G.Skill Trident Z DDR4 3600mhz / 2x16gb Kingston Hyper X Impact DDR4 2666mhz C15
Video Card(s) 2 x EVGA GTX 1080 TI FTW3 / Nvidia RTX 2070 8gb
Storage 2 x Samsung 960 EVO Plus 1tb NVME/ 1tb Intel SSDPEKNW010T8 NVME + 2tb Samsung 860 EVO SSD
Display(s) Acer Predator X34P / ASUS 15.6" Screen
Case Fractal Design Meshify S2 White-TG + Noctua Chromax Fans / ASUS Scar III Case
Audio Device(s) Onboard + Logitech Z623 / Onboard
Power Supply Seasonic Prime Ultra Titanium 1000W + PROLINK PRO903WS / ASUS ADP-230GB B Power Brick
Mouse Corsair Vengeance M65 PRO RGB / Logitech MX Anywhere 2S
Keyboard Corsair K70 LUX RGB / ASUS Scar III Keyboard
Software Windows 10 Professional x64 / Windows 10 Professional x64
Awesome looks and awesome components... :) I hope our dear leader gets one for review... :)
theonedub
habe fidem
8,027 (1.42/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Software Windows 10 Pro x64 || WIndows 11 Pro x64
Its as if they beat MSI to creating a 'Lightning' class of card. Well done, Zotac.
1,259 (0.25/day)
Looks like a very nice and clean card. You can tell it was designed with passion and care.
(Except the fans, and I'm a bit worried about the noise output of those tbh.)
9,900 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
its interesting how they add more pcb area on the top of it and it makes the card looks pretty extreme,
i guess we need some benchmark to figure it out
2,872 (0.48/day)
Northants. UK
System Name Bad Moon Ryzen
Motherboard Asrock B450M Pro4-F
Cooling Vetroo V5
Memory Crucial Ballistix 32Gb (8gb x 4) 3200 MHz DDR 4
Video Card(s) 6700 XT
Storage Samsung 860 Evo 1Tb, Samsung 860 Evo 500Gb,WD Black 8Tb, WD Blue 2Tb
Display(s) Gigabyte G24F-2 (180Hz Freesync) & 4K Samsung TV
Case Fractal Design Meshify 2 Compact w/Dark Tempered Glass
Power Supply MSI MPG A850GF (850w)
VR HMD Rift S
Card looks fugly to myself but I'm interested to see how far people can clock these :)
21 (0.00/day)
Indonesia
System Name Red Lightning
Processor Intel i5-3570K @4.0GHz
Motherboard Asrock Z77 Extreme4
Cooling Cooler Master Seidon 120V
Memory Gskill Ripjaws 8GB dual channel 1600MHz
Video Card(s) ASUS GTX 650 Ti
Storage PLextor M5S 128GB + WDC Black 1TB Sata3
Display(s) Dell SE2417HG
Case Cooler Master HAF 912 Advanced
Audio Device(s) Asus Xonar DG
Power Supply Seasonic M12-II 620W
Mouse Steelseries Rival 95
Keyboard Ozone Strike
Software Windows 10 Home
seems like MSI Lighting board :D
5,250 (0.87/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
i can't expect 2Ghz GPU core speed, but i hope
359 (0.08/day)
Edit your post bta!
Dear Mr. Kwai,
Yesterday we sent out a memo which inadvertently stated 2Ghz rather than the intended value 1.2Ghz for the overclocked GTX 680 speed. We sincerely apologize for any inconvenience this may have caused.
Sincerely,
Zotac Engineering
951 (0.19/day)
System Name Little Boy / New Guy
Processor AMD Ryzen 9 5900X / Intel Core I5 10400F
Motherboard Asrock X470 Taichi Ultimate / Asus H410M Prime
Cooling ARCTIC Liquid Freezer II 280 A-RGB / ARCTIC Freezer 34 eSports DUO
Memory TeamGroup Zeus 2x16GB 3200Mhz CL16 / Teamgroup 1x16GB 3000Mhz CL18
Video Card(s) Asrock Phantom RX 6800 XT 16GB / Asus RTX 3060 Ti 8GB DUAL Mini V2
Storage Patriot Viper VPN100 Nvme 1TB / OCZ Vertex 4 256GB Sata / Ultrastar 2TB / IronWolf 4TB / WD Red 8TB
Display(s) Compumax MF32C 144Hz QHD / ViewSonic OMNI 27 144Hz QHD
Case Phanteks Eclipse P400A / Montech X3 Mesh
Power Supply Aresgame 850W 80+ Gold / Aerocool 850W Plus bronze
Mouse Gigabyte Force M7 Thor
Keyboard Gigabyte Aivia K8100
Software Windows 10 Pro 64 Bits
2,516 (0.48/day)
Canada
Interesting design, i don't understand the purpose of the board layout and think it may actually cause some installation problem's in certain system's. Nice to see implementation of better component's
658 (0.09/day)
it has IR powerstages too! that Chil PWm is a pure 8+0 phase PWM, and i guess they are using 4 phase for memory power? That is an expensive VRM, so gorgeous.
3,946 (0.63/day)
Police/Nanny State of America
Processor OCed 5800X3D
Motherboard Asucks C6H
Cooling Air
Memory 32GB
Video Card(s) OCed 6800XT
Storage NVMees
Case Freebie glass idk
Audio Device(s) Sennheiser
high binned or not, it's not like it's going to OC amazing without extreme cooling
