Need help regarding connecting Meta Quest 3 to USB-C port on MSI motherboard
AQuirkyZee
1 (0.01/day)
Thank you for taking the time to help me out.
My issue is that I don't know exactly how much power my MSI motherboard USB-C port delivers.
It can never fast charge neither my phone which support 30W fast charging, nor anything else, I find this problematic when connecting the Meta Quest 3 via cable link to the pc using the usb-c port. the battery drops as if it's not plugged ,albeit at a slower rate.
The USB-C version is 3.2 I didn't manage to find out which generation, and whether it supports power delivery or not. Nothing in BIOS that indicates either.
The MSI motherboard is PRO B760M-P
I would be extremely grateful if anyone could help me figure this out, thank you for your time.
18,058 (2.69/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
Your motherboard has 1x USB 3.2 Gen2 Type C (Rear).
You might need a better cable.
318 (0.49/day)
Generally motherboard rear USB-C ports do not support power delivery (30w). There are add-in PCIe cards that can do this but they are quite expensive. An alternative is a phone charger or similar capable of delivering at least 30w with fast charging.
18,058 (2.69/day)
IIRC fast charging wouldn't work with a cheap thin cable I used before, later on it worked with a thicker/better cable.
