We potentially look at any of the HD6XXX desktop cards.
What do you mean, "look at"? If you don't want to answer this here, feel free to send me a PM.
But our order of preference would be the "native" sized devices first. If you can get these support in the next 2-3 weeks, I'll add the 2nd $100 donation.
6970
6870 (looks like you already support)
6770
6670
6450
I have these ones on my support list for the next version, except for 6770. For that I'll need a BIOS sample, see below.
We use RBE to modify the video bios to increase the "upper limit" of the GPU/Ram and to add an instance # to the "Hardware Specs String" to help automate our testing of the cards.
You do realize that I will never be able to guarantee that this will work because I can't and won't hack the digital signature, right?
Well, I guess you know pretty well what you are doing, so don't mention this...
Note, I'm not sure what "BIOS examples" you're looking for. Can you clarify?
Sure. In order to put these cards on RBE's support list I need BIOS images of them. If you have the cards, extract the BIOS images off of them (e.g. via GPU-Z) and send them over to me by eMail (or, post them in the forum, maybe other users will be grateful; also, consider uploading them into the TechPowerUp BIOS database using the built-in feature for that in GPU-Z). If you are having a hard time extracting the BIOSes using GPU-Z (maybe due to some of the BIOSes being used for IGP chips), send me a PM, I'll help you.
To be more precise, I need BIOSes of these cards:
- 6250
- 6310
- 6530
- 6550
- 6570
- 6750
- 6770
as we don't have those in our TechPowerUp BIOS database.
