Help: Strong PC, Low performance, First build
A_Heckwan
2 (0.00/day)
First off, I don't know much about building PC's
I spent hours going through Youtube videos on building a PC.
Finally managed to put it together and it works. Windows and software are already installed and good.
I should be blasting through games and applications with the rig, but it stutters alot and gives me low FPS on many games including Skyrim, and VR games.
I tried many different things suggested but it doesn't help much. My only thought right now is maybe the PSU isn't giving enough wattage?
It's like the processor isn't doing a good job, maybe there's a defective part? Would be my luck.
I'm pretty sure all the necessary drivers are installed.
Parts list:
NVIDIA GeForce RTX 2080 SUPER 8 GB Video Card
AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor 16 Threads
MSI MPG X570 GAMING PLUS ATX AM4 Motherboard
G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory
Samsung 860 Evo 500 GB 2.5" Solid State Drive
Crucial P1 1 TB M.2-2280 NVME Solid State Drive
Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive
Corsair Air 540 ATX Mid Tower Case
SeaSonic FOCUS Plus Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
KINGWIN KW525-7U3C 7 USB 3.0 Port Hub For 5.25” Include 1 IQ Charging
2,693 (0.44/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
Tweak your ram, monitor temps.
Have fun
40,435 (6.57/day)
Find the Zen Garden Here too
69 (0.05/day)
System Name Carnival of Glass
Processor Intel i9 14900K (previously 12900K/9900K, 8086K/Xeon X5670)
Motherboard ASRock Z790 PG SONIC (Gigabyte Z690 Aorus Master, Gigabyte Z370 Aorus Gaming 7/390 Des/X58A-UD7)
Cooling Corsair Hydro open loop, 480mm XR7, 360mm XR5!
Memory 32GB Corsair Dominator 6000MT DDR5 @6466 CL36-38-38-72-114-2
Video Card(s) Zotac RTX 3090 w/Corsair XG7 block (previously 1080Ti/970) +200 core +800 RAM +shunt mod
Storage 1x 500GB Samsung Evo 970 boot, 1TB ADATA, 2TB Sabrent RQ, 2x2TB Crucial MX, 4TB WD SN850X, 16TB NAS!
Display(s) Acer Nitro 27" 4K, dual Acer 24" 1080p LED, 65" Panasonic UHD 4K TV/55" Toshiba 4K UHD in bedroom
Case Corsair 7000X (previously Corsair X570 Crystal SE)
Audio Device(s) Onboard + EVGA Nu Audio Pro 7.1, Yamaha 4K AV Amp, Rotel RX-970B + 4x Kef Coda IIIs :D
Power Supply Corsair HX1500i Modular PSU
Mouse Logitech G502 Lightspeed (previously G600 MMO)
Keyboard Logitech G910 Orion Spectrum (previously G19)
VR HMD Quest 3 + Pro controllers
Software Windows 11 x64 Enterprise (legal!)
Benchmark Scores https://www.3dmark.com/spy/18709841 https://valid.x86.fr/s9zmw1 https://valid.x86.fr/t0vrwy
Can't say i'm a fan of AMD's CPUs as they apparently have weak silicon and aren't really fully 7nm, have a 14nm IO die and 'chiplets'.. Funny really when Intel do that or add cores, everyone whines.. But for such a machine that's a bit strange dude..
First off you've installed all the latest drivers and updates, right? And second, you don't mention a CPU cooler...you did use a good one yes? And thermal paste of course? That PSU -should- be fine if it has a strong 12V rail.. However if it has dual or more rails it may be an idea to check your wiring and make sure you don't have everything sat on just one. Haven't looked up the PSU but it should tell you on the box or the PSU its self.. Have a look at voltage/power/current ratings, might as well eliminate it.. But it sounds more like some kind of thermal issue to be honest. I'm assuming you installed Windows to your SATA SSD, are installing games to the 1TB M.2 SSD and using the HDD for less played games/data storage?
I thought i had an account but just registered to try and help out.. Your PC is on par with if not a tad better than mine in some respects, though i do have faster drives, bigger PSU and its nVidia/Intel based lol hmm.. I have an AIO cooler on the CPU at the moment.. You're not using a stock cooler or something? I'd check the mounting of it too, could not have enough pressure.. And as i said you didn't mention any!
1,374 (0.38/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
You should keep this pro-Intel nonsense to yourself. The setup is perfect and so is the PSU. The problem says somewhere else.
1,470 (0.22/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Have you installed the motherboard chipset drivers? this is the first thing you should install upon turning it on for the first time, you will have a CD with the motherboard or you can go to the motherboard support page and download them from there, this is my preferred option as they will be the latest up to date drivers. Then go to nvidia.com and download the right drivers for your RTX 2080, install and you should be good to go. If you have done this, try reseating the GPU, ie: pull it out and put it back in. Make sure the pcie cables are inserted fully. and double check all other cables including the ATX 24pin, CPU 4/8pin, ensure RAM is seated fully.
If you're sure all of this has been done, then try a GPU driver reinstall, download DDU to remove all nvidia drivers from your system, download the newest ones from the website and reinstall them. if your still getting choppy framerate, monitor whats going on with both your GPU and CPU with something like afterburner/GPU-Z when you're playing a game to see whats going on
461 (0.25/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
That is normal because CPUz is benchmarking the CPU.
What scores did you get ?
Here are mine (see my system specs under my avatar):
I would make sure you have the latest Nvidia drivers installed:
And the latest AMD chipset drivers:
And the newest BIOS flashed:
And check the Memory Tab on CPUz and make sure it says your RAM is in Dual channel mode and running at 1800 Mhz (2 x 1800 = 3600).
Because with your rig, you should be getting Very High FPS on pretty much every game.
I have a 3700x and 2060 Super and I get 100+ fps on new AAA games and 200+ fps on older games on Very High/Ultra settings.
1,470 (0.22/day)
Ran CPU-Z, hit Bench and from 1% it shot up to 99%
Gpuz not cpuz, as it will log all of the information from your graphics card whilst you are running a game
40,435 (6.57/day)
Remove the hdd for now.
Deleted member 67555
Which drive is your OS drive? and which drive are you storing your installed games?
13,213 (3.79/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Just to throw something different into the ring, unplug the USB 3 Hub and try again, there has been cases where they have slowed systems down and caused what appears to be lag.
40,435 (6.57/day)
Yup cheap controllers
860 (0.46/day)
The New England region of the United States
System Name Daily Driver(gaming, browsing)
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)|Kingston KC3000 2TB (Misc)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Benchmark Scores Nope
That power supply should provide more than you could possibly need! I would start with the updating the motherboard to the latest BIOS. Then move on to drivers in the same way. Everything from the motherboard vendor, then get the video drivers directly from Nvidia.
Some people mentioned disconnecting the extras, that's also a good idea. Setup just the basics, boot drive, power, half the RAM and the video card. Install just one of the games you are having issues with on the boot drive.
8,127 (2.27/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
if you do a fresh install of windows, unplug all other drives except c:/ until its done installing and updating.
3,984 (1.19/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
Definitely check your ram because if you don't set the settings manually or turn on xmp then your ram will run really slow. The ram running at jedec is likely not causing the issue by itself but it is definitely a good place to start.
After that, you need to play some games while logging data such as usage and temps for both the CPU and GPU to see where to go next.
69 (0.05/day)
Pro-Intel nonsense? It's merely stating fact.. I'm hardly a 'fangirl' although i saved up and saw the Intel light about 10 years ago, before that i had nothing but AMD, ever since i built my own PC when upgrading from a Pentium 2 lol Athlon Thunderbird 1.2GHz! Socket A of course.. I have a ton of different hardware here, even some Cyrix, IBM, IDT chips, Motorola 68K series, PPC.. I just like my CPUs to last longer than a few...years or months without damaging themselves ;) Hell my original Phenom 9850 BE cost me £700 new (with board and RAM), had to have it as oooh "native quad core" and "integrated memory controller" and "Intel FSB bottlenecks"...yet it was awful, hot, never overclocked well and had a TLB bug.. When i picked up a Core 2 Quad cheap to play with years later, even though it wasn't as high end a board used etc, it beat that thing by miles and wouldn't have cost me as much! Haha.. I was a little wild back then though, upgrading a little bit whatever i could every 6 months or something.. In the space of a year when i was a young teen i went from a TNT2 Ultra to a GeForce 2MX to a GF3 Ti200 within a year or so! Set records with that GF3 though.. I even lapped the GPU, Heatsink and RAM, attached custom cooling and had the core at 240MHz, the RAM at 555MHz.. How sad is it that i can still remember that? But it beat the Ti 500 and the price had dropped to £125 back then, when the original GF3 was about £250 not a few months before.. Then after being disappointed by a Ti 4600, i got a 9700 Pro so i could play Max Payne 2 with Mirror reflections in DX9.. Stayed with Radeon right up until i had a 290X that was fast but died on me, partly MSI's fault..got a GTX 970! I...think i need a life. Or a Husband...or both? AMD has ripped fans off for years though, ever since they purchased ATi, which really upset me.. Those that say Intel do that, well...they're both massive corporations that want to sell you things, except Intel seem to help people/charities more.. So aren't they really just two sides of the same coin anyway? Haha..
My other claim to fame is overclocking a Toaster... No sarcasm here, i used a transformer to almost double mains voltage, giving it about 400VAC.. Sure turned bread into toast quick! Even survived a few rounds before it popped.. Photonic Induction did it better though! xD
Hope the OP got these problems sorted! Must have done as its rather quiet on that front.
719 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
Did you enable silent mode on the fans in MSI Dragon Center.
It caps the Max CPU speed to keep temps down. I ran into this issue on my MPG X570.
Once set back to balanced the PC shot up to over average on performance.
2,428 (1.39/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity, EK-Quantum Reflection PC-O11, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1)
Storage Samsung 2TB 980 PRO 2TB Gen4x4 NVMe, 2 x Samsung 2TB 970 EVO Plus Gen3x4 NVMe
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
I hate to necro the thread but I highly suspect the "KINGWIN KW525-7U3C 7 USB 3.0 Port Hub For 5.25” Include 1 IQ Charging" the OP mentioned is a serious problem.
I just got two of these recently for my towers and it seems when you supply the auxiliary power there is something wrong there. I found the following reddit post that describes the situation. I don't know how to verify that post but I can say when I was supplying the aux power to the unit suddenly my SSD tray light turned on and my machine refused to post 99% of the time so there is definitely some electrical problem with this unit from the factory. I spent 60-ish dollars (for both) on this malfunctioning junk and I'm pissed. Hopefully I didn't damage my motherboard or SSD or PSU. Buyer beware!
https://www.reddit.com/r/buildapc/comments/t3m10r
I found a similar Amazon post with a picture of the PCB. Mine is nearly identical but the component on mine is SS24 not SS34.
