Zotac RTX 3070 from an OEM machine, VBIOS for Resizable BAR
Bjoolz
6 (0.01/day)
I haven't found anyone brave enough to test a BIOS update for this card, at least not reporting back afterwards, so I was hoping someone here might offer their suggestions. It was bought used standalone. Originally from a Medion Erazer Engineer X10. I have never flashed a VBIOS before so I'm borderline clueless here.
This is what it reports as in GPU-Z: https://www.techpowerup.com/gpu-specs/zotac-rtx-3070-medion-erazer-oem.b9201
This is the sticker on the back:
And it looks like a Zotac RTX 3070 Twin Edge (Seller's pic, I have cleaned it after receiving it):
The current VBIOS is from 2020 so the lack of support is definitely from the VBIOS. I contacted Zotac's chat and while trying to help they didn't have information on it and couldn't guarantee it would work. The machine it's in at the moment doesn't have an integrated GPU so a failed flash would be really annoying.
43,187 (6.74/day)
Put it on graphics card tab and screenshot it please
11 (0.01/day)
EU
Processor i5 14600KF
Motherboard PRO Z790-A MAX WIFI
Cooling SMX Snowy Blackout 360
Memory Lexar 32GB 6400MHz CL32 Ares Gaming RGB
Video Card(s) RTX 4070 Ti SUPER 16G GAMING X SLIM
Storage Sabrent Rocket 500GB + KINGSTON SNVS2000G 2TB
Display(s) Samsung G55A
Case PREYON Nest Meshy+
Audio Device(s) Sound Blaster AE-5
Power Supply be quiet pure power 12M 1000W
Mouse Glorious Model 1
Have you tried this ? : https://www.zotac.com/files/download/by_product?p_nid=959406&driver_type=238&os=All
Your card looks like standard Zotac card :)
7,598 (1.77/day)
Well if you can't afford to lose the card, even temporarily, then just avoid this? Rebar doesn't impact performance that much any way, low single digits at best.
Bjoolz
6 (0.01/day)
Yeah, I was hoping someone would know if it really was just a standard Twin Edge, I'm not going to take a chance.
7,228 (1.08/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Buy cheap second hand gpu off ebay. Not more than a dollar plus postage
3,203 (2.38/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
i would just not do it at all, there is little point in going through all that trouble, performance isn't worth it
7,228 (1.08/day)
Sometimes explorers need to venture and experiment even if there are no performance gains, experience is acquired.
Push the boat out! @Bjoolz
2,231 (2.64/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
If it is a Twin Edge, the tool from Zotac should update it (almost) risk-free. If the BIOS file doesn't match it shouldn't proceed.
I know it because I updated the VBIOS on my 3070 Twin Edge OC on ZOTAC's recommendation.
Bjoolz
6 (0.01/day)
I saw on the 3080 at least they removed or changed this because a lot of people were unable to update due to BIOS mismatch. Not sure if they just added a lot more versions it checks for or removed the check.
I went super cheap on my build this time, got a used PC with a 5700x and a tiny b550 board dirt cheap and it only has a single spare 1x slot which is basically underneath the GPU fans. So I would almost have to go for a USB VGA adapter.
7,228 (1.08/day)
43,187 (6.74/day)
153 (0.08/day)
System Name Locutus TT P90 open air case
Processor Intel I7 12700K
Motherboard Asus Z690 WIFI D4
Cooling NZXT 280 mm AIO
Memory 32 Gig Corsair Vengeance 3600 DDR4
Video Card(s) Zotac 3080 Holo LHR
Storage 3 various branded SSDs and 6 TB Seagate HD
Display(s) LG 32'' g-sync 144 Hz VA IPS
Case P90 open air case
Power Supply EVGA G2 1 KW
Mouse Logitech G900
Keyboard Corsair Strafe
Software Win 11 Pro
Just enable resizable BAR in your MB BIOS settings. Flashing card is risky IMHO. Zero perceivable diff in gaming for me with BAR on.
2,231 (2.64/day)
Brazil
Not enough. Early VBIOSes on Ampere cards weren't ReBAR enabled.
43,187 (6.74/day)
Until user gets a spare gpu, no point in trying to do anything
Bjoolz
6 (0.01/day)
I have messaged some other users with the same GPU that tried finding the same answer on reddit and Medion's forum and if they reply back I'll post it here.
Count von Schwalbe
Nocturnus Moderatus
3,227 (2.78/day)
Knoxville, TN, USA
It has a custom subsystem ID, so any reflash would require bypassing the safety checks that could prevent flashing the wrong BIOS.
43,187 (6.74/day)
Do not do it until you have a backup plan
