First Build Advice, Basic!
Status
Not open for further replies.
bignokki
37 (0.01/day)
Denmark
System Name my-first-time
Processor q9300
Motherboard asus p5k-e Wifi
Cooling zalman 9700 (black/green)
Memory corsair 2x2gb
Video Card(s) hd3870
Storage 2x250gb WD
Case apevia x-cruiser
Power Supply corsair 650w
Software vista (64bit) ultimate
post pics? sure.. when I've done tha mod i will :D ... but im in spain atm, and will first be home on monday/tuesday...
JrRacinFan
Served 5k and counting ...
20,073 (3.20/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
If you guys need help with LED calculations and resistance just PM me. I used to work with original Xbox1 cosmetic mods and needed to calculate the resistance needed alot. The best rail to draw from for your LEDs is the +5v rail. ;)
I should put up a guide and help thread, but too lazy LOL.
173 (0.03/day)
System Name First Build :D
Processor Q6600 SLACR @ 3.2 GHz
Motherboard Asus P5Q Pro
Cooling Asus Silent Square
Memory 2 x 2GB GSkill @ 962MHz
Video Card(s) VisionTek 4870 512MB @ 825/975
Storage Seagate Barracuda 750GB
Display(s) Samsung 943NWX 19"
Case Gigabyte GZ X1
Audio Device(s) Realtek ALC 1200 (yes, its onboard :) )
Power Supply FSP 700W
Software Windows Vista 64 service pack 1
Hey guys!
I'm new here and i joined because i wanted some advice on building my first pc. I've done a lot of research and have come up with what i believe is a good combination of parts :D. So here goes :
Q6600 with a zalman cooler(will oc until it doesn't bottleneck my video card)
nforce 680i
9800 GTX (will oc mildly)
4X 1GB hyperX ddr800
500 gb WD
antec 900
haven't still decided on a PSU though. What do you guys recommend?
any advice will be appreciated :D:D:D
K
kyle2020
Hey guys!
nforce 680i
500 gb WD
antec 900
Welcome to TPU my friend!
Right, lets get started.
Might i ask what zalman cooler you intend to use? Quads need a high end cooler to dissipate heat efficiently, what model have you chose?
With the 9800, if you intend to overclock it, have you thought about buying an aftermarket cooler? You should really either run it naturally aspirated or if you do want to overclock, try and buy a new VGA cooler - stock ones just dont cut it.
The rest sounds fine, but id do a bit of surfing around for cases - I own a 900, great cooling etc, but the cable managements an absolute pain on them and theres no motherboard tray.
Now as for a PSU, dont go buying a cheapo 700W MeGA P1mPIng one with thousands of LED's and so on - go for a well known brand like corsair, hiper or tagan. And try and go modular if you can afford it, makes everything alot tidier (Modular means you can remove cables that you arent using). Make sure there enough juice aswell, You'll need 600W+ to power a quad and a 9 series. I would recommend a Thermaltake Toughpower series, or if you have the money and like rock solid stable power + it to be flashy and modular, try and get a Tagan Piperock.
Hope i have helped in some form, any more questions, ill be more than happy to help!
173 (0.03/day)
Case Gigabyte GZ X1
thanks for the post
i'm thinking of getting a zalman 9700 as i've seen it around a couple of builds. And about the vga cooler, would i need it if i'm only going up to, say, 750 on core given that i have lots of ventilation? I'm trying to keep to my budget of 850$
About cable management in antec 900 http://www.youtube.com/watch?v=qnePBkCor1E
this guy makes it look easy. I'd give it a try as i love the 900 and wouldn't like to give up on it
thanks for your help on this :D
really appreciate it:D
173 (0.03/day)
Case Gigabyte GZ X1
also i'm considering going with 9600GT SLI as it seems to have an edge over the 9800GTX.
What do you think?
K
kyle2020
thanks for the post
the 9700 is what im purchasing soon - looks nice + great cooling, good choice!
Even overclocking by a small ammount isnt recommended with stock coolers - go for an Arctic Cooling Accellero S1 or an Akasa Vortexx NEO - i dont know if either fit any 9 series, but i have had both on my GT @ 800-1850-2100 and they both cool it excellently.
3,628 (0.62/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
can i just show imput for the nvidia 8800 gt card? when i was asking for advice bore gettin the ati i was told its a great card, gues its worth the extra five min research if it is better, i dont actually no.
bignokki
37 (0.01/day)
Denmark
Processor q9300
Storage 2x250gb WD
Hey guys!
nforce 680i
500 gb WD
antec 900
i brought a q9300, which i regret, think q6600 will be better when you do oc...
copare the prize on 2x250gb WD, and 1x500gb WD, where i brought 2x250 came out cheaper... (both 7200rpm)
the zalman 9700 (black/green), is ok, i have it my self, it rly looks cool... i can't tell any results about cooling, as my cpu is barely oc'ed...
psu: i have a corsair (650W sli-rdy) and im happy with it... no fire yet.. it keeps up my system (q9300 / hd3870 / dvd-drive / 2xhdd / 4xfans / and some LED's)
GL on your upgrade/build...
bignokki
37 (0.01/day)
Denmark
Processor q9300
Storage 2x250gb WD
got home from spain... (a bit late... my car broke... :( ) but i've come to another prob... i went in to the internet to buy my LED's, resistors and some cable... but what cable do i need i have alot of options:
- 0.15mm²
- 0.25mm²
- 0.50mm²
- 0.75mm²
- 1.00mm²
- 1.50mm²
- 2.50mm²
- +2.50mm²
what to chose?! :O
K
kyle2020
- 0.15mm²
- 0.25mm²
- 0.50mm²
- 0.75mm²
- 1.00mm²
- 1.50mm²
- 2.50mm²
- +2.50mm²
what to chose?! :O
well you dont want it too thick or else it will look messy / be hard to work with, but thinner cable will be prone to snapping / be awkward for cable management. Go for the 1mm or so, just order one, try it then order more if its right.
bignokki
37 (0.01/day)
Denmark
Processor q9300
Storage 2x250gb WD
ok, i'll try that... thx again..
K
kyle2020
No problem - id give more advice but have never done any mods with LED's before.
JrRacinFan
20,073 (3.20/day)
Youngstown, OH
Storage 20+ TB
- 0.15mm²
- 0.25mm²
- 0.50mm²
- 0.75mm²
- 1.00mm²
- 1.50mm²
- 2.50mm²
- +2.50mm²
what to chose?! :O
I would opt for 1.5mm, so it would not snap as easily.
3,628 (0.62/day)
Display(s) 720x576
it also depends where on your case it is, mine's hidden behind the front cover so i didnt need to worry bout it being moved and snapped so i could use the cheaper and smaller size for example.
K
kyle2020
Thought id save this for my stickied thread . . . POST NUMBER ONE THOUSAND EVERYONE! :D
bignokki
37 (0.01/day)
Denmark
Processor q9300
Storage 2x250gb WD
Gz
np rly... :p
drdaver
20 (0.00/day)
System Name Davey Jr.
Processor e6300@3.2
Motherboard abit ab9 pro
Cooling 8x 80mm thermaltake fans with controller, zalman 9500, accelero
Memory 4gb geil
Video Card(s) getting 4870 x2s
Storage 4 wd 640 se16
Display(s) samsung and sceptre 24 lcds
Case thermaltake xaser iii
Audio Device(s) sound blaster x-fi platinum
Power Supply antec 1000w
Software xp home sp3
#1, setting a strict budget is essential! too easy to get drawn into buying more then you need, thanks for te guide
K
kyle2020
Couldnt agree with you more. When you start spending money like its going out of fashion it just gets silly.
Ahhzz
8,754 (1.48/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
Came across this site this morning, and it looks like it might help tweak some first-timers who need basic advice :)
http://choosemypc.net/
Status
