ATItool 0.26 and BETA does not work for me
453 (0.08/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
I have never had issues with ATItool working in other systems before, but this time I am stuck.
I have a ASUS 9800GT Ultimate card in my new build and would like to find its highest stable clock rates. At any rate, ATItool says that it cannot access the video card and then proceeds to give me 0MHz clocks. The artifact scan button will do nothing and the Show 3d view button also does nothing.
Any ideas?
I can OC the card fine with Precision; I would just like a fast way of stability testing it.
Vista 32 SP1 FWIW.
You can view the build here:
http://www.techpowerup.com/gallery/1848.html
Specs here:
http://www.evga.com/community/ModsRigs/comment.asp?sysid=13223
Kursah
Super Moderator
14,691 (2.28/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Run as administrator and see if that helps.
I was able to run .26 and betas just fine in Vista x86 and x64 at least most of the time. If you cannot get it to work, download and use the stability test in Fur Mark, it's a more stressful test along the same lines. Also I have UAC turned off, that might help...dunno...haven't used ATI Tool in a while.
:toast:
453 (0.08/day)
Pacific Coast
Mouse EVGA TORQ X10
:toast:
I didn't try running it as admin, but have never had to do that in the past. I have user account control off; it's one of the first things I turn off -- that and the page file.
I have switched to Fur Mark; thank you. Fur Mark should do the job.
WarEagleAU
Bird of Prey
10,812 (1.65/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
I Cant get mine to work properly either or install properly. Makes a big smarm about not having a digital driver signed.
