Acer Nitro 5 i7 9750H RTX 2060 overheating despite cleaning fans and repasting and undervolted
4,441 (3.90/day)
Colorado, U.S.A.
System Name HP Compaq 8000 Elite CMT
Processor Intel Core 2 Quad Q9550
Motherboard Hewlett-Packard 3647h
Memory 16GB DDR3
Video Card(s) Asus NVIDIA GeForce GT 1030 2GB GDDR5 (fan-less)
Storage 2TB Micron SATA SSD; 2TB Seagate Firecuda 3.5" HDD
Power Supply 12V HP proprietary
Tried with the case open? and what temperatures are you seeing?
KaloGhoda
3 (0.01/day)
tried as in? used while the case is open? nope
even in the throttlestop app ive been seeing the hot, protochot 92 and power warnings
4,441 (3.90/day)
Colorado, U.S.A.
Memory 16GB DDR3
Try it and also with a fan blowing into the open case (as diagnostic measures)
KaloGhoda
3 (0.01/day)
temps go about 96 C for cpu and about 88 for GPU, the throttling for both of them goes insane with extreme stuttering dude to massive clock speed drops
am i doing something wrong here??
9,340 (6.08/day)
Louisiana
Keyboard G710+x3
You might post to the actual machine
Nitro is a laptop series isn't it so leaving the case/ bottom open is not wise hehe
Seems you should use better paste or at the least detail what you did use
1,298 (0.90/day)
Do not use too thin (liquid-like) thermal paste; use more dense one, but fine, thin layer, so it stays where it is supposed to. I've used white silicon (?) based from a local factory that produced telephony equipment and it works well.
4,441 (3.90/day)
Colorado, U.S.A.
Memory 16GB DDR3
8,989 (3.36/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
GPU temperature is to be expected, CPU is probably throttling because of the low 45W TDP limit rather than temperature. You can try to use ptm7950 for better temps but I am afraid it's not going to get much better.
