Cpu not running at full speed!
1,595 (0.36/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 9 5900X / Ryzen 7 2700
Motherboard Strix B550i / B450i Aorus Pro
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair LPX 2x16 3600MHz / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Acer Z301c / 39" Panasonic HDTV
Case Corsair 2000D / Cougar QBX
Audio Device(s) Yamaha RX-V379 / Realtek ALC1220
Power Supply Corsair SF600 / BeQuiet SFX Power 2 450W
Mouse Logitech G900
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
i can even play cod boII at highest settings
I highly doubt it, my HD5770 was struggling quite a bit with everything turned up, I can only imagine how badly it runs on yours
56 (0.02/day)
System Name Custom
Processor Intel Pentium E2200 @ 2.20GHz
Motherboard LORD ELECTRONICS CO.,LTD. 945GM ICH7 Series (Socket 775)
Cooling 1 Fan
Memory 4.00GB Dual-Channel DDR2
Video Card(s) 2047MB Gainward NVIDIA GeForce GT 610
Storage 232GB Hitachi HDP725025GLA380 ATA Device (SATA)
Display(s) SMB2030 (1600x900@60Hz)
Case Frontech
Audio Device(s) Realtek High Definition Audio
Power Supply Frontech
Mouse TechCom
Keyboard iBall
Software Windows 7 Ultimate 32-bit
cod bo II runs smoothly with high fps(below 50fp and above 35 fps) on my pc but all games have stuttering don't know why but i didn't had that problem with my previous gpu
So it's this motherboard with 2 RAM slots: http://e-spectrum.in/products/es-mb-g31/92/ ?
So you are using 2x2GB DDR2 sticks and it only shows 3GB on 64bit windows
yes
This screams "bios issue" to me. He likely needs the latest version.
where i can download the latest version of phoenix bios?
Could be that the IGP is set to use 1GB of memory, although I've never seen a G31 BIOS that could do that. Can you reset the BIOS to its default settings?
how can i set IGP and what about the cpu speed?
20,836 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64 / Windows 11
You don't want just the "phoenix bios." You want your motherboards specific latest bios.
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
but at the mobo site there is no option for downloading bios updates even they have no option for drivers.
Ebo
778 (0.19/day)
Nykoebing Mors, Denmark
System Name the little fart
Processor AMD Ryzen 2600X
Motherboard MSI x470 gaming plus
Cooling Noctua NH-C14S
Memory 16 GB G.Skill Ripjaw 2400Mhz DDR 4
Video Card(s) Sapphire RX Vega 56 Pulse
Storage 1 Crucial MX100 512GB SSD,1 Crucial MX500 2TB SSD, 1 1,5TB WD Black Caviar, 1 4TB WD RED HD
Display(s) IIyama XUB2792QSU IPS 2560x1440
Case White Lian-Li PC-011 Dynamic
Audio Device(s) Asus Xonar SE pci-e card
Power Supply Thermaltake DPS G 1050 watt Digital PSU
Mouse Steelseries Sensei
Keyboard Corsair K70
Software windows 10 64 pro bit
goto your manufactures website of your motherboard, find the correct 1, and look under download. If you cant find it by yourself, you can try and use cpu-z, normally it will tell you who it is.
http://www.cpuid.com/softwares/cpu-z.html
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
originally why mobo is e-spectrum g31 while cpu-z says its lord electronics mobo and on google i cant find lord electronics website
19,366 (3.68/day)
can i have a fix for my problem plzzz? i cant game smoothly its annoying me and also i can even play cod boII at highest settings so my specs aren't the problem.
You are being answered in your duplicate thread, aren't you??? I'm not going to help in this thread and the other. Moderators need to merge the threads...
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
but there they are trying to solve my cpu and ram issue and here the stutter problem.
INSTG8R
Vanguard Beta Tester
7,970 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Yes....:shadedshu:
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
8,213 (1.35/day)
Mouse Logitech G604s
Have you tried just reinstalling windows? Drivers? Video card drivers more specifically? The more newer titles you try and play, the more demanding they are/become. I know you dont want to hear someone say you need to upgrade, but it has to happen at some point.
can you merge my both threads?
Does it say moderator of any kind under his avatar?
Ebo
778 (0.19/day)
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
nope
8,213 (1.35/day)
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
18,025 (2.68/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
okay, so you are in a bit of troubble, so mabye this little programme can help you out :).
https://www.slimwareutilities.com/slimdrivers.php
"What it does: SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. "
It does not update a BIOS.....
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
You just said you didn;t...
Yeah, unsubscribed... good luck!
what? i tried updating my video card drivers and installed windows 4 times then what should i do!
8,213 (1.35/day)
tried both the options
You litereally just quoted me and said you didnt.
Im probably going to get infracted for this, but I dont care. You're an idiot. I will no longer post in your threads trying to help you. You came here asking for advice. In TWO threads and when people present you with options you pull this shit. DONE.
Good luck.
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
so how do i update my bios
Good luck.
i was answering to your moderator question that you asked "Does it say moderator of any kind under his avatar?"
18,025 (2.68/day)
8,213 (1.35/day)
There was more than one question in there and you gave a blanket response of "nope". That to us, tells us you didnt try updating drivers/reinstalling windows and you also made 0 mention that I saw stating otherwise before I even posted here.
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
sorry i am really sorry. my bad. but i tried updating gpu drivers and reinstalling windows.
You need to contact these people here: http://e-spectrum.in/products/es-mb-g31/92/ , use the contact form or:
i'll try
8,213 (1.35/day)
Then it can only be 1 of two things. You have a dying hard drive that you need to run diagnostics on to find out for sure, or you just need to upgrade your system. I believe RCOON said something about your CPU speed dialing back to 1.5GHz from 2.5 or whatever the stock speed is. That could also be an issue.
Outside of those 3 things, I dont see anything else.
56 (0.02/day)
System Name Custom
Cooling 1 Fan
Case Frontech
Mouse TechCom
Keyboard iBall
i bought a new hard drive a few days ago hoping that it will fix the problem but no luck.yes my cpu speed went from 2.2ghz to 1.47ghz and ram from 4.00gb to 3.00gb after replacing my mobo with a new mobo. see my other thread http://www.techpowerup.com/forums/threads/cpu-not-running-at-full-speed.217530/#post-3370869
