[expert][tip] Using a RAMdisk to speed up your HDD - and/or reduce SSD trashing
Solaris17
Super Dainty Moderator
25,933 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard EVGA z690 Dark KINGPIN (modded BIOS)
Cooling EK-AIO Elite 360 D-RGB
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Philips Evnia 49M2C8900
Case Lian Li o11 Evo Dynamic White
Audio Device(s) Moondrop S8's on Schiit Hel 2e
Power Supply Bequiet! Power Pro 12 1500w
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
was doing some system mantinence today and gave this a go made a 1gb ramdisk and made it my pagefile
2,866 (0.49/day)
Northants. UK
System Name Bad Moon Ryzen
Processor Ryzen 5 5600X
Motherboard Asrock B450M Pro4-F
Cooling Vetroo V5
Memory Crucial Ballistix 32Gb (8gb x 4) 3200 MHz DDR 4
Video Card(s) 6700 XT
Storage Samsung 860 Evo 1Tb, Samsung 860 Evo 500Gb,WD Black 8Tb, WD Blue 2Tb
Display(s) Gigabyte G24F-2 (180Hz Freesync) & 4K Samsung TV
Case Fractal Design Meshify 2 Compact w/Dark Tempered Glass
Power Supply MSI MPG A850GF (850w)
VR HMD Rift S
Anyone tried this with a game like oblivion or fallout 3, could be very nice.
734 (0.13/day)
Golden, Colorado
System Name KAREN / EVA / GHOST
Processor Intel Core i7-950 / AMD Phenom II X4 940 BE / Core i5 3570k
Motherboard ASUS TUF Sabertooth X58 / DFI LP DK 790FXB-M2RSH / Asrock z77e-itx
Cooling Thermaltake Frio / Corsair Cooling™ Hydro Series H50 / Corsair Hydro Series H60
Memory Corsair Dominator 6GB DDR3 1600 / Corsair Dominator Quad2X4096-8500C5DF / G.SKILL Ripjaws Serie 1600
Video Card(s) XFX HD6950 CF unlocked /XFX HD5770 CF/ MSI R4890 Cyclone
Storage OCZ Vertex 2 60 WD Raptor X WD1500AHFD / Seagate Barracuda /Western Digital 80gb, Toshiba 1TB
Display(s) 2 Acer P215H 21.5 Widescreen / Acer S211HL 21.5 / HP 2009F 20inch
Case SILVERSTONE RAVEN RV02-BW / NZXT Phantom /Bitfenix Prodigy
Audio Device(s) On board / Philips MMS 321 - PC multimedia speakers
Power Supply Ultra X3 ULT40311 1000W / Cosair CMPSU-750TX 750W/ CORSAIR Gaming Series GS700 700W
Software Windows 7 64 bit / Windows 7 64 bit / Windows 7 64 bit
I finally gave this a try I am pleased with the results :D
Ainvar
7 (0.00/day)
System Name Alienware M17x R2
Processor 1.6GHz (2.8 GHz Turbo Mode, 6MB Cache)
Motherboard Dell/Alienware
Cooling 3 fan and laptop cooler
Memory 8gb ddr3 1333mhz
Video Card(s) Dual 1GB ATI Radeon Mobility HD 4870
Storage 1.2TB Raid 0 (2x 640GB 7,200RPM)
Display(s) 17-inch WideUXGA 1920 x 1200 RGB LED (1200p)
Case Laptop
Software Windows 7 64bit
Benchmark Scores Benmarks will be released on the 9th tuseday.
I do love the Ramdisk. Yes I cam from the Old dos days. Where you put the whole game on to the ram and play them.
I found a program that had a 2 week trail. I made a ramdisk of 4.5ghz and installed lotro flashboost. Then sent the files to the ramdisk. What I notice with my setup. The game ran smoother. I would like to be able to tweak flashboost not to install the Texture files but the Map files and speed up going from Point a to point b. Like this Youtube
http://www.youtube.com/watch?v=CJzXm_4j8E4
Lord of the rings ramdisk. Point a to Point B Normaly would gake 5 to 15 seconds unless the game is not defraged and it would take longer.
hat
Enthusiast
21,732 (3.41/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Would it be worth it to buy a 2GB set of memory so I could make a 2GB ramdisk to use as my pagefile?
Ainvar
7 (0.00/day)
Case Laptop
I ask about that on scottmuller forums http://forum.scottmueller.com/viewtopic.php?f=3&t=1359
My Post
Ok I dont know why they have not found a way to do this on a 64bit OS with 8gb or more ram.
Software and Games (Mostly games) tend to have a limited use of 1 to 3gb of ram while running the software due to 32 bit OS limit. Now we been slowly entering the 64 bit age with systems with 6 to 8gb of ram. But software tend to stay in the 32 OS and 3gb limit. I been reading some people have tried disabling page file and Virtual ram Just so they use more ram for software. When I read this It sound right but if you keep reading the same thread and you find they have more issues. So people with large amout of ram dont disable pagefiles or Virtual ram.
Now I understand the games tend to use Pagefiles and Virtual ram as well as up to 3gb of ram. Like Lord of the Rings use it alot 13gb of sofware and best useing on a SSD drive. Now if system has large amout of ram why can we not have a option to use part of our Ram for pagefile and Virtual ram on the ram it self? Would it act faster then a SSD drive.
8gb of ram split into 4gb of ram and 4gb Pagefile and Virtual ram.
Could this be done?
Scott post
Unfortunately most of these questions are predicated on a misunderstanding of how Windows allocates and uses memory. In addition to reading my book Upgrading and Repairing Windows, I recommend you read the following articles, which will help explain how both physical and virtual memory is allocated and used under Windows:
http://blogs.technet.com/b/markrussinovich/archive/2008/07/21/3092070.aspx
http://blogs.technet.com/b/markrussinovich/archive/2008/11/17/3155406.aspx
Bottom line: In nearly all cases, I recommend making *no* manual adjustments in Windows memory use. Windows manages memory properly all by itself, most of the manual changes a user can make will only cause trouble. The only change I do recommend is in XP, where the default virtual memory paging file (pagefile.sys) is fixed at 1.5 times the amount of RAM on the system during *installation*. If you add or remove memory later on, the pagefile size will not automatically change accordingly. On the systems that I install and maintain, I set the Virtual Memory paging file (pagefile.sys) to "System managed size", which allows Windows to change the size dynamically as necessary. Note that is now the default setting in Windows 7/Vista. Scott.
WAR10CK
192 (0.04/day)
USA
System Name Fuck ICE
Processor Phenom II X4 B55 @4ghz 1.4250V
Motherboard MSI 785GM-E51
Cooling Xigmatek HDT RS1283 Red Scorpion 120mm CPU Cooler
Memory A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800
Video Card(s) Sapphire 100283L Radeon HD 5770 (Juniper XT) 1GB
Storage WESTERN DIGITAL WD1001FALS Caviar Black 1TB 7200 RPM 32MB cache SATA 3.0Gb
Display(s) Acer P215H 21.5
Case Cooler Master HAF 922 Mid tower
Audio Device(s) onboard one
Power Supply BFG Tech GS-550 550W ATX12V V2.2
Software Windows XP SP3,Windows Vista Ultimate 32 Bits,Windows 7 Ultimate 64
Benchmark Scores Who cares It runs like a Monster
thanks man this information was really helpful
Completely Bonkers
2,576 (0.41/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
IE, firefox, and other browsers let you change the location of their cache files... perfect for moving to a ramdrive. However, Chrome doesnt have an option to do this. But I have just found a command line hack! :pimp:
For people wanting to move their Chrome cache folder to a ramdrive, here are the instructions (borrowed from a thread at http://www.google.co.uk/support/forum/p/Chrome/thread?tid=098d42a41aacdc6d&hl=en).
Instructions:
1./ Right click on your chrome shortcut
2./ Properties
3./ Edit Target, as follows: "C:\Documents and Settings\...\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --disk-cache-dir=z:\
Change the last part, z:\, to your ramdrive if not on Z:
332 (0.06/day)
Processor Intel® Core™ i5-2500K (4.6GHz @ 1.28-1.33v)
Motherboard ASRock Z68 Pro3 Gen3
Cooling Prolimatech Megahalems Rev.C + Blue Vortex 140mm
Memory Kingston HyperX Fury White (2x8GB, DDR3-1866, 10-11-10-30, 1.5v)
Video Card(s) MSI GTX 970 Gaming
Storage Crucial C300 128GB, WD Green 2TB
Display(s) BenQ XL2420T
Case Antec Twelve Hundred
Audio Device(s) Onboard Realtek audio
Power Supply Corsair HX 650W
Software Win7 Ultimate (64-bit)
Is anyone using RAMDisk effectively and with what programs? (apart for browser cache)
I use Opera and I have Disk Cache turned off and Memory Cache on so this is probably the same as having RAMDisk on?
I want to try it but I don't see any practical use for it.
5,123 (0.94/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
v12dock
Block Caption of Rainey Street
1,959 (0.35/day)
My computer seems much snappier after redirecting all my Temp files to this, Thanks ALOT!
3,351 (0.64/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Wow!
The results are simply great :)
6,270 (0.94/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Just a thoughtful question here: Would having fraps store to a Ram Drive relieve the dropping of frames and the lagg it creates with in the game its self...I have always thought that the in-game slow downs were from not being able to transfer the data fast enough...We all know how huge a file fraps creates with in just seconds.. Help me with the the calling for enlightenment on this.
Solaris17
25,933 (3.79/day)
Alabama
VR HMD Quest 3
any recognizable benefits? or does the system behaves much like before?:)
it is a little faster then before but the most recognizable thing is browsers or loading large programs like photoshop or 3dsmax. things that rely on the pagefile.
5,123 (0.94/day)
North of Germany
sounds logical... what happens when you run out of pagefile?:)
OneMoar
There is Always Moar
8,748 (1.70/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
deleted .. no idea why I said that ...
Solaris17
25,933 (3.79/day)
Alabama
VR HMD Quest 3
1,971 (0.36/day)
Bulgaria
System Name penguin
Processor R7 5700G
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
Some people will say it's pointless to allocate RAM for use as page file, because after all it is supposed to be used only when you run out of ram, but there are some programs, which are specifically coded to use the page file prior to the ram running out (like autocad).
So in some limited cases, it does make sense to allocate some of the ram as page file.
Mussels
Freshwater Moderator
58,413 (8.16/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
idiots ....
would you care to explain your comment, in detail?
your answer is what will determine if you get an infraction or not.
Completely Bonkers
2,576 (0.41/day)
Just to add to HAH's comment: moving a pagefile to RAM will also help save writes to your precious SSD. So IF your pagefile is being used, moving it to RAM will speed it up and save you writes. With modern workstations with 8GB and more memory, you might as well fix the pagefile to 1GB and stick it in a ramdrive.
Windows is supposed to have a good memory manager and you shouldnt need to play with it. However, may people DO fix their pagefile to a fixed size after a defrag to stop the pagefile from fragmenting. So YES there are reasons to "manage it yourself".
OneMoar
8,748 (1.70/day)
Rochester area
Keyboard EVGA Z15
wow guss I was drunker then I thought I was
sorry about that ..
5,250 (0.90/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
im really impressed with this thread, you got my grateful thanx and 5 star rating
1,065 (0.16/day)
System Name [Primary Workstation]
Processor Intel Core i7-920 Bloomfield @ 3.8GHz/4.55GHz [24-7/Bench]
Motherboard EVGA X58 E758-A1 [Tweaked right!]
Cooling Cooler Master V8 [stock fan + two 133CFM ULTRA KAZE fans]
Memory 12GB [Kingston HyperX]
Video Card(s) constantly upgrading/downgrading [prefer nVidia]
Storage constantly upgrading/downgrading [prefer Hitachi/Samsung]
Display(s) Triple LCD [40 inch primary + 32 & 28 inch auxiliary displays]
Case Cooler Master Cosmos 1000 [Mesh Mod, CFM Overload]
Audio Device(s) ASUS Xonar D1 + onboard Realtek ALC889A [Logitech Z-5300 Spk., Niko 650-HP 5.1 Hp., X-Bass Hp.]
Power Supply Corsair TX950W [aka Reactor]
Software This and that... [All software 100% legit and paid for, 0% pirated]
Benchmark Scores Ridiculously good scores!!!
Great thread. I got 24GB of RAM on the way. Going to make some "tweaks" to my primary workstation. I'm having some great results using Dataram's RAMdisk application. Throughput rates are simply ridiculous. I'm getting around 25 to 30 times faster overall performance compared to stuff you can find in retail, SSD-wise.
RAMdisk setups seem pretty rare. Anyone got info to share on best ways to utilize such setups aside from obvious ways? I plan to run a tweaked and modified version of Windows straight off of it. With some symlink trickery I should be able to utilize such a small amount to a farthest degree.
Mussels
58,413 (8.16/day)
Oystralia
i'd like to know how you go with the symbolic links and what trickery you have in mind
