Case front panel has 1x USB C and 1x USB 3.0, motherboard only has USB 3.0 header
5,202 (0.92/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
Hey guys, I have a slight issue with my new build. I have an H210 case that has 1 USB C and 1 USB 3.0 connector. My motherboard only has a single 20-pin USB 3.0 header so I'm scratching my head trying to figure out how to get the USB C front panel port connected as well. I do not have room for expansion cards since it is a mini ITX build.
My only option seems to be buying something like this or this and then converting one of the 20-pin USB 3.0 male headers with something like this. This sounds like it would work in theory, but would I run into any issues?
Also... is there a cheaper way to do this without spending $50 in adapter cables? It seems like such a silly way to spend money. At that point, it might make sense to just switch to another motherboard.
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
the C port is 3.1, so if you only have usb3, it wont be full speed*not sure if it would even work)..unless im mistaken ofc
5,202 (0.92/day)
Case Dan Case A4
Mouse Logitech G603
the C port is 3.1, so if you only have usb3, it wont be full speed..unless im mistaken ofc
I don't particularly mind that it isn't full speed, but I'd rather be able to plug something in and have it be functional (if only at partial speed).
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
actually i dont think this would even be an option, i didnt pick up on the fact that you want to use the usbC port, sorry
i know its not optimal, but have you considered a USB pass-through?
obviously free is the best outcome.....itx limits options, not wanting to upgrade a MoBo just for this does as well, but a pass through is a solution, just not a pretty one. im sure we all had cases from that period when usb front panel support was trash :laugh: *assuming ofc you have rear 3.0*
the splitter may be your best bet
newtekie1
Semi-Retired Folder
28,473 (4.12/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I'd pick up one of these instead of those Y cables. The issue with the Y cables is there is no logic built into them. If you plug two things into the same header on the motherboard, things start to fry. And in the case of the USB-C what port on the header you are using will depend on which direction you insert the cable.
  • Like
Reactions: xvi
8,194 (2.18/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
The right motherboard for the right case! :D
