Developers of Outpost Infinity Siege Recommend Underclocking i9-13900K and i9-14900K for Stability on Machines with RTX 4090
21,211 (5.98/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
I never done any undervolting in my life but I can’t see in which world it would increase the stability of the system. If anything it should worsen it?
Less heat, less boost is generally better stability. Lowering the voltage curve isnt going to impact stability as long as there is enough for a given frequency. Too much voltage is not adding stability either: its either stable or its not.
In older system, yes, of course. In newer "auto overclocking" ones this often means auto downclocking, not a system that tries to maintain same clocks no matter what.
Or the undervolt provides needed temp headroom to boost better/higher. Thats when you know a part was pushed too much at stock settings.
732 (1.96/day)
Undervolting a CPU limited by power or thermal limit will increase the frequency the CPU runs at. It is good for overclockers ONLY. It does not decrease the strain and it decreases voltage safety margin for stability.
7,163 (1.45/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Video Card(s) Sapphire Pulse RX 7900XTX + under waterblock through Kryosheet
Storage Optane 900P[W11] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO[FEDORA]
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 40
Actually, both Intel and motherboard manufacturers are at fault here, in my opinion
Yes, but then don't bill us 500-1000$ for a product that doesn't deliver what it actually advertises, it is against the consumer law. Yet they segregate, make multiple rubbish products, limit us and basically blackmail us into spending more if we would like more logic(less pain in the arse) pcie or power header, IO layout. Release like ~3 boards and concentrate on delivering quality... but naah... last years economy class was all about flooding the market and we took the bait.
I don't blame Intel nor AMD, GPUs are totally fine consuming more, so it can work for a consumer device with no issues if you design it properly. It's all about quality control, proper testing and cheaping out.
6,819 (1.68/day)
Actually no, it can be stable & unstable at the same time ~ or so says something something quantum o_O
Also technically you can't test the number of possible combinations of software &/or hardware on any system to test all plausible causes of instability ~ the possibilities are literally endless. Most "stable" PC's are functionally/practically stable though not theoretically.
896 (0.14/day)
Round Rock, TX
System Name Teh Beast
Processor Intel i9 14900K | 7800X3d
Motherboard Asus STRIX Z790E-E | Strix B650E-F
Cooling NZXT Kraken Elite 280 | Kraken Elite 280
Memory 64GB G.Skill T5 6400Mhz | 32GB G.skill 6000mhz
Video Card(s) Sapphire 7900XTX Pulse | 4070 Super
Storage 1X 1TB SN850X - 1 X 4TB SN850X - 2 X 2TB 980 Pro
Display(s) LG 38" 38GL950G + LG 27" 27GP83B-B
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
I'll bet underclocking is not even needed.
Limiting the CPU to intel defaults of 253w and maybe even setting iccmax to 307 amps (also default) would likely solve the issues.
Motherboards defaulting to such insane power settings these days is totally insane to me.
201 (0.13/day)
Reports are it's actually only individual CPUs having a problem, and a replacement CPU solves it. Which suggests that any tweaking of BIOS settings is really just hiding the problem.
9,340 (5.98/day)
Louisiana
Keyboard G710+x3
Pushing these chips so they can get back the gaming crown from x3d f-stability hehe :pimp:
353 (0.09/day)
You limit the power draw, that's how it's done.
35 (0.03/day)
If the issue is motherboards running CPUs at settings above stock, then it's normal that some would work better than others.
201 (0.13/day)
Default settings are always conservative as per Intel's detailed settings. If Intel misjudged how sensitive some CPUs are then it's on them to resolve and pass on to the board partners. Or provide replacement CPUs free of charge.
9,340 (5.98/day)
Louisiana
Keyboard G710+x3
RMA already does that if used although shipping to Intel costs the buyer.
Issue is later batch chips usually from Taiwan sp65+- are always worse than early release chips usually from China sp90+-
So all these poor performing chips you may get a worse batch hehe
2,212 (0.74/day)
That pairing of hardware is asking for problem. You're pairing two pieces of hardware that are both known to be hot and power hungry teetering on the edge of instability. Mix in poor quality and/or underfed PSU or anemic MB and you've got a power keg situation. Plus you've got MB makers doing really idiotic things with stock bios settings.
2,740 (1.41/day)
UK, Leicester
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Video Card(s) 3080 RTX FE 10G
Storage 1TB 980 PRO (OS, games), 2TB SN850X (games), 2TB DC P4600 (work), 2x 3TB WD Red, 2x 4TB WD Red
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
It uses Unreal Engine 5 and the developers of Unreal Engine 5 themselves (the RAD/Epic Games Tools) noted problems with recent Intel CPUs:
Blaming it on the devs is funny. Intel responded and advised Intel owners to avoid the problem by changing some BIOS settings.
Translation, its a UE5 problem and the game devs are parroting what the engine devs said.
In a more serious mode one could argue when you have a power rail type issue, whether its bad VRM, and PSU or whatever, then underclocking a CPU (or GPU) can fix issues, but is this what is really about and if it is, its a bit misrepresentative as its presented as a problem that would be generic or a flaw with the platform rather than a workaround for specific hardware combinations.
167 (0.35/day)
Lake Superior
You're free to think that but why would Intel's CPU begin returning different results at different clock rates?
And why would Intel respond with settings to change to avoid the problem and also replace CPUs if you show them this issue?
Is it just because RAD Game Tools has such an impeccable reputation going back 30 years as a middle-ware vendor that Intel is playing nice?
Really makes one think.
2,740 (1.41/day)
UK, Leicester
System Name Main PC
Processor 13700k
Actually, both Intel and motherboard manufacturers are at fault here, in my opinion. Intel for making it possible to remove the power limits completely (yet warning against it), and motherboard manufacturers for disregarding that warning. Have to make your product look as good as possible ...even if only for a brief time before it's failing. Then the blame game begins and the customer ends between a rock and a very hard place. Just my two cents.
True, ASRock for my board have a bios for download available listed as a stable build, I install it and it defaults to 20C higher than the specified safety temperature on the CPU (120C tjmax, should be 100C).
On another board if I enable XMP, it significantly over volts the IMC.
We know the ASUS debacle of blowing up AMD 7000 series chips. Then changing their web site to make it look as if the problem was never there, removing liability etc.
Making MCE a standard default bios mode.
For sure is arguments to lock down the bios, as motherboards manufacturers are failing to show restraint, they all want that extra few % on motherboard reviews.
It wouldnt surprise me if my 120C tjmax bios is an ex review bios, where they forgot to flip the default back for public consumption. (reviewer shows in video, look I am using auto for tjmax).
I think a solution I would like to see is, where Intel/AMD have to approve each bios before release, the Board vendors have a bad boy points system, different mistakes give different points, if they get X amount of points within a period of time, they go through a ban of being allowed any K or X features in their bios at all, full lockdown, to comply and not be labelled as a bad boy, all non spec features "have" to be off by default.
The industry is in a bit of a mess.
What are these settings Intel advised to change? I didnt comment on them as they wasnt disclosed. I assumed in my head though Intel are likely telling people to configure spec power limit's.
2,321 (2.15/day)
Intel has been pushing things to the brink for many generations ever since Ryzen became really competitive, anything goes to get that performance crown in reviews. It's how things like the 14900KS came to be.
Competition is great and all but I'd love to see a "founders edition" reference motherboard design. They surely exist in a lab and probably have much better and saner layouts than what AIBs are doing now. But at least making a template bios with mandatory settings - both in terms of default values and configuration visibility - would be great, having to look for a specific board version from a specific vendor to get a specific feature available in the bios (i.e. default gpu boot, pcie power modes, exotic bifurcation options for external adaptors, etc.) is complete bullshit
1,068 (1.06/day)
don't AMD GPUs this generation use more power than equivalent nvidia 4000 GPUs?
Those GPUs do use a bit more power, but they don't crash the game because of this. GPUs are not an issue here. Overpowered, unlocked i9 CPUs are, regardless which GPU is used.
"We're sorry, but your PC is too fast to run this game."
"We are sorry, but your PC has a motherboard tuned towards bigger-number-better and pushing unlocked CPU into instability territorry"
Poor coding being dumped on players.
And poor batch of CPUs running unstable in overprovisioned motherboard.
8,122 (3.18/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
No option for controller support is my biggest gripe.
1,068 (1.06/day)
Doubtful, as vast majority of CPUs simply work with game, including i9. They clearly say it's a small number of i9, so it could be a batch or specific motherboards that overprovision those CPUs.
4,908 (3.91/day)
São Paulo, Brazil
System Name Project Kairi Mk. IV "Eternal Thunder"
Motherboard MSI MEG Z690 ACE (MS-7D27) BIOS 1G
Cooling Noctua NH-D15S + NF-F12 industrialPPC-3000 w/ Thermalright BCF and NT-H1
Memory G.SKILL Trident Z5 RGB 32GB DDR5-6800 F5-6800J3445G16GX2-TZ5RK @ 6400 MT/s 30-38-38-38-70-2
Storage 1x WD Black SN750 500 GB NVMe + 4x WD VelociRaptor HLFS 300 GB HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700
Audio Device(s) EVGA Nu Audio (classic) + Sony MDR-V7 cans
Mouse Microsoft Ocean Plastic Mouse
Keyboard Galax Stealth
Software Windows 10 Enterprise 22H2
Benchmark Scores "Speed isn't life, it just makes it go faster."
This is just a case of rumor and FUD being blown out of proportion. I suspect developers are either trying to defend their game's quality or outsource a problem they have into something else.
Any Raptor Lake system that is crashing at stock is due to user error, such as unlocking the power without suitable cooling or an insufficient power supply. A lot of the time, people just enable XMP too, which is not a wise thing to do, unless you have a kit with a very conservative XMP profile, especially if you're running in a closed case with low fan speeds aka hotbox. I have never experienced any instability in any game or software with my i9-13900KS.
I mean this is an enthusiast product. Removing the power limit is an awesome ability to have. But it's unwise to do so on a conventional machine. With 360-420 mm AIO's or large tower heatsinks such as the NH-D15, you won't want to run a Raptor chip above 300 W.
Toothless
Tech, Games, and TPU!
9,359 (2.52/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard MSI MEG x570 Ace
Memory 4x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Not really, no. Three models causing issue is not a "poor batch." It's simply game devs being lazy.
