- May 24, 2023
- 732 (1.95/day)
I think it would be practical to have threads for manufacturers to visit and see the ideas of customers in one place.
I will make a first one for Alphacool with one idea of making a different version of a current product and one idea for a new product:
1) I am thinking about making an external enclosure for radiators, and for that I would need a parallel distribution block to connect all radiators to.
I noticed that Alphacool ES Distro Plate Parallel C5 has a weird (and IMO useless) pass through in the corner, would not it be better to make a completely universal parallel distribution block version? Current version up, suggestion below:
2) Speaking about external radiator boxes, why not make some boxes for a few most common sizes of radiators?
- They would have openings for radiators on all 4 sides, with an option to clip on dustfilters.
- Some plates (two?) should be supplied to block momentarilly unused rad openings
- The ceiling would be supplied in two versions, one highly perforated for the fans on each rad and the second with a cutout for one fan for a semi-passive operation
- In the bottom there should be pre-mounted parallel distribution block, possibly with just 4 inlets and outlets and a little prolonged on one side, so that rad connections area is in the middle of the bottom of the box and the side with common inlet and outlet reaches the side panel of the box.
- They could be supplied as flatpacks.
- I have not researched how a chimney effects works in such enclosures, but an optional upper extencion could be sold to facilitate this effect for a completely passive operation
- Some (optional?) fan hub with sufficiently long power and PWM leads to the PC would also be useful.
